Old Mar 08, 2012, 02:32 AM
mewert is offline
Find More Posts by mewert
Team Armattan
mewert's Avatar
College Place, WA.
Joined Apr 2004
Quaker
Scratch built Quaker 84" ; OS .70 Surpass FS; BJ 40" balsa over foam floats.
mewert is offline Find More Posts by mewert
Old Mar 08, 2012, 10:52 AM
Herman Munster is offline
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
Couple of nice planes. When do you have the float fly?
Herman Munster is offline Find More Posts by Herman Munster
Old Mar 08, 2012, 12:15 PM
Kyler1 is offline
Find More Posts by Kyler1
United States, SD
Joined Aug 2010
Did you recover that rascal 110 or do they have a plane that comes in that sceme.
Kyler1 is offline Find More Posts by Kyler1
Old Mar 12, 2012, 07:47 PM
hydro_pyro is offline
Find More Posts by hydro_pyro
Blade mSR freak
hydro_pyro's Avatar
Irish Hills - SE Michigan
Joined Jan 2010
My Dynam epp Cessna 182 on homemade foam/econokote floats and aluminum tubing struts...
hydro_pyro is offline Find More Posts by hydro_pyro
Old Mar 12, 2012, 08:23 PM
sparkx38 is offline
Find More Posts by sparkx38
Livin ta fly
sparkx38's Avatar
United States, LA, Shreveport
Joined Apr 2011
Originally Posted by mewert View Post
Here is my Rascal 110 on Hangar 9 floats. Power is an OS 1.60 Twin FS. We have a nice spring float fly at Scootney Park in Washington State.
Any Video?
sparkx38 is offline Find More Posts by sparkx38
Old Mar 14, 2012, 10:11 AM
Kyler1 is offline
United States, SD
Joined Aug 2010
The ice on the lake is comming off very early this year. As soon as we get the right direction of wind it will come right off. I think it will be today.
Old Mar 20, 2012, 10:38 AM
Jürgen Be is online now
Find More Posts by Jürgen Be
Jürgen Be's Avatar
near Stuttgart, Germany
Joined Oct 2008
Flying Boot
"Flying Boot"
from FSK ( Flying Styro Kit )
And here`s video, flying from water last weekend........
Flying Boot (3 min 45 sec)
Flying weight is around 320g with 3s 1350mAh Lipo as flown in the vid.
Flying is possible from 2s 500mAh too, but prefered the 3s on that windy day.
Motor is a 1100kv outrunner with a 8 x 5 APC Slowfly prop and an 18A ESC.
Gives lot of power, much more than needed, on the 3s Lipo.
To get the "Boot" out of the water, I modified the sponsons, they were much too high and had a too low angle to the front. Upper front is nearly at the same level, as the leading edge of the lower wing now. Took away the fixed waterrudder and changed to a stearable one with an additional servo in the lower fus.
Sealing the fus was unpossible, so I always had some water in, sometimes lots of, in case of the big hole round the pilot. So I desided to drill two holes, 5mm dia.
, one direktly to the step, one at the rear end of the fus. The water now comes out when starting . This can be seen in the vid at 00.18 - 00.21.
Jürgen
Jürgen Be is online now Find More Posts by Jürgen Be
Old Mar 20, 2012, 11:09 AM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
Jurgen i love the boot but i dont think we can get one here in the US .I have been looking for a nice project to build out of foam and i think i will try to build my own just a little bigger. I also think after reading your post it will have a covered pilot area. lol Thanks for your upgrades and i will take them to heart when i try one.joe
cracksmeup is offline Find More Posts by cracksmeup
Old Mar 20, 2012, 11:37 AM
velyter is offline
Find More Posts by velyter
Aviator
Bellevue, WA
Joined Dec 2007
Pby
I just built this PBY. The fuse is all fiberglass and the wings are built up balsa. The wing is a plug in making it easy to transport in my SUV. She is all electric with twin 32 840 kv motors. This a 6 foot wing span.
velyter is offline Find More Posts by velyter
Old Mar 20, 2012, 12:07 PM
cracksmeup's Avatar
Joined Jun 2009
^ 6 ft is a nice size for a pby and she looks great.Get us some flying pictures on the maiden. Nice job ! joe
Old Mar 20, 2012, 12:08 PM
dgfinch is offline
Find More Posts by dgfinch
Stone Mountain, GA
Joined May 2007
Who makes her?
dgfinch is offline Find More Posts by dgfinch
Old Mar 20, 2012, 12:16 PM
velyter is offline
Aviator
Bellevue, WA
Joined Dec 2007
The lake is still frozen it will be another month. I also am in the middle of building my new CMP Beaver with commander fiberglass scale floats. I also have the Eflite beaver and this one is a little larger and beefier. I will do a review once it is built.
Old Mar 20, 2012, 12:17 PM
velyter is offline
Aviator
Bellevue, WA
Joined Dec 2007
Originally Posted by dgfinch View Post
Who makes her?
CMP makes her and I bought it from Nitroplanes. The quality of this PBY is great.
Old Mar 20, 2012, 01:54 PM
Fred Sanford is offline
Find More Posts by Fred Sanford
Fred Sanford's Avatar
United States, MN, Bemidji
Joined May 2003
I have a similar PBY from the old Kyosho kit. I found it necessary to add spray rails. Can't help but wonder if this one is from the same fg mold! Tip floats look the same in the ads. Mine is a foam one piece wing with balsa sheeting. Came in three parts. Very nice flier once I ditched the OS .10's and went electric on 4S.
Fred Sanford is offline Find More Posts by Fred Sanford
Old Mar 20, 2012, 08:33 PM
Kyler1 is offline
United States, SD
Joined Aug 2010
I just took my cub out for the maiden on floats. Didn't go so well. It was doing lots of ground loops and I finally got it up. Came around and the wing clipped on the neighbors shore line and made a little crush in the wing, wasn't bad and the fusealage is fine. The wing bolts sheared after it hit and the little pilot ejected out and ended up about two feet away, he was even screwed in. I dunno?????????????????????????????
Gallery Pics of your builds!!!! Post your Pics!!!!! tc3wins Multirotor Talk 198 Aug 09, 2015 02:44 AM
