This thread is privately moderated by CrashingDutchman, who may elect to delete unwanted replies.
Old Oct 04, 2011, 07:14 PM
tanner.jon is offline
Find More Posts by tanner.jon
Joined Sep 2011
Buddy Links!
I just made a substantial purchase on HobbyKing.com - Check out my buddy links below:
  1. XH Adapter Coversion Board W/ Polyquest Char - http://www.hobbyking.com/buddy.asp?c...C-7560E2F5E600
  2. 3.17mm Prop Saver w/ Adapter & 3 bands - http://www.hobbyking.com/buddy.asp?c...6-B51C3878F566
  3. USB Simulator Cable RealFlight G4.5 - http://www.hobbyking.com/buddy.asp?c...E-890838AC7930
  4. 25A 14v DC Power Supply for Chargers (350W) - http://www.hobbyking.com/buddy.asp?c...3-012FE3CB5B62
  5. Turnigy 1000mAh 3S 30C Lipo Pack - http://www.hobbyking.com/buddy.asp?c...5-CFC77DEF28CF
  6. Turnigy 2mm Heat Shrink Tube - BLACK (1mtr) - http://www.hobbyking.com/buddy.asp?c...4-1AB9EEBE92E7
  7. Turnigy 3mm Heat Shrink Tube - BLACK (1mtr) - http://www.hobbyking.com/buddy.asp?c...B-F061BFE07EC7
  8. 3.5mm 3 wire Bullet-connector for motor (5pa - http://www.hobbyking.com/buddy.asp?c...A-84C51A558A84
  9. Turnigy 4mm Heat Shrink Tube - BLACK (1mtr) - http://www.hobbyking.com/buddy.asp?c...9-FC03356A8358
  10. X-BLADE Precision knife with replaceable SK- - http://www.hobbyking.com/buddy.asp?c...3-8809F5A6D0ED
  11. X-BLADE Spare SK-5 Steel blades (10pcs/set) - http://www.hobbyking.com/buddy.asp?c...4-7EC96C070B6B
  12. Turnigy 6mm Heat Shrink Tube - RED (1 - http://www.hobbyking.com/buddy.asp?c...D-AE7CB9BBCA83
  13. Turnigy 5mm Heat Shrink Tube - RED (1 - http://www.hobbyking.com/buddy.asp?c...0-510B6FA052EF
  14. Turnigy 4mm Heat Shrink Tube - RED (1 - http://www.hobbyking.com/buddy.asp?c...7-F64522A74A81
  15. Turnigy 3mm Heat Shrink Tube - RED (1 - http://www.hobbyking.com/buddy.asp?c...6-825F7D408915
  16. Turnigy 2mm Heat Shrink Tube - RED (1 - http://www.hobbyking.com/buddy.asp?c...C-6046CCA8435C
  17. Turnigy 6mm Heat Shrink Tube - BLACK (1mtr) - http://www.hobbyking.com/buddy.asp?c...E-30BC1618828E
  18. Turnigy 5mm Heat Shrink Tube - BLACK (1mtr) - http://www.hobbyking.com/buddy.asp?c...7-AFC807D6F316
  19. TURNIGY Transmitter Strap - http://www.hobbyking.com/buddy.asp?c...0-955AFBF28FFA
  20. Hands free small item holder - http://www.hobbyking.com/buddy.asp?c...2-86E821F4BA39
Hope this helps someone out.
tanner.jon is offline Find More Posts by tanner.jon
Old Oct 05, 2011, 09:18 AM
CrashingDutchman is offline
Find More Posts by CrashingDutchman
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
Did you post them on my buddy code collection site? See: http://hk.rc-international.info/swarm
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Oct 11, 2011, 05:55 AM
MarkAurel is offline
Find More Posts by MarkAurel
Slovakia, Banská Bystrica Region, Veľkı Krtíš
Joined Jan 2011
Turnigy AE-25A Brushless ESC
http://www.hobbyking.com/buddy.asp?c...C-964294F24DE8
8x4 Propellers (5Pcs/Bag)
http://www.hobbyking.com/buddy.asp?c...4-922A1A73BC49
HobbyKing 4-6min Epoxy Glue
http://www.hobbyking.com/buddy.asp?c...5-4958A5C7C603
ZIPPY Flightmax 1300mAh 3S1P 20C
http://www.hobbyking.com/buddy.asp?c...6-3B3C982C4CDE
Turnigy Mini Servo 16g/2.1kg/.11sec
http://www.hobbyking.com/buddy.asp?c...8-D6C5B3AE4F9E
Hobby King Discovery Buzzer
http://www.hobbyking.com/buddy.asp?c...F-E9625AC5C989
HXT Alloy Composite Stick Mount 20mm
http://www.hobbyking.com/buddy.asp?c...4-FE49D28A092E
SF E-Prop 7x4 / 178x102mm w/ Adapters Black
http://www.hobbyking.com/buddy.asp?c...C-1D5D68FA9EB0
Pin Horns L22xW19xH.9 (10sets)
http://www.hobbyking.com/buddy.asp?c...C-86BA7D87B05C
9x5 Propellers (5Pcs/Bag)
http://www.hobbyking.com/buddy.asp?c...1-F3BA7155D2FC
Carbon Fiber Rod (solid) 2.0x750mm
http://www.hobbyking.com/buddy.asp?c...A-EA3154BB194D
http://www.hobbyking.com/buddy.asp?c...E-934A10CCF255
High stength fiber tape 20mm x 50mtr
http://www.hobbyking.com/buddy.asp?c...0-703EBCC70AC2
