Old May 14, 2011, 07:57 AM
JeffinTD is offline
Find More Posts by JeffinTD
United States, OR, The Dalles
Joined Apr 2011
ac/dc multi-chemistry multiple charger?
I'm pretty new to this, so please excuse the stupid question.
I mostly run medium size lipo batteries and would like a charger that would handle maybe 3 or 4 at once, that runs on 12v dc or 110v ac, and could handle large packs if I get into bigger electrics.
What chargers should I be looking at?
I'm not on an unlimited budget, but will pay more for something safe, and for something fast.
JeffinTD is offline Find More Posts by JeffinTD
Old May 14, 2011, 08:13 AM
SteveM732 is offline
Find More Posts by SteveM732
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
Few chargers run on both AC and DC and fewer still come with multiple units inside. Even then, I'm not sure how many are multi-chemistry. Worse yet, none can quickly charge what I consider to be a large pack.
To handle both AC and DC most of us buy a separate power supply. I won't go into the advantages and disadvantages, but if you can concede this point you will find many very high powered and economical chargers. Also, internal power supplies are often limited to 50-100W which is not high power. And if you really do want high power you'll need to step it up to a 24V input.
Since your charger doesn't exist (that I am aware of) I am going to suggest the following setup:
1) AC power supply with 24VDC output, capable of at least 500W output (you could start with a 12-15V supply and upgrade later if needed)
2) Multi-chemistry charger of at least 20A and 300W output with a 24V input capability
3) Learn how to charge batteries in parallel
My pick for the charger would be an FMA PowerLab8, or iCharger 208B, 306B, or 3010B. Hands down the best charger is the FMA PowerLab8, but it may exceed your budget.
http://www.progressiverc.com/index.php/chargers-1.html
http://www.usastore.revolectrix.com/...o-PowerLab-8_5
http://epbuddy.com/index.php?main_page=index&cPath=15
SteveM732 is offline Find More Posts by SteveM732
Old May 15, 2011, 09:06 AM
JeffinTD is offline
Joined Apr 2011
Thanks much for the reply. That has me pointed in the right direction.
Something AC/DC in one unit isn't high on my list, but would have been handy. I can always put the power supply and the charger on a caddy...
Old Jul 01, 2011, 09:37 AM
aarongreen123 is offline
Find More Posts by aarongreen123
Joined Dec 2009
i like that parallel charging idea, will one of those paraboards work with any balance charger? i have a dynamite passport charger, does up to 6s. would this work with that?
http://epbuddy.com/index.php?main_pa...roducts_id=110
aarongreen123 is offline Find More Posts by aarongreen123
Old Jul 01, 2011, 09:46 AM
philipa_240sx is offline
Find More Posts by philipa_240sx
philipa_240sx's Avatar
Canada, ON, Ayr
Joined Apr 2010
The Paraboard is compatible with most chargers. All that is required is a 6S JST-XH balance port and 4mm banana jacks for the main leads.
All versions of the Dynamite Passport fit this requirement.
philipa_240sx is offline Find More Posts by philipa_240sx
Old Jul 03, 2011, 05:31 PM
Joined Dec 2009
again i'm a newb to this, so a couple questions. When charging four 3s 2200 lipos rated at a 1c charge rate would i set the dynamite at the 6amp rate? am i understanding correctly that each batt would be getting the rate of 1.5amp? is there any danger of overcharging if one battery finishes first? do all the batteries need to be plugged in at the same time or can you add batts as you use them and just leave the charger rippin? thanks for your info so far
Old Jul 03, 2011, 06:56 PM
Canada, ON, Ayr
Joined Apr 2010
When charging in parallel, treat the packs a single large one. The packs will equalize their charge once connected in parallel and basically function as one larger pack.
ie. 4x 2200mAh = 8800mAh
So a 1C charge requires 8.8A
A few rules of thumb when parallel charging:
- DO NOT mix different battery make/models.
- DO NOT mix different mAh capacities.
- DO NOT mix fully charged Lipo's and discharged Lipo's.
For Sale Mega Peak Ac/DC Charger Kyle D. Aircraft - Electric - Batteries & Chargers (FS/W) 4 Jan 28, 2015 09:59 AM
Sold Ace Super Digipace AC/DC Charger slogo Aircraft - Electric - Batteries & Chargers (FS/W) 6 Apr 17, 2011 01:43 PM
Sold Or trade. Triton eq ac/dc charger GOOBERSEPTEMBER Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 19, 2011 07:05 PM
Sold Hyperion Charger $80 6060 ac/dc grubby Aircraft - Electric - Batteries & Chargers (FS/W) 3 Mar 14, 2011 06:46 PM
Sold Triton EQ 2 AC DC Charger - $135 shpped/paypaled OCFly Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 03, 2011 08:01 PM
