Old May 13, 2011, 08:05 PM
FlopGun is offline
Find More Posts by FlopGun
You brought two too many.
FlopGun's Avatar
United States, WA, Seattle
Joined Jul 2007
Build Log
Extreme Flight 60" Edge 540T EXP - Build/Fly/Video
Guys, I can't believe it, but here goes. Chris Hinson of Extreme Flight asked me to do the 60" Edge EXP build/fly and video thread and that's just what I'm going to do, how lucky is that? Herc and the gang must be too busy 3Ding these Edges at the Joe Nall.
I have a lot of flights with 48" Edge EXP, it's the best 3D 4-footer I've flown, and I already know this 60" will be my favorite 5-footer.
Specs:
Wingspan: 60 inches
Length: 58.5 inches
Wing Area: 760 square inches
AUW: ~ 5.5 lbs
Price:
$259.95 available direct from Extreme Flight.
$429.95 with power combo (esc+motor).
My setup:
Airtronics 94820 servos
Dubro Heavy Duty servo arms for Airtonics (cat no. 856)
EF Airboss Elite 80 amp ESC
EF Torque Revolution 4016T/500 motor
6S 3000mah and 5S 3600 lipos and maybe some 4000 ones.
I will be using Xoar/Vox props of various sizes.
UPDATE 6/2 Flight Video
Extreme Flight 60" Edge 540T (5 min 13 sec)
The model is nicely packaged and has all the goodies you expect from EF and a few extras.
* Carbon and composite reinforced fuselage and landing gear mount
* Complete hardware package with dual ball links for all control surface actuation
* Carbon Fiber wing tube, main gear and tail wheel assembly
* Side Force Generators
* Wing Bags
* Spinner
* Decal sheet
Mine arrived in perfect condition.
Let me know if there's any questions or specific things to check out.
I have the red, white and blue version and will be starting the build right after this initial post.
Here's a few shots to get started.
FlopGun is offline Find More Posts by FlopGun
Old May 13, 2011, 09:07 PM
stevelmaa is online now
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
Looking forward to the build and video Flopgun.
Steve
stevelmaa is online now Find More Posts by stevelmaa
Old May 13, 2011, 10:37 PM
r/cdawg is online now
Find More Posts by r/cdawg
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
I'll be tagging right along with you Flopgun. I plan to start my build tomorrow afternoon. Same set up with the exception that I'll be using Hitec HS-225MG servos.
r/cdawg is online now Find More Posts by r/cdawg
Old May 15, 2011, 12:47 PM
FlopGun is offline
FlopGun's Avatar
Joined Jul 2007
OK, let's talk about weight for a sec. My flying style is low and slow and lots of 3D so I like low wing loading.
Now, when I first built my 48" Edge, and weighed it close to 3 lbs, that seemed on the heavy side for a 48". But when I flew her she flew *very* light. The Extra EXP also flies light on the wing, but the Edge had something about it that makes it 3D so easy.
Bottom line is with the 60" Edge I'm not worried about weight, but all the same I like to keep my eye on it, so here are some numbers:
Fuse 428
Left wing 201
Right wing 202
Elevator+stab 96
Rudder 34
Canopy 107
Wing Tube 39
Wheel Pants 39
Main Gear 51
Hardware Packet 103
Torque Motor 290
Motor Hardware 30
Vox Propeller 29
Spinner 7
Airboss ESC 84
SFGs 40
4 X airtronics 94820 112
Servo arms 6
Spektrum 6200 10
Extensions/ties/misc 32
6S 3000mah Lipo 460
Glue??
Decals??
AUW 2400 grams
85.7 oz.
5.35 lbs
Never measured glue! Guessing less than 1 oz.
So this model is going to be floaty 3D magical. Considering I've owned two Extra 58" that were 90-92 oz AUW and they flew very good 3D.
Here we have larger plane with more wing area, more fuse area, lighter weight and the Edge design.
