Old May 18, 2011, 01:20 PM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
5.8ghz 200mw range flight - record by futurebreeze 24km - video post 1281
Range with 5.8ghz 200mw is possible. While this thread started out as showing that range was possible it has changed to a general purpose thread on those that are looking to get extra range out of 5.8ghz.
Getting started
The general rule to get extra range from 5.8ghz is using circularly polarized antennas. These antennas can either be brought or made at home. Antennas used during my range attempts were a combination of high performance tuned antennas from Markus123456 and tutorial guides from IBCrazy (where you can also buy performance tune antennas).
Antennas
Proper antennas and their placement are the keys to successful 5.8ghz flight. As you see here we are using only 200mw of power. Generally circularly polarized (CP) antennas give the best performance. It is not to say linear can not give range but most will find it easier to achieve by using CP antennas. If you change from Linear to CP antennas remember to change both antennas on the video receiver (VRX) and the video transmitter (VTX). If you have linear one of while CP on the other it will effect your overall range and might not give the benefit you are looking for.
The first antenna you will need to get you hands on is a cloverleaf (CL). This antenna goes on your plane, i.e. the VTX. This antenna will remain on either short or long range flying.
The antenna on the VRX depends on the mission. There are a ton of antennas out there. TrueRC have a few antennas that can help with multipathing and of course there are the antennas from IBCrazy. For omni style flying on my planes I like to use a Skew-Planar Wheel (SPW). With a good layout and antennas I pushed it to 3km and markus123456 went 6km. For safe flying tuned antennas will give you 2km in a plane but so far the reports are much less in multicopters. The key to extra safe range is making sure one of the lobes is facing the front of you plane.
The CL and SPW are not overall hard to build but they are hard to tune. For best results with home builds use 0.6mm copper wire and measure as best you can. My home builds go out 1km clear but they don't get the overall range of tuned antennas. Homebuild antennas are great for crash and bashing. CP antennas don't like crashing as they can bend out of shape and this effects the performance. If you don't crash and like range then pony up for tuned antennas as it will be hard get the same range on homebuilds. For homebuilds the cable you need can be easily found on ebay or you can use part of the linear antennas you already have. Each brought cable gives you the chance to make 2 antennas.
For directional antennas when you are going for max range or have an antenna tracker a helical is a great choice. They are easy to build, IBCrazy has a tutorial and they are wide band which means you can getting a better signal across the whole frequency (and makes them easier to build). I use 1mm copper wire and copper coated printed circuit board for the base. A 5 or 6 tune gives the best beam width for flying but the best range can be had with a 8 turn.
Current Record
The current record is 24km by costi_n. video post 1281
Some discussions within the thread (more to come as I update)
Wifi frequencies around the world
I cooked my RC305 transmitter... fixable? or details in here
Other good 5.8ghz threads
Parkzone Ultra Micro FPV - 5.8ghz 200mw FPVhobby TX - 40g without lipo's
5.8Ghz
whakahere is offline Find More Posts by whakahere
Old May 18, 2011, 01:51 PM
BlueAngel2000 is offline
Find More Posts by BlueAngel2000
Flying like an Angel.
BlueAngel2000's Avatar
Austria
Joined Sep 2007
Wow, really nice.
Congratulations.
Maybe your recorder does something to the video....
I would try that flight again, when the CL and SPW combo performs as good as the last time.
Maybe you have really damaged a little bit the rf module of the receiver, or at least introducing external noise via the rssi wire into the module.
I do use RSSI too on this receivers, but use a simple RSSI buffer (voltage follower) to decouple the rssi output off external noise.
Do you have some more pictures of the helical, especially the transformer.
Because i will build one too and haven't decided yet, which way to go with the transformer.
Alex does suggest the 75ohm coax (which i have at home) for 5,8G.
BlueAngel2000 is offline Find More Posts by BlueAngel2000
Old May 18, 2011, 02:04 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
Originally Posted by BlueAngel2000 View Post
Wow, really nice.
Congratulations.
I have no idea why it no longer shows rssi on two of my receivers that I hooked up. both no longer give any read outs for rssi. I removed the wire because It didn't work anymore. I have another receiver that runs on 5 volts that the rssi does come out still so I might do a test flight with that AND compare it to my current ones.
I just used a hecker transformer. have a look at my first picture and you can see it. I wish I could tune this antenna.
Old May 18, 2011, 02:06 PM
vipix is offline
Find More Posts by vipix
FPV from Lithuania
vipix's Avatar
Lithuania
Joined Mar 2007
Nice. I have same AV RX/TX and planing to extend range.
What RC radio do you use?
vipix is offline Find More Posts by vipix
Old May 18, 2011, 02:13 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
5.8GHz helicals are hard to match well. Thus they are not always very efficient and checking them requires some very expensive equipment. Thus I have been recommending the Hecker transformer match as it is the least prone to errors. I personally use it on 2.4GHz and 5.8GHz helicals. On 900MHz and 1280MHz, I use a tapered microstrip match. I am working on a block strip match as well which will be the easiest of all of them once I figure out how to do it correctly.
