Old May 14, 2011, 01:41 PM
Wind Raider is offline
Find More Posts by Wind Raider
Joined Mar 2007
One Cell Lipo powered glow driver
Just want to share my recent project ...
The FET got very hot , can't be used for long period .
This one is better
Note :
Fuse is to protect the circuit , not the glow plug
I got the FET from ex BL esc ....
Wind Raider is offline Find More Posts by Wind Raider
Old May 14, 2011, 02:51 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
I have seen several people trying to use linear regulators to power glow plugs which is a real waste of heat and power. Good to have a thread to point them to.
I understand that you were building from parts you had, but two comments for people buying parts to build one. First, the NE555 is specified for operation from 4.5V to 16V so is being operated outside it specifications. There are CMOS versions of 555 that are rated for lower voltages and if buying new parts they would be a much better choice. In the US, you can get the TLC555 at Radio Shack and it is rated for operation from 2 to 15v. The 4435 is also extremely marginal on a single lipo which is why you need two of them. If buying parts, a much better choice would be an IRF7420 and one of them should work fine.
jeffs555 is offline Find More Posts by jeffs555
Old May 14, 2011, 11:00 PM
Joined Mar 2007
Jeff ,thanks for your input .
NE555 can be powered with 3 volt although the datasheet says "min 4.5 volt" .
CMOS 7755 , TCL555 should be better .
IRF7420 to replace two 4355 is a good choice .
Since I live in a rural district , it is hard to find those components in local shop ; so I use my old 'stock component'
I will redraw this circuit with better components as you suggested .
Old May 15, 2011, 12:06 AM
Joined Mar 2007
I haven't tested this circuit . But it should work fine .
Old May 15, 2011, 12:16 AM
z-matrix is offline
Find More Posts by z-matrix
just look at it smokin'
z-matrix's Avatar
Joined Dec 2005
that's not a linear regulator, it just gives out the short circuit to the li-po using the heating element with a repetition rate.
Peak currents are probably very high with high Đi/Đt that may cause radio interference.
Sure, it works, as long as your li-po can take the high peac currents, and your fet does not go sc.
You may prefer adding sqrt(-1) to the system for better performance, though it will be a few gramms heavier.
Btw.: you can use the switch to switch and 1m mosfet control instead of the full circuit current...
Z
z-matrix is offline Find More Posts by z-matrix
Old May 15, 2011, 12:38 AM
Joined Mar 2007
@z-matrix : yup , that's non linier regulator .
testing version1
One 900 mAh Lipo can be used for 15 minutes continous ON . The battery is just warm a bit not hot .
Two Fets has advantages :
1. lowered the ON resistance , so we can 'dig' more mAH form the battery
2. the fet will be cooler .
btw , can you explain more about sqrt(-1) ?
Old May 15, 2011, 01:06 AM
z-matrix is offline
z-matrix's Avatar
Joined Dec 2005
its the square root of -1
was recommending the use of an inductor and capacitor to smooth the peak current.
A Buck regulator looks like this for example: http://en.wikipedia.org/wiki/Buck_converter
Z
Old May 15, 2011, 04:42 AM
Joined Mar 2007
The 555 is configured in astable oscillator .
Fet is used as electronic switch and also 'invert' 555 output .
Fet will be ON if output of 555 (pin3 ) is OFF ('low') .
The duty cycle ( to glowplug) is varied from 33,5 % to 1 %(adjustable)
The glow plug can take lipo output voltage in very short periods approx 1 ms.
The output to glowplug is approx 3.7 volt ( lipo nominal voltage )
Old May 15, 2011, 09:28 AM
CLASH is offline
Find More Posts by CLASH
Saskatoon,SK Canada
Joined Jul 2010
did to try with some of 3pins Mosfet?
Thank..
CLASH is offline Find More Posts by CLASH
Old May 15, 2011, 10:11 AM
Joined Mar 2007
The gate voltage threshold of common 3 pins FET is too high ; not suitable for this circuit ( with 1 cell lipo ) .
I didn't know whether 3 pins Fet with low voltage threshold available or not .
Perhaps Jeff can suggest that .
Old May 15, 2011, 02:53 PM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
Wind Raider is right. Most of the mosfets rated for Vgs of less than 4.5V are in SO-8 or smaller packages. Here is one in TO-220 that is rated down to 2.5V, but it has a rather high on resistance of 0.07 ohms. Two of them would work ok, or you could use just one with a small heat sink.
http://mouser.com/search/ProductDeta...opOw%3d%3d&amp
Old May 15, 2011, 09:32 PM
Disarray is offline
Find More Posts by Disarray
Disarray's Avatar
United States, GA, Gray
Joined Apr 2007
I currently use a C cell rechargebable battery, a 10amp micro switch and alligator clips for onboard glow. Works great.
Disarray is offline Find More Posts by Disarray
Old May 15, 2011, 11:53 PM
Joined Mar 2007
@disarray : yup , quick and easy method .
You use it as onboard glow driver ?
At what percentage of WOT ( wide open throttle ) you set the switch on/off ?
Alligator can be loose sometimes , you 'd better use glowplug cap instead .
Old May 16, 2011, 08:18 AM
Disarray is offline
Disarray's Avatar
Joined Apr 2007
It is on all the time. On this plane, I have 4 engines, so I use one toggle switch and one C cell for each glow plug. I like the clips, because I can easily take them loose to charge the batteries. I have never had a cell go dead, but I usually only fly this plane for about 30 minutes to an hour on a weekend.
Old May 24, 2011, 02:11 AM
Joined Mar 2007
Here is the version 3
with 20 seconds timer to control the glow heater
One Cell Lipo powered Glow Igniter version 3 (2 min 19 sec)
New Product Dynamite LiPo Glow Driver w/ Video J_Arner Fuel Plane Talk 16 Feb 02, 2012 03:06 PM
Wanted onboard glow driver greatplanes Aircraft - Fuel - Engines and Accessories (FS/W) 4 May 14, 2011 01:52 PM
Question Lipo - One Cell Dead? ruff1 Batteries and Chargers 8 May 07, 2011 12:09 AM
Discussion charging one cell lipo? Jetskeeter Batteries and Chargers 10 Apr 21, 2011 06:29 PM
Discussion Simple LiPo powered glow driver J_Arner DIY Electronics 8 May 22, 2010 06:31 AM
