Old Sep 17, 2011, 09:23 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
The new batch of Motley Crew's shouldn't need the upgraded flex shaft anymore, but you can still run one if you want. The stock rudder does a great job, no need for a replacement. The stock ESC is already water cooled and doesn't run that hot with the stock motor either.
IMO get a new prop (grim 42x55 or octura m445), solder on 5.5mm bullets and enjoy it.
wparsons is offline Find More Posts by wparsons
Old Sep 17, 2011, 07:09 PM
siberianhusky is offline
Find More Posts by siberianhusky
siberianhusky's Avatar
Canada, ON, Peterborough
Joined Nov 2009
No need at all the swap out the rudder unless you are putting an SV one on for the cooling pickup, Set the CG to 30%, start with the strut even and level with the bottom of the sponsons, raise the strut slightly to lift the nose until you get it aired out nicely.
No need to change the CG for different water or windy conditions, just lower the strut a bit and the boat tightens up nicely.
siberianhusky is offline Find More Posts by siberianhusky
Old Sep 22, 2011, 04:52 PM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
What's the deal with the "limited run" http://www3.towerhobbies.com/cgi-bin...&I=LXASLN&P=ML ?
Diesel6401 is offline Find More Posts by Diesel6401
Old Jan 18, 2012, 11:07 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Originally Posted by Diesel6401 View Post
Did some work on the MC yesterday. Changed the setup up dropped a Leopard 4068 2350kv motor in it, a swordy 200 (waterproofed), flipped the motor mount and took a dremal to the stuffing tube and flexshaft. Should be interesting on this setup , prop is top secret ... no clue when ill actually be able to run her.
Sorry for delay, lot's of stuff was going on...
Tested this setup. I was very VERY pleased with how the motor performed. Sadly I did forget my eagletree at home. I ran the setup 3 different times for 3 minutes each. The hottest the motor reached was 105F and the Swordfish 200 reached 115F at the boards. The motor/esc did not mind the prop. I did however find that the hull did not like the prop at all which was disappointing. The prop was a x447/3 cut down to 42mm, detongued with a slight cup. I generated a lot of prop walk in the hull and the transom had a very noticeable shimmy. I love the motor/esc combo though. I ran twice on 4s1p setups. The first was Gens Ace 2s 5300mah 25c/50c they handled pretty good, but did kick the lvc in prematurely a few times. I figured they where getting pushed for that to happen, next I tried 2s 6000mah 25/50c nano-techs. They also kicked in premature on the lvc even more then the Gens aces. I then went to 4s2p and the hull liked the extra weight and the system responded better to the 2p setup. I gps'd the first run with a disappointing 48.8mph, but when I seen how bad the prop walk was, speed (like normal for me) wasn't a goal. I wanted to try some different props, but of course my prop box was next to my eagle tree left at home I'm thinking a m445 next or even actually propping down to a grim 40x52/3 and using a 1p setups as i have more 2s packs then 4s packs. I also have my trusty grim 42x55 I would like to try. My goal is to get this think running as perfect as I can get without top speed as the #1 goal. I'll load some video soon.
Old Jan 18, 2012, 11:30 PM
mavdriver is offline
Find More Posts by mavdriver
mavdriver's Avatar
United States, CA, Apple Valley
Joined May 2002
Hey diesel I pick up a MC hull only brand new on fleabay so i was thinking turnugy 120 with Leopard 3674 2200kv , 4s 5000 40c what do you think for a prop prather 220 , m445 or grim 42 /55 ?
mavdriver is offline Find More Posts by mavdriver
Old Jan 19, 2012, 12:43 AM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Any of those props are fine. Prathers are pretty wicked. I'm just a HUGE 42x55 fan. I love that prop...
Old Jan 19, 2012, 07:54 AM
mavdriver's Avatar
Joined May 2002
Cool 42x55 will try it already have the P 220 will try that one also thanks
Discussion A day (or two) with the crew of Flite Test, SEFF 2011 Flying-Monkey Chit Chat 39 Oct 01, 2011 02:44 PM
Question Looking for Boat crew jostone United Kingdom 0 Apr 18, 2011 04:30 AM
Discussion U.S. fighter jet crashes in Libya; crew members safe 2SMOKINBARRELS Life, The Universe, and Politics 49 Mar 23, 2011 05:18 AM
Discussion Aquacraft Motley Crew connorryder100 Racing Boats - Electric 6 Feb 19, 2011 07:49 PM
Discussion What Motley Crue Can Teach Us About Drug Legalization MtnGoat Life, The Universe, and Politics 42 Aug 19, 2008 10:20 AM
