Old May 16, 2011, 02:05 PM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Question
Mercon ATF as after-run oil?
An experienced flyer at my LHS recommended the use of Mercon automatic transmission fluid as a cost-effective substitute for after-run oil. Anyone else do this?
Cheers,
JD.
grosbeak is offline Find More Posts by grosbeak
Old May 16, 2011, 04:02 PM
garciaj is offline
Find More Posts by garciaj
United States, KS, McPherson
Joined Apr 2011
I would say no, i say this because there is alot more detergents in ATF then even standard oil. yes its like an oil but my personal opinion is not to. ask your self this will oil eat through a car floor if it sits there long enough, no. Will ATF, Yes.
just as im against totally cleaning the motors and taking out all the burt oil off inside, that helps it seal properly like when you break them in.
garciaj is offline Find More Posts by garciaj
Old May 16, 2011, 04:57 PM
Phoenix51 is offline
Find More Posts by Phoenix51
Phoenix51's Avatar
USA, OK, Locust Grove
Joined Jul 2010
ATF is fine in your engines as long as it is not type F. Type F has friction additives in it for older Ford transmissions.
Phoenix51 is offline Find More Posts by Phoenix51
Old May 17, 2011, 09:56 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Marvel Mystery Oil is NOT air tool oil. And it will gum up after a while.
Marvel Air Tool Oil is a great after run oil. As is ATF.
Pinecone is offline Find More Posts by Pinecone
Old May 17, 2011, 12:02 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Most ATF's, any or the air tool oils and Rislone (in the yellow container) make excellent after run oils. Marvel Mystery oil, sewing machine oil and gun oil do not do a good job as they are to thin but are better than nothing. Marvel Mystery Air Tool oil is okay. Definitely do NOT use WD40 as an After Run Oil as, if any rust is present, it will release enough of it to make a nice lapping compound inside your engine the next time you run it to accelerate the wear and tear.
Rodney is offline Find More Posts by Rodney
Old May 17, 2011, 11:17 PM
n00b-E is offline
Find More Posts by n00b-E
n00b-E's Avatar
Joined Sep 2007
What I use for ARO:
The original Zoomspout Oiler is filled with 4 ounces of ConocoPhillips/Unocal 76 Turbine Oil- a superior general-purpose lubricating oil. A flexible, telescoping, non-conductive plastic spout extends from 7" to 13".
n00b-E is offline Find More Posts by n00b-E
After Run Oil rabosr Fuel Plane Talk 28 Jun 12, 2015 03:44 AM
