Old May 15, 2011, 09:35 PM
Donald Rose is offline
Find More Posts by Donald Rose
Joined Dec 2006
Help!
Arduino Pro Mini 328-5V/16MHz
My pro Mini does not flash the green LED rapidly after I upload the the MultiWii_1_6.pde. Also, I can not start the configurator screen in the MultiConif_1_6 I thimk these problems are associated with the port settings in my Windows XP computer. I set the bit rate at 115200 bits/sec, but that didn't help. Can anyone tell me what other port settings I should use?
I am using a SparhFun DEV-10008 breakout board and a USB cable from the Pro Mini to the Windows computer.
Donald Rose is offline Find More Posts by Donald Rose
Old May 15, 2011, 09:41 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Can you load the blink sketch?
If you get that working then you need at least 1.7final code version.
RCvertt is offline Find More Posts by RCvertt
Old May 15, 2011, 10:51 PM
Joined Dec 2006
Rvertt
I can load the blink O.K. and it works. When I try to start the confirurator in the MultiConif_1_6, the breakout board keeps blinking red and doesn't stop. Also the tricopter y image doesn't come onto the screen. I understood that the 1.6 version was more reliable that the 1.7 at this time.
Old May 15, 2011, 10:57 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Rvertt
Don't know. I only played with 1.7pre and MultiWiiV1_7 with no problems.
Discussion 5.5 īnch arduino pro mini mini michel pet Multirotor Talk 2 Apr 15, 2011 10:58 AM
Discussion Arduino Pro Mini servo controller cdi3d Multirotor Talk 5 Apr 03, 2011 10:59 AM
Help! Need help making adapter board Arduino Pro Mini/FF IMU Edwardo5000 Multirotor Talk 7 Mar 24, 2011 03:04 PM
Question Wemotec Mini Pro...spinner required? FNFAL Electric Ducted Fan Jet Talk 9 Mar 11, 2011 06:58 AM
Help! Arduino pro mini - 3.3v or 5v termhn Multirotor Talk 4 Jan 11, 2011 08:05 AM
