Old May 17, 2011, 07:53 AM
sparks is offline
Find More Posts by sparks
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Build Log
Cartoon Jets 1 plan, Two planes, twice the fun!
There has been about 10 guys waiting for this thread and I'm sorry it took so long. I just can't release a design not knowing if it will fly.
The design has flown and is into my flight test program now.
The plans and plastic parts are on the website now if you want to build along as I lay out the thread.
www.parkflyerplastics.com
The cool part is when you buy the plans you are getting two versions of the same design a Cartoon Saber and a MIG.
For this reason you will need to buy the plastic parts separately.
This gives you and a buddy any combination of models to build.
On the site, go to short kits . . .kits with plans . .and you will find the plans with the plastic choices below them.
Better yet just punch in cartoon jets and the search box will take you to all your options.
sparks is offline Find More Posts by sparks
Old May 17, 2011, 07:54 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Because this thread is about two planes I'll be color coding the instructions.
Titles in black apply to both models
Titles in blue apply to the saber
Titles in red apply to the MIG
Old May 17, 2011, 07:55 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
what you will need
2 sheets of 3mm depron
1/8 sheet of 6mm depron
some 1/8 and 3/32 balsa 4"x 6" will be plenty.
card stock to make patterns one sheet of poster board will work.
Gorilla glue, the fast white stuff
2 micro servos
10 amp ESC
GWS 10x4 prop.
park flyer sized receiver
1800 KV motor or more
800 MAH three cell battery
Old May 17, 2011, 08:00 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
development
After building a fanfold 1/4 scale P-40 I needed a break and discovered Fatty planes.
(I'm going with Cartoon jets to prevent sensitivity problems.)
The concept model was small, about 20 inch span and a flat wing with a flying stab. It flew for about 15 seconds and crashed . . . .6 times! But I knew it could be done if I had lighter equipment or a larger model.
The prototype kicked my butt for about 4 months.
On the first test flight I did 5 ovals, 3 figure eights then turned it into the wind ( 3 mph) to climb for a shot at light aerobatics. It stalled when I pulled the nose up and the more I tried to push the nose over the worse the nose up attitude got. She floated to the ground wings level and pancaked on the belly with no damage. On the next attempt a bad hand launch broke the motor mount. I'll get into how to hand launch a fat plane later.
The motor I was using was a homemade CD Rom and two blade prop.
I rebuilt the nose and fitted the plane with a Tower pro out runner and three blade prop. Turns out that my little CD Rom motor was lighter and put out about as much thrust. I'd guess I tried to fly the plane 10 times , breaking props, patching Depron and changing CG in-between attempts.
It still pitched nose up and floated to the ground. I thought it was the shape of the exhaust nozzle so I broke the tail bonds to make it a straight tube. . . .no good.
The prototype was so beat up I salvaged the equipment for Saber #1.
There it sat in the shop garbage can waiting to be collected. But wait, it has one more mission. Verify the CG as a chuck glider. I taped up the nose packed in clay and went out into the yard. First try with a good push and it flew across the backyard and actually did a belly landing.
It was a thrust issue . . .not enough. A 1300 KV motor will not work.
Saber #1 was fitted with a stronger out runner and it did great.
Time to get out the paint!
Old May 17, 2011, 08:02 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
So.............. should I continue or wait a week or two for some of you to receive the plans?
I run very descriptive threads so you should be able to keep up.
Here are a few links to the others so you know I won't leave you hanging
P-40
http://www.rcgroups.com/forums/showthread.php?t=1287190
C-130
http://www.rcgroups.com/forums/showthread.php?t=1112544
757
http://www.rcgroups.com/forums/showthread.php?t=513835
B-58
http://www.rcgroups.com/forums/showthread.php?t=906009
Old May 17, 2011, 03:31 PM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Fantastic thread, looking forward to more posts
Andy
Aero Andy is offline Find More Posts by Aero Andy
Old May 17, 2011, 04:44 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
As I've said amny many times, 'Toons rule! This isa nice build, Sparks.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old May 17, 2011, 04:53 PM
GermanTigger is online now
Find More Posts by GermanTigger
GermanTigger's Avatar
Germany
Another must have
My "have to build" list gets longer and longer!?!?
Please keep posting more pictures?!?!
Toby
GermanTigger is online now Find More Posts by GermanTigger
Old May 17, 2011, 05:41 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
So let's build a cartoon Jet
You start with a 3mm depron tube. The best way to keep from screwing it up is to cut a corner off the sheet to see which direction the grain runs, yes there is a grain.
Roll the sheet around a paper tube or a 3 inch PVC pipe and wrap it with sandwich wrap or tape to hold it. Give it a day to set and when you release it, it will stay rolled.
Now would be a good time to make the patterns. Use spray adhesive to attach the patterns to a poster board and cut them out.
Place the sheet on the cutting table unrolled and put the pattern over it; use a sharp hobby knife to cut the fuselage tube and don't forget to make the marks for the wing placement.
Note the MIG has different cuts at the rear, the pattern is marked in red
Work steady and don't take a break. The foam is remembering what it's like to be flat the longer you take the flatter the sheet will get.
Old May 17, 2011, 05:43 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
First bond
Apply tape to the deep cuts to prevent them from trying to split while you are working.
Apply glue in-between the wing marks and tape them together. this is a straight bond and should be very easy. if you have to push the seam inward while you apply the tape so there is no pucker, you are looking for a nice round tube. let it dry completely.
Old May 17, 2011, 06:38 PM
Fuzzy711 is offline
Find More Posts by Fuzzy711
Fuzzy711's Avatar
USA, MA, Chicopee
Joined Apr 2010
Subscribed! and waiting
Fuzzy711 is offline Find More Posts by Fuzzy711
Old May 17, 2011, 06:56 PM
jeffsch is offline
Find More Posts by jeffsch
jeffsch's Avatar
Seattle, USA
Joined Oct 2009
Just got my kit in the mail yesterday. Really looking forward to the build!
jeffsch is offline Find More Posts by jeffsch
Old May 17, 2011, 09:40 PM
MPS86 is online now
Find More Posts by MPS86
MPS86's Avatar
United States, NY, Fairport
Joined Jan 2011
Subscribed put my order in tonight! Where do you guys get your depron sheets?
MPS86 is online now Find More Posts by MPS86
Old May 17, 2011, 09:56 PM
Wilfor is online now
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
I think most order Depron from http://rcfoam.com/
Some hobby shops have it as well
Wilfor is online now Find More Posts by Wilfor
Old May 18, 2011, 01:31 AM
ExPat
Aero Andy's Avatar
Joined Apr 2010
Sparks, it's looking good already
Andy
Discussion Fun fun fly planes... Evan D 3D / Fun Fly Fuel Planes 2 May 26, 2011 09:54 AM
Discussion Twice in one day, two planes "fell'?? sgomes Electric Plane Talk 18 Jun 29, 2010 02:50 AM
Fun Flier "blue Two" plan happy flier The Builders Workshop 0 Jul 01, 2004 09:57 AM
Fun Flier Plan (blue Two) happy flier 1/2A Planes 0 Jul 01, 2004 09:54 AM
