Old May 15, 2011, 08:25 PM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
Mini-Review
Turbo Ace 915 V2 9g Motor with Pictures, Video, Flight Tests, and Thrust Tests
Tom Z is offline Find More Posts by Tom Z
Old May 16, 2011, 01:38 PM
dbennettya is offline
Find More Posts by dbennettya
Joined Apr 2009
Tom,
Nice write up. However with these micros it is all about weight to thrust ratio and not RPM at 0* pitch. For example on my 4G6 with HP08 rewind 4 turns 4 strands 32AWG delta does 250 grams of thrust with a 12T pinion and is 18,680kv. That is +2Gs of thrust and it moves like a rocket.
You may find that with even a smaller pinion your TA915 will give higher thrust at 12* pitch. No one has measured the thrust capability of the TA915 so far so we have no comparison.
Good Luck, Don
dbennettya is offline Find More Posts by dbennettya
Old May 16, 2011, 05:18 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Hi Don,
Thanks.
We always see on the threads about the highest head speed possible
needed for 3D but I see thrust to be important also. What good is say 4,500 RPM
without enough thrust. That is what seemed to be the problem with the weaker HP08 motors. High head speed but not enough torque.
Your HP08 rewind sounds very powerful.
How did you measure your thrust?
If this is something I can do? If so I will measure thrust and add it to the review.
Tom
Old May 16, 2011, 08:23 PM
Joined Apr 2009
Tom,
I just use a scale and put a fairly heavy book or object on it and strap the heli to the book and scale. This way the scale doesn't take off on positive thrust Then with the heli, battery, book and scale just zero the scale and your ready to go. One thing is don't do full thrust for very long as it is hard on the batteries and they will droop a lot plus things might want to heat up. So just long enough to get a good reading. My rewinds do 250 grams and the strong 2S units have done 300 grams but figuring in the weight difference is what counts. You will need the highest C rating batteries you can get to get good numbers.
Good Luck, Don
Old May 17, 2011, 06:58 AM
Alwayscrash is offline
Find More Posts by Alwayscrash
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
Originally Posted by Tom Z View Post
Hi Don,
Thanks.
Tom
Take a look here:
http://benmlee.com/V120D02_Setup.htm
Alwayscrash is offline Find More Posts by Alwayscrash
Old May 17, 2011, 07:33 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Thanks Don and Alwayscrash!
I will give it a try.
I also found this.
HOW TO MEASURE THRUST OF MICRO HELI AS 4#3 (0 min 17 sec)
Tom
Old May 17, 2011, 08:38 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Thrust Test
I just did a thrust test for the Turbo Ace 915 14T w/XP-12A Version 2 ESC
and the Eflight Blade mCPX.
See the "Thrust Test" section in my review and the pictures.
Tom
Old May 18, 2011, 10:12 AM
chevell is offline
Find More Posts by chevell
chevell's Avatar
USA, CA, San Diego
Joined Oct 2007
Thanks Tom I was wondering about the thrust numbers on these outrunners.
I wonder if using a smaller gear would make the thrust numbers go up as Dbennettya suggested.
I get better head speeds using the 900mah 25C's.
chevell is offline Find More Posts by chevell
Old May 18, 2011, 11:40 AM
jonferran is offline
Find More Posts by jonferran
San Francisco, CA
Joined Feb 2004
Wow Tom, what a tease :P
From the title I thought you put that 9g motor in the mcpx. You need to do that next, k? thx. 8)
Jon
jonferran is offline Find More Posts by jonferran
Old May 18, 2011, 11:52 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Jon,
That would be great! It would have so much torque and head speed
the heli would probably explode!
The best outrunner motor I have seen for the mCPX is the Turbo Ace 4.5g outrunner motor. Very light and powerful.
I do have one here. Hmmm.....
Tom
Old May 18, 2011, 11:55 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Your welcome.
I may test a 12T for Dbennettya to get the thrust, head speed, and flight time for it.
Funny how I got more thrust with the 22C battery then I did with the 25C battery.
Tom
Old May 18, 2011, 12:01 PM
Joined Apr 2009
Not too suprising as 0.5 x 25 = 12.5A and 0.6 x 22 = 13.2A so the 22C probably has lower internal impedance.
Don
Your welcome.
Tom
Old May 18, 2011, 12:26 PM
San Francisco, CA
Joined Feb 2004
Jon,
Tom
Go for it! I am using an AEO 4.6g outrunner and it is a BEAST. Reduced weight + more power =
Old May 18, 2011, 12:35 PM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Jon,
Tom
Just saw your post and video on it, awesome!
Now you got me thinking to try it also...
Tom
Old May 19, 2011, 06:31 AM
Joined Sep 2009
RC Motor Wooden Pulling Power Testing Station
Found this on r2hobbies :
http://www.r2hobbies.com/eng/proddet...ting%20Station
AC
Sold Walkera 4#6 with extras! Turbo Ace brushless!!Like new! tc3wins Aircraft - Electric - Helis (FS/W) 1 Apr 25, 2011 02:48 PM
Sold Walkera 4#6 with extras! Turbo Ace brushless!! tc3wins Aircraft - Electric - Helis (FS/W) 0 Apr 16, 2011 01:26 PM
Sold turbo ace 411516 c05 brushless helizrnew2me Aircraft - Electric - Helis (FS/W) 2 Mar 17, 2011 05:56 PM
Discussion Turbo Ace 915 vronny Micro Helis 0 Mar 17, 2011 01:08 PM
Discussion Xaircraft x650 or Turbo Ace x720? lionSpirit Multirotor Talk 4 Mar 12, 2011 11:58 AM
