Hallo,
The Reisenauer Super chief seems to be a little bit oversized for this application, its not only double the price,but aswell nearly double the weight of the KPG. The 5/6mm shaft ist a very nice solution,but it reduces spinner-options for hotliner use! The Micro-Edition NL ist tested(not recommended ) up to 3 Kw, its running very smooth and silent and its got very good efficiency and less than half the KPG´S weight.The high torque pinion is pretty long and has more surface to glue it on the shaft than the KPG;but 3KW and big props with hard start-up and brake may bring it to its limit!! Andy told me that he is working at an solution in between Super-Chief and Micro-Edition NL, based on the ME NL with longer gears and steel-housing,this may be an alternativ option to the KPG Regards Yello |
Mike |
I'm not saying the kontronik GB is bad, just that there are other options that might kick it up a notch |
http://tds.loctite.com/tds5/docs/680-EN.pdf
http://www.loctite.sg/sea/content_da...g_Compound.pdf 648 is better, slightly better temp VS strength, and better normal cure strength too... Best try find me some ![]() Edit - YIKES! Just found some 648 in NZ, $203NZ for 50mls
Unless you don't want to wait that long. The 10ml I have will last me at least 3 lifetimes.Let me know. |
| Thread Tools | |
| Discussion 16-25-2 + KPG25 5.2 on 6S | jackosmeister | High Performance | 27 | Jan 25, 2012 09:07 PM |
| Discussion Is it possible to change the ratio of a KPG25 gearbox. | jackosmeister | Power Systems | 2 | May 15, 2011 01:01 PM |
| For Sale Kontronik 5.2 6mm kpg27 gearbox and mount | la528it | Aircraft - Electric - Power Systems (FS/W) | 5 | May 06, 2011 03:02 PM |
| Sold KONTRONIK KPG25 Planetary Gearbox; KONTRONIK Adapters for KPG27 & KPG25 GB | old_dude | Aircraft - Electric - Power Systems (FS/W) | 6 | Jan 17, 2011 03:39 PM |
| Sold KONTRONIK KPG25 Planetary Gearbox; KONTRONIK Adapters for KPG27 & KPG25 GB | old_dude | Aircraft - Sailplanes (FS/W) | 1 | Jan 17, 2011 03:24 PM |
