Old May 17, 2011, 10:40 AM
joeyimscared is offline
Find More Posts by joeyimscared
Joined Jun 2007
Help!
Tower Pro BP-21 cutting out at full throttle
Hello all. I am helping a friend get started with a GWS Slow Stik. We got him a couple of 20 amp esc's and 3 cell 1200 mah lipos from RC Timer and a couple of BP-21's from Hobby King. When we rev the motors to full throttle under load (with a prop) they make a horrible screeching noise and cut out. Moving the throttle stick to the bottom resets the motor and it will turn on again. We purchased 3 motors and they all behave the same way. It only cuts out at full throttle. I have tried other esc and battery combos that are proven but the result remains the same. We checked all of our connections and even re-soldered a few to make sure we have solid connections, but no change. I have been flying electric planes since 2004 and I have never seen this problem before. Any suggestions? Did I just get a bad batch of motors from HK?
joeyimscared is offline Find More Posts by joeyimscared
Old May 17, 2011, 12:03 PM
wellington53 is offline
Find More Posts by wellington53
Glenn
wellington53's Avatar
United States, WI, Oconto Falls
Joined Jan 2004
Has the esc got a timing feature,
wellington53 is offline Find More Posts by wellington53
Old May 17, 2011, 12:32 PM
Lnagel is online now
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
The ESC is losing synch with the motor. If the ESC is programable then try changing the timing. Usually increasing timing cures this problem. If that doesn't help or if the the ESC cannot be programmed, then the only option is to use a smaller propeller.
Larry
Lnagel is online now Find More Posts by Lnagel
Old May 17, 2011, 02:05 PM
Joined Jun 2007
Larry
Many thanks Wellington53 and Larry. Sure enough my esc's default timing was set to low. Increasing it to medium solved the problem. I have never had a timing issue before, but now I know. Thanks again!
Scott
Question PHOENIX 45 Cutting Out at full throttle Jim Connell Castle Creations 3 Aug 12, 2003 04:22 PM
AC 1215/16 cutting out at full throttle JamesD Power Systems 4 Mar 08, 2003 10:08 PM
ZAGI 400-X ; power cutting out to motor after flying at full throttle Joe-z Foamies (Kits) 29 Jul 15, 2001 10:51 PM
