Old Jun 25, 2011, 01:46 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Anyone tried this one?
http://www.reisenauer.de/artikeldeta...=233&sprache=2
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jun 25, 2011, 02:00 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
That is cool. Its tiny, but can take a kW
jackosmeister is online now Find More Posts by jackosmeister
Old Jun 25, 2011, 02:07 AM
Arcteryxxx's Avatar
Joined Feb 2010
Just might be ideal for an X-plane application....
Old Jun 25, 2011, 02:45 AM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Speaking of small (not tiny)....I just remembered I have an Aveox 1015/2Y with a Maxon 4.4:1 GB. I think the calc said it pulls about 34A on 5S with a 12x6 prop. I spun it up on an 11x7 on 3S (don't know how many amps) and it was amazing the thrust it had. This just might be a great starter set-up for a 60" plane or so.
I doubt I will use it. If anyone is interested, shoot me a PM. It has a CC35A esc on it too.
Bill
Flyextreme is offline Find More Posts by Flyextreme
Old Jun 25, 2011, 09:50 AM
Dbox is online now
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Originally Posted by Arcteryxxx View Post
Reisenauer's are simply the best ones on Earth.
Yuri.
Dbox is online now Find More Posts by Dbox
Old Jun 29, 2011, 07:07 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Im thinking of using my Mega 16/25/1.5S in my KPG 27.... and the shaft on this smaller mega is only 11mm long.. And with the adapterflansche in place the shaft is 2mm from the bottom of the gearbox.
Will it be ok if the pinion that has to be glued on to the shaft only is glued 7mm ? will it hold ? The pinion is 9mm long..
Or would it be better to glue the pinion all the way on the shaft, but this way the gears from pinion will be 2mm higher up, making the pinion only to grip with 7mm of its length instead of the 9mm..
I hope you understand me, otherwise I can draw a picture explaining.
sebbe is offline Find More Posts by sebbe
Old Jun 29, 2011, 07:13 PM
Auckland NZ
Joined Aug 2007
sebbe - Use the fun/kira 400 mount, opened up centre hole, to get ALL the shaft in the pinion, and the gears engaged properly.
Whats everyone using for lube in their KPG's/planetary boxes being pushed hard?
Old Jun 30, 2011, 03:40 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Jacko, NP, I will be using a mega 16/40/1, it has longer shaft... just did order one.
I am also wundering, what lube to use in the gearbox.
Old Jun 30, 2011, 01:45 PM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
I can send you some, $15 + shipping = 3ml in a syringe + application tip (enough for at least 2 completely dry boxes).
This is some of the best synthetic lubricant you can buy, made for high load, high speed applications... will not shear like the junk you buy at the automotive stores.
la528it is offline Find More Posts by la528it
Old Jun 30, 2011, 03:15 PM
Heather is offline
Find More Posts by Heather
Hastings, Hawkes Bay, New Zealand (Aotearoa)
Joined Feb 2000
Kontronik sell lube for there gearboxes themselves
http://www.wattsup.co.nz/catalog/pro...roducts_id=417
Heather
Heather is offline Find More Posts by Heather
Old Jun 30, 2011, 04:08 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
I will check with my father first, he works in a factory where they have the most expensive oil/lube for machines...
I wanted to know what KIND of lube..? a high pressure/load / speed lube ?
Thanks anyway...
Old Jun 30, 2011, 04:23 PM
la528it is offline
la528it's Avatar
Joined Dec 2007
Heather
It seems to shear/dissipate quickly http://www.rcgroups.com/forums/showp...06&postcount=8
http://www.rc-network.de/forum/showt...liner-Antrieb?
I have also lost the bearings in one with what appeared to be factory lubrication. At the end of the day, I suspect it does not matter much, all this "evidence" is probably caused by other things... I spent way too much time trying to find the best which is why I am so adament about all this here
yes, yes, yes... tell him your application is like a spindle bearing, but worse... the same lube which keeps the needle bearings happy must also keep the gears happy since these all have open cages.
Old Jun 30, 2011, 04:34 PM
Auckland NZ
Joined Aug 2007
Id imagine some sorta low viscosity high grade gearbox oil would be best?
Grease seems like it would get flung off too easily, which is why I used aeroshell 12.
What about something like this - http://www.redlineoil.com/product.aspx?pid=42&pcid=8
My getrag 260, and LSD love redline fluids.. Im tempted to give it a go!
The kontronic grease, looks, smells and feels like molykote 33 light. Could just be a similar product though.
Old Jun 30, 2011, 06:08 PM
Dbox is online now
Dbox's Avatar
Joined Jun 2005
You guys "too much of a science " here.
Yuri
Old Jun 30, 2011, 08:25 PM
Sure it'll work
Flyextreme's Avatar
Joined Nov 2005
Yuri
That's just ridiculous. You need synthetic like Parkay or Country Crock.
Discussion 16-25-2 + KPG25 5.2 on 6S jackosmeister High Performance 27 Jan 25, 2012 09:07 PM
Discussion Is it possible to change the ratio of a KPG25 gearbox. jackosmeister Power Systems 2 May 15, 2011 01:01 PM
For Sale Kontronik 5.2 6mm kpg27 gearbox and mount la528it Aircraft - Electric - Power Systems (FS/W) 5 May 06, 2011 03:02 PM
Sold KONTRONIK KPG25 Planetary Gearbox; KONTRONIK Adapters for KPG27 & KPG25 GB old_dude Aircraft - Electric - Power Systems (FS/W) 6 Jan 17, 2011 03:39 PM
Sold KONTRONIK KPG25 Planetary Gearbox; KONTRONIK Adapters for KPG27 & KPG25 GB old_dude Aircraft - Sailplanes (FS/W) 1 Jan 17, 2011 03:24 PM
