This thread is privately moderated by cass3825, who may elect to delete unwanted replies.
Old May 14, 2011, 06:39 PM
Joined Feb 2005
Universal VTOL MultiWii code
Servo speed and stretching options added for all servo channels. Settings just below I2C speed selection. Servo pin assignments will need to be commented/uncommented depending on your pin usage.
EDIT: Revisions made based on first successful transition flights.
cass3825 is offline Find More Posts by cass3825
Old May 14, 2011, 09:00 PM
RCvertt's Avatar
Joined Aug 2007
That is pretty cool. I think I have plenty to get started with now, but if you want to keep busy read on...
If I understand it, this turns on stretching or slow for all 5 pins at the same time. Is there a way to have stretching and or slow on specific pins instead of all 5 pins on or off at the same time? The stretched signal still seams really smooth so maybe this isn't needed but the option might be good for testing.
At some point we might want to play with turning the accel on or off during flight. Is there an easy way to do that. I'm thinking the accel might be off during forward flight with just the gyros helping out with the control surfaces then we'll want the accel back on during hovering.
RCvertt is offline Find More Posts by RCvertt
Old May 15, 2011, 02:25 AM
VTOLicious's Avatar
Austria
Joined Oct 2007
MultiWii Paris V3
Hi Billy,
I have a Tricopter-Tiltrotor VTOL project waiting for a capable flight controller and pleased to see someone coming up with a special code for such applications
I already have a standard Tricopter with a PARIS v3.0 Aerial Photography/LLC/BMA180 - MultiWiiCopter board http://www.multiwiicopter.com/collec...rd-plug-n-play
Do you think your VTOL-code will work with this board?
Thanks, Michael
VTOLicious is offline Find More Posts by VTOLicious
Old May 17, 2011, 10:01 PM
Joined Feb 2005
All servos are individually stretchable and/or can be slowed individually.
Originally Posted by VTOLicious View Post
Hi Billy,
Thanks, Michael
I believe it should work! Special attention needs to be paid to the pin assignments. Let me know via PM if you need help with this.
Old Oct 05, 2011, 08:30 AM
Joined Sep 2011
ardupilot mega with IMU
Hi Billy,
Great Job...!!!
I'm from Malaysia and still learning programming..try to understand the code.
I have ardupilot mega + ardupilot IMU shield.
Could you help to modified arducopter code from tricopter to VTOL plane?
I plan to tilt 2 front motor for direct flight and turn off tail motor
thanks
Tasfin
mt67 is offline Find More Posts by mt67
New Product 6DOF 10DOF 11DOF IMU All In ONE+ MCU and ALL in ONE II with GPS and sensors CSG_EU Multirotor Talk 114 Nov 14, 2012 01:26 PM
Build Log Universal Hovercraft UHM-30. Scratchbuilt, single motor, ducted lift. Miskatonic RC Hovercraft 28 May 20, 2011 12:00 AM
Discussion Calibrating ESC's using multiwii code mstanescu Multirotor Talk 0 Mar 11, 2011 02:37 AM
Cool The UNIVERSAL Online Code Configurator for Arduinos kinderkram Multirotor Talk 83 Feb 17, 2011 11:44 AM
