Old May 16, 2011, 07:54 PM
Rctestflight is offline
Find More Posts by Rctestflight
Rctestflight's Avatar
United States, UT, Park City
Joined Sep 2009
Motor KV Relative to Stableness
Hello,
Just got a quick question:
Are higher KV motors or lower KV motors more stable for aerial video on a quadcopter?
Rctestflight is offline Find More Posts by Rctestflight
Old May 16, 2011, 10:12 PM
mbsteed is offline
Find More Posts by mbsteed
Multicopter AP centric
mbsteed's Avatar
Canada, AB
Joined Jan 2011
Most folks go with kvs between 750 - 1400. There is some indication that the lower the Kv work better with the larger props and the higher kv work better with the smaller props. At least that is what I have gleaned from forums. Others can chime in on this with more technical replies. For instance my Gaui uses 8 inches props with 1400 kv motors. 750 kv motors are often setup with props 10-14 inches depending the power of the motor.
It also depends on how you want to fly the quad - the slower kv range seems to be used more for AP purposes while the higher kv are more sport.
mbsteed is offline Find More Posts by mbsteed
Old May 17, 2011, 01:49 AM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
lower kv better run times higher kv better stability ive found so far
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Found ElectriFly RimFire 28-30-950 kV motor fairplane Aircraft - Electric - Power Systems (FS/W) 1 Apr 27, 2011 06:52 PM
Sold NIB Dualsky XM3536CA-8T 990 kv Motor (.10 to .15 class motor) The Don Aircraft - Electric - Power Systems (FS/W) 1 Apr 24, 2011 10:56 PM
Discussion Recommendations for kv motor GPV-1 Silone74 Motorcycles 35 Apr 13, 2011 01:09 PM
Help! Number of poles in the Hyperion 5800 KV 12 mm motor ? cyclops2 Micro EDF Jets and Power Systems 15 Mar 09, 2011 01:49 PM
Sold Mega 16/7/7 2450 Kv brushless motor - $50 shipped CONUS SPasierb Aircraft - Electric - Power Systems (FS/W) 0 Mar 07, 2011 08:17 AM
