Old May 13, 2011, 09:04 PM
hog2soar's Avatar
Central California
Joined Jan 2010
How loose do you keep your folding prop?
How loose do you keep your folding prop? Just loose enough that you have to slightly push it back against the fuselage? Or is it loose enough when holding the plane in your hand and you point the nose up 90 deg. to the ground that it folds back against the fuselage by its self?
Also do you use locktite on the threads,holding the prop on?
Just curious what everyone is doing. Or if you have a set way of adjusting the tension?
hog2soar is offline Find More Posts by hog2soar
Old May 13, 2011, 09:15 PM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Loose enough so that it falls under it's own weight.
Loctite if the nuts are not lock nuts, or if the yoke uses bolts that screw into the yoke directly..
..a
Old May 13, 2011, 09:20 PM
kilwein's Avatar
Joined Jan 2007
Have mine so they move just by pointing nose up - down. Locktite is a must on the threads, I also put some on the bolt head shoulder. I also have the bolt head on the forward spin side, not sure if this is the best or not. Having a folder loose one prop half would be a very bad day.
kilwein is offline Find More Posts by kilwein
Old May 13, 2011, 10:05 PM
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
Yes
Fold under their own weight. Loctite needs to be kept away from any nylon or plastic part. Also, coat threads, not the tip of the bolt. You are using a "thread locking" compound.
Foambird is offline Find More Posts by Foambird
Old May 13, 2011, 11:56 PM
E-Gliders
outngo's Avatar
South Carolina
Joined May 2009
very loose, so that is does not hang on power off.
outngo is offline Find More Posts by outngo
Question How Do You Balance a Folding Prop Xptical Electric Sailplanes 11 May 30, 2011 06:36 AM
Poll How do you operate your transmitter? slowone096 Electric Plane Talk 18 Apr 16, 2011 11:02 AM
Discussion How do you weather your WW1 aircraft? Gunnar15 Scale Electric Planes 6 Mar 21, 2011 10:54 PM
Discussion How do you keep covering from pulling off when you tape your wingtip on? mdennis Sailplane Talk 13 Aug 26, 2007 08:34 PM
