Old May 17, 2011, 08:13 PM
hotrodder is offline
Find More Posts by hotrodder
hotrodder's Avatar
United States, CT, Manchester
Joined Jan 2007
Sent my Dx6i back to Horizon for repair
I sent my radio (dx6i) back to Horizon Hobby because it would not bind up with my recievers... Yes all my reciever are Spektrum's.... But I did buy acouple of orange spektrum recievers from HK, at $8.00 each why not...
To get back on track, I asked Horizons tech's also to have the throttle stick modded so that it will self center like the right stick... I will have it back in the next day or two... I have my dx3s ready to go if the sun breaks though here in rainy Ct.....
Joe
hotrodder is offline Find More Posts by hotrodder
Old May 17, 2011, 11:40 PM
thorsail is offline
Find More Posts by thorsail
thorsail's Avatar
Chicago , Illinois
Joined Jul 2008
Hi Joe
well,I will be surprised if you have any problems after this - based on my
own personal experience with Horizon, and from others I have talked to ,
their customer service is over the top - 5 stars.
The only time I ever experienced any bind issue's I considered it "my
fault" in that the power to the RX was low or the actual male plug was
suspect ( loose/damaged) off the batt pack or on/off switch.
question : I run a DX5e for my sailboats - does your DX6i also have in the
instructions the bit about the "range check" function like mine does ?
ie: after binding the RX to the TX, I have to walk 100 feet away, (with
everything powered up of course) and while holding the trainer toggle switch
one is supposed to then toggle the hi/lo rate switch 4 times - lights flash
and something beeps -tells me I am connected to the boat....I always
wondered if this was just for the DX5e or do the higher end units do this to?
2.4 ghz rocks !
Allan
thorsail is offline Find More Posts by thorsail
Old May 18, 2011, 09:25 AM
hotrodder's Avatar
Joined Jan 2007
Allan the dx6i has the range check function instructions to... Also the dx7 has them to... I think all of the spectrum units from Horizon probably has them also... It is always better to be safe than sorry....
Joe
Old May 18, 2011, 06:33 PM
Homeport is offline
Find More Posts by Homeport
United States, MA, Lowell
Joined Dec 2008
I have never had a problem with binding.
Throttle comes and goes when it feel like it, they told me to use a servo instead of a speed controler.
Homeport is offline Find More Posts by Homeport
Old May 20, 2011, 03:30 PM
hotrodder's Avatar
Joined Jan 2007
Got my dx6i back from Horizon today and gotta say that Horizon cusotmer service is top notched... I sent it back because the radio would not bind to my recievers anymore... I also asked them to make the throttle stick self center like the right stick... Horizon went though my radio and replaced all 4 digital trim actuator's, new RF board,gimbal t/r and a/e. All of this was done free of charge....
A big thanks to Tony S at Horizon ....
Joe
Old Aug 01, 2011, 05:45 PM
muscleflex is offline
Find More Posts by muscleflex
muscleflex's Avatar
Leeds, UK
Joined Nov 2004
hi - sorry to resurrect an old thread but how old was your dx6i when you returned it?
reason i'm asking is i just bought a 2nd hand DX6i as i am still saving up for a DX8 but the seller didn't tell me about a fault with the LCD - there's a line thru the LCD and i want to have the tx serviced and get the LCD repaired
muscleflex is offline Find More Posts by muscleflex
Old Aug 14, 2011, 02:00 AM
muscleflex's Avatar
Leeds, UK
Joined Nov 2004
got my tx back within a week (working day) and they didn't charge me.
they replaced the LCD and also one of the switch which looked a bit bent.
THANKS HORIZON/SPEKTRUM!!!
now i'm just thinking whether i have money for a DX8!
Sold Selling 2- spektrum ar7000 just back from horizon johnsheri Aircraft - General - Radio Equipment (FS/W) 1 Mar 23, 2011 06:30 AM
Sold DX6i - needs to be sent to Horizon weru Aircraft - General - Radio Equipment (FS/W) 3 Feb 16, 2011 08:54 PM
Discussion Got my UMX beast. not very extreme quality control should i sent it back? get dustd Electric Plane Talk 11 Jan 06, 2011 08:08 PM
sent my bcx back to horizon and 4u2catch Coaxial Helicopters 13 Dec 11, 2005 01:56 PM
Finally my BL lifted this Wireless cam /Tx and sent back these videos with sound!!!!! jas_Qfix Scratchbuilt Indoor and Micro Models 0 Aug 16, 2005 01:46 AM
