Old Aug 01, 2011, 10:17 AM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
It's all good, Pont. As you say, there are different choices and people are free to choose. You've made it clear, though, that US customers have a cheaper option with clubheli. If they have to pay shipping again to get parts in a separate parcel, it may not be cheaper in the end, though.
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Aug 01, 2011, 02:43 PM
Palle_Plutt is offline
Find More Posts by Palle_Plutt
Kingdom of Sweden, Västra Götaland County, Lindome
Joined Jul 2011
Originally Posted by PitViperB1 View Post
Oh man I'm excited for you
Can't wait to hear your impressions.
Originally Posted by bobepine View Post
Mind me asking what that cost you?
Congrats on the new heli. Have fun!!!
My first session with this heli was in my small small garden(like an big livingroom) so it was only a hovering test.
It's more stable than an solo pro V2 left/right tail only turns dosen't move forward/backward.
It feels directly that this is an much heavier heli I dont mind that much to hover 20 cm from my self with SP V2 but with this it's a bit scary.
Price for this heli in my local hobby shop is 1199SEK ( Swedish krona) alot more than the prices mentioned here but not overpriced IMO for a swedish shop.
Palle_Plutt is offline Find More Posts by Palle_Plutt
Old Aug 02, 2011, 05:00 AM
Joined Jul 2011
Ok second impression.
Everything in rotorhead is very loosely assembled ie. mixer arms have some thing like 1mm play and only need 0.1mm to move freely.
Second fly session in an big open field.
First it feels like flying a NE Solo Pro Vx!
Then it started blowing and heli doesent have any FF so I can't fly direct against wind(only a light breeze 1-2m/s).
So I discovered that links was mounted on the short arms on swashplate and EPA adjustment is very narrow on that servo.
I moved links to long arms(ball) and got better forward motion.
I going to test to adjust EPA after my battery is charged.
Old Aug 02, 2011, 05:18 AM
helicopcat is offline
Find More Posts by helicopcat
helicopcat's Avatar
Joined Jan 2011
Does the TX have the dual rate switch? (pressing the stick). Perhaps this is the reason of the short servo movement (narrow endpoints).
Otherwise it seems to be set in factory for novice....
helicopcat is offline Find More Posts by helicopcat
Old Aug 02, 2011, 05:51 AM
Frank_fjs is offline
Find More Posts by Frank_fjs
2011 - Year of the clones!!!
Frank_fjs's Avatar
Australia, SA, Adelaide
Joined Nov 2010
Good to hear that EPA seems to be available, is subtrim and gyro gain present also?
Frank_fjs is offline Find More Posts by Frank_fjs
Old Aug 02, 2011, 06:08 AM
bobepine's Avatar
Joined Jun 2011
As far as I know, this heli doesn't have subtrim. Unless there is a different way to invoke it.
Site Sponsor
Old Aug 02, 2011, 07:12 AM
PitViperB1 is offline
Find More Posts by PitViperB1
Joined Jun 2008
That's exactly what I thought.
I thought that was a TX setting for indoor (aka novice) and outdoor.
PitViperB1 is offline Find More Posts by PitViperB1
Old Aug 02, 2011, 08:07 AM
Joined Jul 2011
Sorry to say: I can't find EPA adjustment.
Subtrim is there but I haven't tested gyro adjustment yet.
Tx is in mode 2 and in advanced mode (full circle).
Old Aug 02, 2011, 08:17 AM
bobepine's Avatar
Joined Jun 2011
1- Enter subtrim when your heli is powered up and see if the rudder responds. It should respond, contrary to the solo pro. This means the TX is in subtrim mode but the heli isn't.
2- Trim the aileron all the way to the left then enter subtrim. Trim as you need, then exit subtrim. Upon exiting subtrim, all your trims should be dead center. Power off the TX and power it back on. The aileron setting will be back to all the way to the left. Subtrim doesn't work for this heli and if you follow the above steps, this will make it clear to you. It appears to work untill you turn off the TX and turn it back on to find out that the trim settings are no longer centered but back to what they were before you entered subtrim mode. Try it and report back.
Site Sponsor
Old Aug 02, 2011, 10:16 AM
Joined Jul 2011
Hi
I have now tested twice with subtrim on tail rotor and it works.
1. Press button repededly listen for beep.
2. Adjust trim (marker in disp don't move) 10 clicks to right heli turns to right.
3. Press button lissen for beep.
4. Remove battery in heli.
5. Turn off TX.
6. Turn on TX.
7. Attach heli battery.
8. Try to fly heli still turns right with trims in center on display.
9. Enter subtrim.
10. Get heli to hover only with adjusting trim.
11. Same as 3. save subtrim.
12. Repeat steps 4 to 8 to verify.
You got an preproduction 328 from your neighbor didn't you?
Old Aug 02, 2011, 10:48 AM
Frank_fjs's Avatar
Joined Nov 2010
Hi
5. Turn off TX.
6. Turn on TX.
9. Enter subtrim.
Sweet! What about gyro gain? It would really make my day if this works.
Old Aug 02, 2011, 11:08 AM
Joined Jul 2011
Actually I noticed this behavior also.
But I still claims the subtrim function to work.
Also as you pointed out before tail works in subtrim mode that is two things that are different to the Solo Pro Vx that I have.
Old Aug 02, 2011, 11:14 AM
bobepine's Avatar
Joined Jun 2011
Hi
5. Turn off TX.
6. Turn on TX.
9. Enter subtrim.
OK, now I'm really confused. Off to try this again tomorrow and I will report my findings. I certainly hope that gyro gain and subtrim is available on this bird because I'm buying one next week.
Site Sponsor
Old Aug 02, 2011, 11:16 AM
bobepine's Avatar
Joined Jun 2011
Ha! OK, I think I'm right, then. Subtrim doesn't work because when the settings are back to what they were before, the heli behaves accordingly, hence, adjusting trim in subtrim mode is useless since you are back to square one when you turn off the TX and turn it back on.
PS: And you mentioned being unable to access EPA mode. This confirms my findings. I was also unable to invoke EPA mode.
Site Sponsor
Old Aug 02, 2011, 12:44 PM
Rick Hauler is offline
Find More Posts by Rick Hauler
ClubHeli.com
Rick Hauler's Avatar
Allentown, PA
Joined Mar 2009
Ok everybody...the 328A's have arrived, along with the parts. All preorders should have received an email. If you would like to add spare parts to your preorder, just place the order on the site and note it in the comment box "PLEASE SHIP WITH MY PREORDER". All helis will ship tomorrow, so please have your spare parts order in by 10am tomorrow morning. We will refund shipping costs applied to your parts order. Thanks for your patience!
Note - Rotor blades and cabins are still a week out or so....
2nd note - Remaining helicopter inventory will not be listed until preorders are shipped.
Rick Hauler is offline Find More Posts by Rick Hauler
Sold HobbyKing NIB Nine Eagles 260A Solo Pro V2 BNF Brosol Aircraft - Electric - Helis (FS/W) 3 Apr 14, 2011 06:43 PM
Discussion What do you all think of the Nine Eagles Solo Pro gaaunapoi Beginner Training Area (Heli-Electric) 10 Mar 31, 2011 10:56 PM