MarkAurel is offline Find More Posts by MarkAurel
Old Oct 17, 2011, 04:36 PM
Danne76 is offline
Find More Posts by Danne76
Joined Oct 2011
Find my codes here: http://hk.rc-international.info/swarm/daniel (valid until October 23, 2011)
Danne76 is offline Find More Posts by Danne76
Old Oct 28, 2011, 10:03 AM
chees070 is offline
Find More Posts by chees070
Joined Dec 2007
2 codes
zippy flightmax 3s 25c for 5.06 dollar
http://www.hobbyking.com/buddy.asp?c...A-4397EDA5BBA4
2mm gold bullet connectors for $1.32
http://www.hobbyking.com/buddy.asp?c...3-410C0026DCCD
regards
chees070 is offline Find More Posts by chees070
Old Oct 29, 2011, 12:10 AM
Tstubbs is offline
Find More Posts by Tstubbs
FFF CRASH ANALYST
Tstubbs's Avatar
United States, TX, Venus
Joined Aug 2011
70mm foam wheels 5pc
http://www.hobbyking.com/buddy.asp?c...6-77EF7871777C
tail (nose) wheel assembly
http://www.hobbyking.com/buddy.asp?c...F-5748C8B210CD
pinned nylon hinges
http://www.hobbyking.com/buddy.asp?c...5-17D02ED3245B
18-20A HK SS ESC
http://www.hobbyking.com/buddy.asp?c...3-52AABB81BAE5
turnegy metal gear small servo
http://www.hobbyking.com/buddy.asp?c...9-6699D84E0CB6
3.5mm connectors
http://www.hobbyking.com/buddy.asp?c...7-1F03663365C7
3 blade props
http://www.hobbyking.com/buddy.asp?c...B-8ED721F14365
gws ultralight wheels
http://www.hobbyking.com/buddy.asp?c...B-040BFD490543
I like the idea of sharing the buddy codes, but the search function doesn't work on your site, and the categories are not working either
Tstubbs is offline Find More Posts by Tstubbs
Old Oct 29, 2011, 04:24 AM
If you mean the search function and categories on the right side of the page, then you are correct. These are only for the home page of the site (Hobbyking regional warehouses categorized instead of all items for a warehouse mixed on couple of pages as Hobbyking has it now) . Buddy code products are not (yet) categorized.
There is a working search function just above the list with buddy codes on the available buddy codes tab. If you think that one doesn't work, then let me know what you are searching for and I will check for you.
Old Oct 30, 2011, 07:55 PM
Fantam is offline
Find More Posts by Fantam
Go Leafs Go!
Fantam's Avatar
Georgetown,ON,Canada
Joined Jan 2002
How to you redeem buddy points that you may have earned? I don't see anything on the HK site when I log in.
Fantam is offline Find More Posts by Fantam
Old Oct 31, 2011, 03:01 AM
If the products you bought are eligible for buddy code points, then you can find the buddy codes in your account page -> order details. See this: http://www.rc-international.info/Blo...explained.aspx
Old Nov 05, 2011, 12:45 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
BL EDF 40mm 8400 KV:
http://www.hobbyking.com/buddy.asp?c...E-8B4428BC361C
turnigy 3000mah 20C 3s lipo battery:
http://www.hobbyking.com/buddy.asp?c...0-CFE0EE852ED0
Trailing link Oleo:
Turnigy 25-30A BL esc:
http://www.hobbyking.com/buddy.asp?c...A-89F8A34DDD52
Metal Mechanical retract units 2 sets Max 3kg wieght 3mm:
http://www.hobbyking.com/buddy.asp?c...6-33193F424EE8
Keenan smith is offline Find More Posts by Keenan smith
Old Nov 05, 2011, 01:25 PM
If you post your codes in this thead, you should also post them on the buddy code site first: http://hk.rc-international.info/swarm
This time I did it for you: http://hk.rc-international.info/swarm/ksmit459
Good luck!
Old Nov 05, 2011, 01:49 PM
Joined Dec 2010
thanks
Alert HobbyKing BuddyPrice Codes for more products, use as you wish obuggy HobbyKing 7849 Feb 03, 2016 01:57 AM
Discussion Hobbyking buddy price thread discostu956 Australia 900 Jan 13, 2016 05:13 PM
Discussion Hk buddy codes bushpilotx1 HobbyKing 344 Jul 09, 2015 05:56 AM
Discussion Making a HobbyKing Buddy Box for a Futaba 10C? HighwayChild Radios 6 Jun 17, 2011 02:59 PM
Question Anyone interested? Hobbyking EPP-FPV Plane and motor discount codes Gree FPV Aircraft 0 Apr 22, 2011 09:54 PM
