Old Jun 03, 2011, 04:15 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
I used this amplifier.
I had all my test done on the FRsky system. I had read good reviews about it, and was cheap enough for me to try .
I know other people used on different RC 2.4Ghz. I guess it can be done if you know what to do, else use the search option on the forum, and/or ask if other people has done it. I suggest to do a lot of tests nearby before trying flying far away.
Elcheapo is offline Find More Posts by Elcheapo
Old Jun 05, 2011, 06:50 AM
Beruang is offline
Find More Posts by Beruang
Joined May 2011
Thank you very much Elcheapo, I will do more search on how to do it. Also thanks for your suggestion. I'll do the test for sure.
Beruang is offline Find More Posts by Beruang
Old Jun 07, 2011, 03:21 PM
tom83 is offline
Find More Posts by tom83
Rather be flyin
tom83's Avatar
Tucson, Arizona
Joined Mar 2008
That is just awesome! Great work!
tom83
tom83 is offline Find More Posts by tom83
Old Jun 20, 2011, 12:06 AM
migser85 is offline
Find More Posts by migser85
Tegucigalpa, Honduras
Joined Feb 2007
Alex, el rvosd toma control sobre los 4 controles principales (elevador, rudder, aleron y throttle)? o lo hace como otros que solo funciona tomando control de (rudder, elevador, throttle)? ya que si usa los 4 supongo que es mas preciso para hacer return to home ya que los aprovecharia todos
migser85 is offline Find More Posts by migser85
Old Jun 20, 2011, 11:07 AM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
On standard configuration RVOSD will set rudder to neutral and will manage the plane travel by using ailerons, rudder and throttle.
Old Jun 20, 2011, 04:54 PM
tushev is offline
Find More Posts by tushev
tushev's Avatar
USA, NY, New York
Joined Nov 2008
The autopilot on version 5 work with elevons control(flying wing) also ?
tushev is offline Find More Posts by tushev
Old Jun 20, 2011, 06:52 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
of course
Old Jun 20, 2011, 06:54 PM
tushev is offline
tushev's Avatar
USA, NY, New York
Joined Nov 2008
Awesome!
Old Jun 25, 2011, 01:52 PM
gordonrp is offline
Find More Posts by gordonrp
United States, TX, Austin
Joined Oct 2009
Amazing video!
Thanks for sharing your amazing video Alejandro. Your OSD looks awesome, may have to try one of those.
Can you post some more info about your antenna tracker? Do you use antenna trackers for both your controller TX (controlling the plane) and a separate one for video?
I just want to get a 5km range on both, enough to fly around the local area a bit. Currently using 2.4ghz dx6i, and a 600mw 5.8ghz video transmitter, both using rubber duckies 2dbi i think, but range seems very limited (almost within sight).
gordonrp is offline Find More Posts by gordonrp
Old Jun 27, 2011, 12:10 AM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
The antenna tracker I used on the video was driving an 8Dbi patch. It also has the capability to select an alternate video source (diversity) if the signal is better on that input. There was a yagi antenna on the receiver connected to that second input. The diversity system switched to the yagi at about 25km distance. I used the video transmitter adjusted for 1.16Ghz frequency.
I also had a 14dBi patch for the 2.4Ghz R/C transmitter. But that was mounted on the R/C transmitter. Aimed manually, I both had set a straight line course by having waypoints set on the OSD display. And also aimed the R/C antenna by watching the antenna tracker direction and RSSI signal value.
If your range is limited you have to use better antennas. I was able to fly up to 4.5km by using a patch antenna on the R/C transmitter and 800mW video transmitter. However keep in mind that 2.4Ghz signal can drop suddenly with no advice, and it could take several seconds to get signal back. Without a RTH system I don't think is good idea to test the limits of your R/C or video system.
Old Jun 30, 2011, 06:46 PM
(KNO3) is offline
Find More Posts by (KNO3)
Joined Apr 2010
Did you use low pass filter with the video tx?
(KNO3) is offline Find More Posts by (KNO3)
Old Jun 30, 2011, 09:04 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
No, but I have the receiver 1 meter from the Video transmitter, and both are 50cm away from the rest of the electronics.
Old Jul 23, 2011, 10:03 PM
clipper99 is offline
Find More Posts by clipper99
Oh so close!
clipper99's Avatar
Campbell River
Joined Jan 2010
Using the Argtek 1W booster with the 7DBi patch antenna I wasn't even able to get 2.5km on a ground test with clear LOS between the two points. I think I should try it without this 9db attenuator. Opinion seems to be split on if you need one or not. I cannot adjust the power output of my RC TX so I'm thinking of retrying the ground test again tomorrow without it.
clipper99 is offline Find More Posts by clipper99
Old Jul 23, 2011, 11:30 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
I used FRsky. But the receiver was 50 cms away from the rest of the airplane electronics and 1 meter away from a 1.5W transmitter.
Old Jul 24, 2011, 08:44 PM
Wingnut13 is offline
Find More Posts by Wingnut13
I do all my own crashes
Wingnut13's Avatar
United States, NH, Rochester
Joined Jan 2011
Nice work EL cheapo, I'm just now building up my 9x/FrSky system. Last night I put two WiFi antennas on the Rx side to try to increase range. I haven't got a chance to try it out though.
How is it that a 1W Amp is $45 but the 2W model is $200! Dang....
Wingnut13 is offline Find More Posts by Wingnut13
Data R/C 2.4Ghz pushed to 20km Elcheapo FPV Talk 32 May 16, 2011 10:12 PM
Discussion Exceed RC 6ch 2.4ghz TX with LCD monitor? leithalweapon Electric Heli Talk 1 Mar 15, 2011 12:55 PM
Discussion 2.4GHz Rc range test teopbako FPV Talk 17 Mar 09, 2011 03:08 PM
Sold New Futaba 7C 2.4GHz FASST RC Radio $320 w/free shipping stwaller12 Aircraft - General - Radio Equipment (FS/W) 2 Mar 09, 2011 08:06 AM
Discussion Hitec 2.4GHz pushed back to Mid Sept./Late Oct. What's up Mike? Gyroguru Radios 0 Aug 25, 2009 02:17 PM
