Old Jul 09, 2011, 02:55 AM
Sure it'll work
Flyextreme's Avatar
United States, CA, Torrance
Joined Nov 2005
Grease or oil....oil or grease. I'm trying to figure out what to use in my GB. Has anyone come to any conclusion as to what they are going to use? Or are using?
Anyone familiar with this? http://www.espritmodel.com/index.asp...D&ProdID=10225
Or this? http://www.espritmodel.com/index.asp...OD&ProdID=9867
I'm considering this http://www.espritmodel.com/index.asp...D&ProdID=12609 unless someone tells me it's not what I want.
I don't want something like this holding up the X-plane's completion.
Bill
Flyextreme is online now Find More Posts by Flyextreme
Old Jul 09, 2011, 04:43 AM
sebbe's Avatar
Sweden
Joined Feb 2006
Bill you are looking at greases now, wouldnt it be better with oil ?
Sebbe who also dont know what lube to use ????
sebbe is offline Find More Posts by sebbe
Old Jul 09, 2011, 02:48 PM
la528it's Avatar
City of Angels
Joined Dec 2007
Bill the esprit syringes are useless (I have it and only use it on servos). You are looking for something that will not shear in excess of 50k rpm, keep the needle bearings happy, not deteriorate the plastic cage, tolerate any flaking of the teeth and keep the gears otherwise happy during rotation, start-up and braking....
Buy some of mine, or send me your motor and I'll take care of it (remove all all old lubricant, relube, seal and ship).
I only contacter Kluber for this after seeing a marked jar on the brushless God's shelf in an rcgroups post.
la528it is offline Find More Posts by la528it
Old Jul 09, 2011, 11:56 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
Rich, thanks for the offer and I may still take you up on it even though I just ordered the TriFlow http://www.espritmodel.com/index.asp...D&ProdID=12609 along with the 648 retaining compound.
Do you think the TriFlow grease would not be adequate?
Bill
Old Jul 10, 2011, 01:49 AM
f5b-uk
Mike Seale's Avatar
Devon, UK
Joined May 2002
It's funny how people come to different conclusions when presented with the same information! Under no circumstances would I have bought the TriFlow grease when both of the other types you linked were specifically aimed at gearbox applications.
Mike Seale is offline Find More Posts by Mike Seale
Old Jul 10, 2011, 01:51 AM
200mph club.
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Its funny isnt it..
Id like to try some klubber, but it seems to be unobtanium outside of the EU.
Does it have any spec's? so I can try to find an equivalent.
Maybe we should all try different stuff, and see whos gearbox explodes first
jackosmeister is offline Find More Posts by jackosmeister
Old Jul 10, 2011, 02:16 AM
la528it's Avatar
City of Angels
Joined Dec 2007
Originally Posted by jackosmeister View Post
Its funny isnt it..
Page 11 and page 17
Old Jul 10, 2011, 02:17 AM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
I suppose part of why I decided on the Triflow is because I am familiar with Triflow oil that I used on my helis and on motor bearings. I also seem to be using up alot of time trying to figure out what exactly to use, so I just made a decision, even if it was not the best one.
Mike, based how how strongly you seemed to feel about the Triflow, and the fact I had some doubt already, I just cancelled the Triflow.
Bill
Old Jul 10, 2011, 02:58 AM
f5b-uk
Mike Seale's Avatar
Devon, UK
Joined May 2002
I know what you mean about wasting time making a decision and my comment wasn't necessarily aimed against TriFlow but when presented with two products that were specifically aimed at gearboxes it seemed odd that you would go for the third option.
Based on others comments about Reisenauer products you might want to consider the grease they use
http://www.reisenauer.de/artikeldetails.php5?aid=1135
For 2 euros and a couple of weeks waiting for delivery it might be worth a try?
Old Jul 10, 2011, 03:06 AM
sebbe's Avatar
Sweden
Joined Feb 2006
la528it wich grease ?
We have them here in Sweden:
http://www.produktaktuellt.se/bransc...n-skandinavien
I will call them tomorrow..
Old Jul 10, 2011, 11:59 AM
Joined Sep 2008
hello , can i take a gearbox for my het 2w20 ?? kpg25 or 27 ?
thanks a lot
mattbrignoli is offline Find More Posts by mattbrignoli
Old Jul 10, 2011, 03:51 PM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
thanks a lot
Since your HET have a 3.17 shaft you sure can use a GB with it. Both KPG25 and KPG27 accept this size of motor. 5.2:1, 4.2:1 and 3.7:1 are the reduction rate options.
Just remember to get the right kind of flange and a bottle of Loctite 648....
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jan 21, 2012, 08:08 PM
200mph club.
Auckland NZ
Joined Aug 2007
Im having issues....
One KPG25 I have has busted the pinion-shaft bond three times now.
Ive tried changing the pinion for a new one, both shaft and pinion have been meticulously cleaned before install, and its still busting them off.
Im wondering if my loctite 680 has gone bad? This is getting annoying now...
Old Jan 21, 2012, 09:51 PM
One Idiot is plenty...
Dbox's Avatar
Planet Earth
Joined Jun 2005
Not a single problem.
Even when pinion not so tight to the shaft.
Heat box overnight.
Yuri
Dbox is offline Find More Posts by Dbox
Old Jan 22, 2012, 05:35 AM
RC Farmer
Farmer_Joe's Avatar
Joined Aug 2011
jacko - locktite is good for about 1.5-2 years shell life. I lightly grind the shaft with 400-500 sanding paper.
Farmer_Joe is offline Find More Posts by Farmer_Joe
Discussion 16-25-2 + KPG25 5.2 on 6S jackosmeister High Performance 27 Jan 25, 2012 09:07 PM
Discussion Is it possible to change the ratio of a KPG25 gearbox. jackosmeister Power Systems 2 May 15, 2011 01:01 PM
For Sale Kontronik 5.2 6mm kpg27 gearbox and mount la528it Aircraft - Electric - Power Systems (FS/W) 5 May 06, 2011 03:02 PM
Sold KONTRONIK KPG25 Planetary Gearbox; KONTRONIK Adapters for KPG27 & KPG25 GB old_dude Aircraft - Electric - Power Systems (FS/W) 6 Jan 17, 2011 03:39 PM
Sold KONTRONIK KPG25 Planetary Gearbox; KONTRONIK Adapters for KPG27 & KPG25 GB old_dude Aircraft - Sailplanes (FS/W) 1 Jan 17, 2011 03:24 PM
