Old May 16, 2011, 04:48 AM
BaZsiX is offline
Find More Posts by BaZsiX
Homo Modelicus
BaZsiX's Avatar
Hungary
Joined Jan 2005
Build Log
Peter Rakes's DFW-C.V 2nd prototype
Hi all,
I'm the second builder of this prototype. I received the package two weeks ago but I opened it just in the last week.
So my "mission" is only that I have to build this model as there is on the plan. I'm in the finish with my Horvath's monoplane so I had time to start paralel this build. Csherman introduced this airplane in his Build Log, so I skip the intruduction of the type. I will build the covered engine version. And I've chosen this painting scheme below.
..in medias res...
I started the assembly with the lower wings. The construction went fast. I bought four sets of 3x6 and 3x5 pinewood for the spars instead of brass because it is not available here. I sanded down the connection points then I assambled the outer rings. In the next step I have to enlarge the rear spar hole because the 3x5 pinewood was a little bit larger than the recommended 1/8x3/16. I had "problem" only with the R6B ribs. I tapered the end of the spar but it wasn't enough so I had to cut out a small piece from the spar. The front of these spars also wasn't fit. Anyway I resolved these problems fast. I lenghtened the locating dovels to the R2B rib. I think this will be stronger. I covered the top of the R1B and R2B with 1,5 balsa. finally I fixed the leading edge.
The construction of the upper wings was the same. Today I will glue into the ribs.
Balazs
BaZsiX is offline Find More Posts by BaZsiX
Old May 16, 2011, 02:34 PM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
Wow, side by side prototype builds, should be good to see different approaches to the build. Will be tagging along for the ride.
Craig
trumps is offline Find More Posts by trumps
Old May 16, 2011, 03:07 PM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Balazs,
Coming along nicely, although the wings would be a lot stronger with leading edges. Sorry, sometimes I just can't help myself.
It will be nice to compare the different approaches to the same model.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old May 17, 2011, 03:52 AM
BaZsiX is offline
Homo Modelicus
BaZsiX's Avatar
Hungary
Joined Jan 2005
It was funny Pete
Yesterday I assembled almost the entire upper wings. Only the two ailerons and the leading edges remains for today.
The parts of the the upper wing was perfect and fitted well.
The trailing edges of the lower wing was a little smaller than the plan (1-1.5mm). I think this type of wood shrinks during the laser cut.
Balazs
Old May 17, 2011, 06:15 AM
Norfolk, England
Joined Sep 2001
Balazs,
It's the sharp angles at the end that cause that. Not much that can be done about it I'm afraid - other than cut the parts by hand. Even then, there's no guarantee of greater accuracy.
Pete
Old May 17, 2011, 06:32 AM
BaZsiX is offline
Homo Modelicus
BaZsiX's Avatar
Hungary
Joined Jan 2005
Pete,
I understand this and don't worry about this it's a small thing, not a major problem. Both trailing edge are the same sized.
Balazs
Old May 17, 2011, 01:44 PM
BaZsiX is offline
Homo Modelicus
BaZsiX's Avatar
Hungary
Joined Jan 2005
Today I've finished the upper wings. After both dry, will be ready to sand + the lower two. Every parts fit perfectly!
Last friday I started the assembly with the fuse. I constructed only the two sides (with inner plates) and the main front frame. Now I will continue the build with the fuse.
Balazs
Old May 18, 2011, 02:45 PM
BaZsiX is offline
Homo Modelicus
BaZsiX's Avatar
Hungary
Joined Jan 2005
A little update.
Pete I modified a little on the side of the fuselage. I shifted up with 1,5mm of the bottom (1,5x3mm) strips and I glued some cross strips between the sides. The long strip and the cross strips will hold the bottom sheet. What do you think?
I have to fill with balsa block between the fuse frame F5 and F7?
