Espritmodel.com Heli Air
Old Aug 21, 2003, 05:33 PM
Joined Aug 2003
My Correx/coroplast Delta, need help
Built to an extact standard of a tried and tested plan.
My Correx Delta is well built and strong, I have decided to put a small engine in it but will this work???
Its a size 10 TT engine, like i said small as the standard engine size is around a 32,
Shall I put a larger engine in it? I would like to use the one I have,
Does anyone know any correx delta plan sites????
Does anyone know any good mods or great ideas??
thanx for any help
-eliot- UK
el_rwn is offline Find More Posts by el_rwn
Old Aug 22, 2003, 01:03 AM
All under control, Grommit!
leccyflyer's Avatar
NW England
Joined Sep 2000
Hi Eliot
Welcome to RC Groups
You should check out Morgan Wood's website at www.mugi.co.uk and also do a search for Mugi here on RC Groups. Morgan is a regular here and has a load of different mods and tips for Correx modelling.
I'll move this thread to the SPAD section of the site and you might get some other input there as well.
Good luck
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Aug 22, 2003, 10:09 AM
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
If it's designed for a 32, a 10 will not even keep it in the air after launch.
VP
Viper Pilot is offline Find More Posts by Viper Pilot
Old Aug 22, 2003, 01:36 PM
Tony Oliver's Avatar
North-East England
Joined Mar 2002
Post some details of the model please - span, weight, wing area and a photograph or layout drawing would help. If it's an established design, a website would also help.
Tony
Tony Oliver is offline Find More Posts by Tony Oliver
Old Aug 22, 2003, 04:24 PM
Joined Aug 2003
Good point.
30inch span, 19 inch chord etc.
Viper Pilot, your completely correct
I have now got a MDS 38 on it.....\
Thanx for the info, tonyo i'll stick a pic on here soon
-eliot-
Old Sep 16, 2003, 05:48 PM
lvspark's Avatar
Walla Walla
Joined May 2002
I used a .07 on a mugi delta 36"span x 18" cord. It did not have enough power for easy take-off, but once in the air, it flew fine.
With the .38, it will be fast (that is good) but, the wingloading will be very high (that is bad). P-factor on launch, reduced glide ration will yield many broken props.... Also with the .38 be sure to have high torque servos, and reinforced elevons.... You will need them!
Either way, it should be fun... good luck!
lvspark is offline Find More Posts by lvspark
My soldering skills suck. I need help coomarlin Electric Plane Talk 43 Jul 22, 2004 11:21 PM
Flyers in Dodge KS??? My brother in law need help thor4944 Electric Plane Talk 0 Feb 08, 2004 08:41 AM
Lost my wattage sukhoi today.Need help. j.d.roost Parkflyers 13 Aug 21, 2003 05:08 PM
Just got my first lithium charger...need help!!!What is a jumper? thor4944 Batteries and Chargers 4 Jun 28, 2003 07:50 PM
No!! Lost my tilde in the trees, need help. JStory Electric Plane Talk 19 May 10, 2002 09:56 PM
