This thread is privately moderated by leccyflyer, who may elect to delete unwanted replies.
Old May 16, 2011, 11:03 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
BC#044 -Embraer Tucano
Aircraft Name: Embraer Tucano
Manufacturer/Designer: BVR Models Nigel Hawes
Type: Electric sports scale
Construction: Built up balsa fuselage, sheet balsa wing and sheet balsa tail
First Flight: Warrington Model Club, 26th April 2010
Wing Span: 48"
Wing area:
AUW:
Power type - Electric
Motor: AXI 2820/10
ESC: Jeti ADvance Plus 40-3P
Tank/Battery:3s1p4500ah Loong Max Tipple Lipos
Propeller: Master Airscrew Wood electric
Receiver: Spektrum AR500
Flight Pack: BEC
Servos: Elevator (balsa/wire pushrod) -HS85MG Rudder (balsa/wire pushrod) - HS81 Ailerons - (torque rods) HS81
Throws -
Undercarriage - Fixed piano wire as supplied
Accessories: Vortex Plastics cockpit and pilots
Covering: Tissue and dope, sprayed with enamels.
Current status: In service
RC Groups thread: http://www.rcgroups.com/forums/showt...o#post15166400
leccyflyer is offline Find More Posts by leccyflyer
Build Log NitroPlanes Embraer Tucano ScaleBrad Glow to Electric Conversions 64 Dec 23, 2012 04:17 PM
Question Embraer Tucano or Shorts Tucano mamethot Scale Fuel Planes 3 Aug 13, 2007 05:07 AM
Embraer TUCANO 312F from CAM TGSN Slope 8 Feb 08, 2005 01:39 PM
FS: Embraer Tucano ARF NIB gouda Aircraft - Electric - Airplanes (FS/W) 4 Jan 18, 2005 09:28 PM
FS/T: Het Embraer Tucano, typhoon 6/20 & aluminum spinner SeanJ Aircraft - Electric - Airplanes (FS/W) 11 Jan 17, 2005 02:21 AM
