Hi all, thanks for the comments. Anyways, the gliders are made from roughly 1 lb density EPS. The fuselages are around 3/16" thick, hot wire cut "at the factory", whereas the wings and tails are bandsaw-cut to around 1/20" thick by yours truly. The fuselage profiles were cut on a laser at my school, but I had to cut the wings and tails w/ scissors because the laser is apparently too powerful for such thin foam.
The props are made of paper-each is made of a tiny paper square rolled into a tube for the hub, then the tube is glued transversely across the middle of a 1" by 1/4" paper strip for the blades. Once the glue dries, I twist the blades. The props spin on stripped twist-tie wires.
As far as weight and durability, etc... these planes probably weigh around .7 and 1.1 grams, respectively, but these are my best educated guesses w/o a scale to verify. I've made foamies w/ much lower wingloadings than these two, but they don't have all the cool spinny-things on them, and they are more delicate.
In my experience, the foam gliders in general are much more durable and forgiving of my clumsy handling vs built-up. The big disadvantage of these sorts of foamies is the poorer L/D, due to the rough surface finish and the excess porosity between the foam beads.
Oh, for those wanting pictures, I have hundreds, but you're going to have to stop the videos a lot to see them all
I'll see if I can get some decent pics up this weekend.