Balazs
Old May 18, 2011, 05:09 PM
Norfolk, England
Joined Sep 2001
Balazs,
Okay on the fuselage mod, but watch the weight of the sheet you use. Moving the longerons up was a good move, but I think the cross braces just add weight where you don't want it. Since the bottom sheet is supposed to go in with the grain across the fuselage, I don't see that the braces serve much purpose.
Why would you add block between those formers? Or do you mean around the gun ring? If so, see what I said about that in the other thread. It's supposed to be sheeted, and I'm sure it can be sheeted if you're careful. However, if you're happier adding block, and hollowing out the resulting shapes, go that route. I feel there's already more than enough weight at the rear, without adding to it.
It's a fairly small model, so weight is always going to be the enemy.
Pete
Old May 19, 2011, 12:56 AM
BaZsiX is offline
Homo Modelicus
BaZsiX's Avatar
Hungary
Joined Jan 2005
Pete,
The weight of the cross braces was approximately 1g. Maximum. I used light 3mm sheet. It helped me to made a square shape fuse. Yesterday I made a template bottom sheet. I made it from one piece and from light 1.5mm balsa sheet. I could easily bend and was strong but it wasn’t grain across. You suggest to me that I make the bottom from three or four grain cross sheets?
Yes I mean around the gun ring. But I think you are right it is possible to make it from sheet. I will make a template today afternoon.
Thanks!
Balazs
Old May 19, 2011, 02:22 AM
Norfolk, England
Joined Sep 2001
It's stronger with the lower sheeting cross grain, but it's up to you. Your cross braces should take the crushing loads caused by handling.
Pete
Old May 19, 2011, 02:27 AM
BaZsiX is offline
Homo Modelicus
BaZsiX's Avatar
Hungary
Joined Jan 2005
Yes I can agree with you (about the crushing loads).
Will you modify the plan (moving the longerons up)?
Balazs
Old May 19, 2011, 03:18 PM
BaZsiX is offline
Homo Modelicus
BaZsiX's Avatar
Hungary
Joined Jan 2005
Observer cockpit.
Sorry Pete but this was the max what I was able to bring out from this with my experience. This was your concept? Tomorrow after the paste dry I will send down the overflow.
Balazs
Old May 19, 2011, 07:34 PM
Norfolk, England
Joined Sep 2001
No, that's not the shape it should be at all. It should be moulded around the gun ring, and over the formers. There is a section shown on the plan, indicating that the sides are vertical between the top of the fuselage side and the gun ring. I deliberately made the gun ring in two parts so the sheeting could be moulded to the first part, the one with the tabs, and the final gun ring glued on after any filling/sanding was done.
I mentioned making the sheet sections that much longer than you've used to allow that moulding to shape - and the use of paper patterns to get the shape right.
If you imagine using filler to blend the circle of the gun ring into what you have there, you need much more than you've used because it all has to blend smoothly from that first ring to the formers either side to simulate the moulded ply decking of the original.
Pete
Old May 19, 2011, 10:02 PM
MerlinV is offline
Find More Posts by MerlinV
Melbourne, Australia
Joined Mar 2009
I found this image on Google. It's not an easy feature to see in any picture I can find.
Hugh
MerlinV is offline Find More Posts by MerlinV
Build Log Peter Rake's 44" DFW-CV csherman Scale Kit/Scratch Built 100 Feb 12, 2014 03:22 PM
Build Log Curtiss wright 2nd prototype classicaero Scale Kit/Scratch Built 117 Dec 30, 2011 03:38 AM
Build Log Peter Rakes IPS Pfalz E1 prototype build highace1 Scale Kit/Scratch Built 62 Jan 28, 2008 05:49 AM
Peter Rakes "Sopwith Tri-Plane" Robert Hoffman Scale Kit/Scratch Built 465 Apr 01, 2005 07:03 PM
Peter Rakes SE5A design Philip Thulin Scale Kit/Scratch Built 2 Mar 07, 2003 10:55 AM