I have plans for a 5.8GHz CP patch. I have not been able to do anytesting yet, but I hope to do it soon.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old May 18, 2011, 02:35 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
I am using a futaba 9C with chainlink attached. I do need to fix the placement of a antenna on the RX as right now I have it pointing at the plane.
It looks like I screwed my RSSI on both transmitters. Neither of them give out any reading now. both are dead in that area I fear that I have damaged my 5.8ghz receivers. my other one which runs of 5 volts still gives a reading but I blew a cap on it one day when I plugged 12 volts into it I wish power was easier.
Old May 18, 2011, 02:37 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
-Alex
I hope you can come up with some easy designs as I will build them. I have no expensive equipment because if I did I would most likely just blow them up anyway
Old May 18, 2011, 03:28 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
The chainlink seems to be working well
Out of curiosity what voltages have you set the dosd rssi at?
NDw is offline Find More Posts by NDw
Old May 18, 2011, 03:50 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
um .... I used the setup wizard in the commander program. It did it for me. I have no idea and my plane is in the car ... ready to roll for testing after work tomorrow. This time I am taking my 5000ma battery AND all three of my receivers to test which one gives me the best picture over the same area on cloverleaf and SPW. Which ever one I deem the best will be going flying with a ton of battery and going the distance I hope. I am fixing my antenna now so it is upright on my RX.
Old May 18, 2011, 04:59 PM
vipix is offline
FPV from Lithuania
vipix's Avatar
Lithuania
Joined Mar 2007
What is the best antenna on TX for helical on RX?
Old May 18, 2011, 05:09 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
Well I am still testing so the best person to ask about the best antenna is IBCrazy as he has more knowledge in his pinky finger about this than I do altogether.
Of course the Helical has to go on you video receiver. It is like a patch antenna. My goal is to push this 6 turn as far as I can and then once I have seen the distance it can go I am going to build a 4 turn one for more close in flying. On my plane I am using a cloverleaf right now but I have no idea if the SPW might give me that extra bit of range. I guess there is two ways I could find out 1: test it or ask Alex (IBCrazy). One of my goals is to fly across the Rhine to the town across from me. There are some nice castles to fly over across that little stretch of water (1km wide).
I think overall after all this testing I most likely will use the cloverleaf and SPW for my main day to day flying on 5.8ghz. I like the omni feel of flying around me without having to worry about where the antenna is point at any given time. 5.8ghz is still mainly set up for short range flying right now but I am just interested to see how much I can push it. Part of the hobby.
Anyone can do what I am doing. I started flying a year ago (learnt to solder at this point too). got into FPV about 6 months ago. I have no electronic background .. I'm a primary school teacher
Old May 18, 2011, 05:20 PM
rabe2000 is offline
Find More Posts by rabe2000
Joined Jan 2011
hey Whakahere, just congrats and respect !
Have the same tx/rx and made a testflight of 2,6 km today with cl and sw with really good video. but was too scared to go on, as flew with gopro and without groundrecording. so no gps-data for searching my SW, if things run bad.
must build the helical asap.
rabe2000 is offline Find More Posts by rabe2000
Old May 18, 2011, 05:51 PM
cmanley_nl is offline
Find More Posts by cmanley_nl
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
Does that huge chunk of plastic around the original antenna (in your 2nd attachment) really have any purpose besides perhaps protecting the wire from being folded? I'm asking that because those thick antennas cause a relatively huge amount of drag on gliders.
cmanley_nl is offline Find More Posts by cmanley_nl
Old May 18, 2011, 05:58 PM
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
I wouldn't think so. You could just take as much of that plastic off and use shrink tube to make it stronger .... or go the smarter way and just make yourself a Cloverleaf/SPW antenna with it. Then you could bank your plane all day while you drive up those thermals and not worry about any dropouts.
Old May 18, 2011, 06:02 PM
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
I agree - a cloverleaf antenna would be most suitable (except on the smallest of gliders). I just found more info on the insides of rubber duckies: http://martybugs.net/wireless/rubberducky.cgi
Help! Poor range: Identifiy this 5.8Ghz(?) antenna nosaari FPV Talk 7 Aug 12, 2013 01:48 AM
Cool Hobbyking has cheap 5.8ghz 200mW sets. SargeNZ FPV Talk 7 Mar 06, 2012 10:32 AM
Discussion 5.8ghz 200mw on Blade 120 SR - pics Vitamin_J FPV Talk 2 Mar 27, 2011 11:25 AM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 09:01 PM
Sold 5.8GHz / 200mW Video Tx and Rx. New. Mr.RC-CAM FPV Equipment (FS/W) 1 Nov 02, 2010 10:07 PM