For those with 4S packs, and lighter motors like the Motrolfly 3620, you could get AUW near 82 oz.
The absolute lightest setup would be with Motrolfly (saving 2 oz), no pants or spinner (2 oz), no SFGs (1.5oz) and lighter lipo (2 oz). AUW under 80 oz.
Old May 15, 2011, 01:24 PM
Vref is offline
Find More Posts by Vref
Vref's Avatar
United States, CO, Evergreen
Joined Oct 2003
very cool. having built several EXP's I know that this thread is going to be more typing than building. Looking forward to the video at the end.
Vref is offline Find More Posts by Vref
Old May 15, 2011, 10:54 PM
FlopGun is offline
FlopGun's Avatar
Joined Jul 2007
Well, I've got the perfect set of days for putting this together, the weather has been very Northwest. Low pressure, gray and wet. So we build.....
What can I say, there's not a lot of building, EF has done just about everything except brew the coffee.
Before starting off, I like to have all the tools right there ready to go. And plenty of sharp blades handy, and maybe a classic rock CD.
Old May 16, 2011, 02:54 AM
FlopGun is offline
FlopGun's Avatar
Joined Jul 2007
Now it's time to glue the hinges with thin CA and install the servos, control rods and ball links.
I like to use a set of hemostats and a small pivot type screwdriver for the ball link assembly.
And even though the kit includes lock nuts, I use some blue loctite anyways.
In the hardware kit with the tail wheel are four threaded control rods. Find the two smallest ones and thread the ball links on. Keep twisting until you have the desired length.
Old May 16, 2011, 02:17 PM
livinma1 is offline
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
subscribed
livinma1 is offline Find More Posts by livinma1
Old May 16, 2011, 02:27 PM
FlopGun is offline
FlopGun's Avatar
Joined Jul 2007
Moving along, lets put together the gear and also fit and glue the horiz stab and elevator.
A note on gluing the stab in. What I like to do is do the measurements first, then when satisfied, CA the stab in, but just with a few drops.
Let it dry a few minutes and take measurements again. If all is well hit it with more CA. But if it something wiggled or jiggled it will be easy to debond those few drops and fix the error.
Old May 16, 2011, 02:39 PM
FlopGun is offline
FlopGun's Avatar
Joined Jul 2007
Also before I forget, because it's important. I've never had a problem with Hitec servo arm screws backing out, but if you are using the Airtronics servos make sure you use a *little* loctite on the threads. These airtronics screws will back out on you.
Old May 16, 2011, 02:43 PM
EXTREME FLIGHT is online now
Find More Posts by EXTREME FLIGHT
EXTREME FLIGHT CEO
EXTREME FLIGHT's Avatar
United States, GA, Cumming
Joined Feb 2004
Nice work FlopGun! Thanks for taking the time to do such a detailed report.
EXTREME FLIGHT is online now Find More Posts by EXTREME FLIGHT
Old May 16, 2011, 03:02 PM
Flazo is online now
Find More Posts by Flazo
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
FlogGun, I bought the Dubro Light Wheels 2.5 inches...
we don't fly on a smoth pavement...
Fred
Flazo is online now Find More Posts by Flazo
Old May 16, 2011, 08:18 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
Looks great Flop, looking forward to seeing this one fly at our fields under your expert control!
cryhavoc38 is offline Find More Posts by cryhavoc38
Old May 16, 2011, 10:00 PM
caaraa is offline
Find More Posts by caaraa
Joined Apr 2011
it looks good.
[img][/img]
caaraa is offline Find More Posts by caaraa
Reply With Quote  (Disabled)
Old May 17, 2011, 05:51 AM
viper7 is offline
Find More Posts by viper7
viper7's Avatar
St. Louis, MO
Joined Dec 2008
sub
viper7 is offline Find More Posts by viper7
Cool New - Extreme Flight 60" Edge 540T EXP!!! hercdriver7777 3D Flying 12606 Today 04:56 AM
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 12547 Jul 24, 2016 07:44 PM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
