Old May 17, 2011, 01:19 PM
PilotKeeg is offline
Find More Posts by PilotKeeg
Joined Aug 2010
can I run the booster on 6.5v? I have been thinking of using 4 alkaline batteries in series to power the booster. Can it run on 5v? The AC adapter says it puts out 6v so I assume 6.5v is ok.
PilotKeeg is offline Find More Posts by PilotKeeg
Old May 17, 2011, 01:42 PM
tushev is offline
Find More Posts by tushev
tushev's Avatar
USA, NY, New York
Joined Nov 2008
Originally Posted by Elcheapo View Post
Georgi, Everything will be on stock by the end of this month.
Thanks for the 2W amp link, already bought. Maybe runing it on 5V instead of 6V could make it more reliable at the expense of having less power. Or running it 6V for my next distance tests
Oops, actually work on 9-12V, straight from 3S Lipo. I will check latter if I am wrong.
Good news is it never gets hot, so no worry
Cheers,
G
tushev is offline Find More Posts by tushev
Old May 17, 2011, 01:50 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
well if you get a better one i'd be happy to buy the old used one. PM me let me know.
I am not interested on selling mine, sorry.
People are reporting this boosters failing. By using more voltage you are actually stressing it more. I think the best is to go the other way. Use 5-5.5V to power it.
Cheers,
G
Thats very good news, maybe this is the answer to get a more reliable unit. I am very happy with my 1W unit though.
Elcheapo is offline Find More Posts by Elcheapo
Old May 17, 2011, 04:13 PM
tushev is offline
tushev's Avatar
USA, NY, New York
Joined Nov 2008
I put some interior pictures of the 2W Booster on this threadhttp://www.rcgroups.com/forums/attac...mentid=3270392
Old May 30, 2011, 12:58 AM
migser85 is offline
Find More Posts by migser85
Tegucigalpa, Honduras
Joined Feb 2007
buenas Alex, estoy entrandole al fpv luego de volar 3 aņos helis3d, ya me he comprado mi buen ekipo de video pero estoy muy indeciso con el osd, el rvosd g5 se ve muy prometedor, cuando sale? el horizonte artificial funciona con sensores infrarojos o con acelerometros? te felicito por tu videos eso me hizo comprarme el sistema frsky con booster y patch de 7dbi para mi dx7, que voltage es mejor para el booster de 1W 5v o 6v con el bec q recomienda range video? sigue asi de bien, quisiera saber si hay un manual en pdf de rvosd g5 para irlo estudiando en mis tiempos libres en el trabajo, estoy ansioso por saber lo nuevo que trae el rvosd.
saludos desde Honduras, Jose miguel
migser85 is offline Find More Posts by migser85
Old May 30, 2011, 05:59 AM
not103 is offline
Find More Posts by not103
not103's Avatar
Italy
Joined Mar 2009
I just bought this booster and I have a question about the wiring because on FV site they speak about a special connector to attach it directly to the FrSky module.
Can I use the cable provided into the kit between the FrSky module and the booster and the connect directly the antenna (wich one I already use for FrSky)??
Without power on booster the system have the same performance without it connected or the range will drop down?
not103 is offline Find More Posts by not103
Old May 30, 2011, 06:34 AM
mark hitchman is online now
Find More Posts by mark hitchman
Zephyr 66" Blunt
mark hitchman's Avatar
New Zealand
Joined Sep 2009
The range drops heaps with the booster connected and not powered.
Mine connected with the lead that came with the booster, just check the connector polarity to be sure but mine was right.
Mark
mark hitchman is online now Find More Posts by mark hitchman
Old May 30, 2011, 07:13 AM
not103 is offline
not103's Avatar
Italy
Joined Mar 2009
Mark
How I can check the connector polaity?
eg. verify that the center pin is connected to the same signal, can be the right test??
Old May 30, 2011, 07:39 AM
Zephyr 66" Blunt
New Zealand
Joined Sep 2009
Yeah, just check that pin goes into socket and you don't end up with 2 sockets together.
Mark
Old May 30, 2011, 04:24 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
RVOSDG5 should be in stock to the end of this week or early next week. Sorry no pdf yet, but it is basically the G4 with included inertial sensors, and few other changes//improvements.
About powering the booster, I use 6Volts. But heard some complaints about booster fail, so I guess using 5-5.5V could make it run less stressed. Mine works ok on 6V.
Old May 30, 2011, 04:26 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
Mark
I made that mistake on the antenna connector. Flew to more than 1km like that. Also the booster has to be powered, else it behaves like an attenuator.
Old May 30, 2011, 05:17 PM
Numpt1E is offline
Find More Posts by Numpt1E
Joined May 2009
Osd
Fantastic Flight, what camera and OSD were you using?
Numpt1E is offline Find More Posts by Numpt1E
Old May 30, 2011, 05:28 PM
Mikey-flies is online now
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
Does anyone know how the argtek works for boosting the received signals (telemetry)? From the specs I've seen it is <=12db for reception but that is a fairly wide range... any real-world reception experience?
Mikey-flies is online now Find More Posts by Mikey-flies
Old May 30, 2011, 07:21 PM
Elcheapo is offline
Elcheapo's Avatar
Joined Oct 2007
DX201 and RVOSD both from http://rangevideo.com.
Old Jun 03, 2011, 02:09 PM
Beruang is offline
Find More Posts by Beruang
Joined May 2011
1W Amplifier for Hobby King TX
FRsky, 1W amplifier, patch 14Dbi.
Flying thru storm clouds, but still 40km+.
Hi there Elcheapo,
What an extraordinary breakthrough you have done there. While most people are aiming to use UHF for LRS, you did your own way using 2.4G and managed to reach 40+ km away! Bravo!
I really don't know what an 1W amp looks like, where to get it, and how to connect it to a 2.4G TX. Could you please share some information?
And also, I'm waiting for my Hobby King 2.4Ghz 6Ch Tx being delivered. Can that 1W amp be connected to this HK TX I've bought?
I'm sorry to bother you with a lot of questions. Appreciate your help. Thanks.
Regards,
Beruang.
Beruang is offline Find More Posts by Beruang
Data R/C 2.4Ghz pushed to 20km Elcheapo FPV Talk 32 May 16, 2011 10:12 PM
Discussion Exceed RC 6ch 2.4ghz TX with LCD monitor? leithalweapon Electric Heli Talk 1 Mar 15, 2011 12:55 PM
Discussion 2.4GHz Rc range test teopbako FPV Talk 17 Mar 09, 2011 03:08 PM
Sold New Futaba 7C 2.4GHz FASST RC Radio $320 w/free shipping stwaller12 Aircraft - General - Radio Equipment (FS/W) 2 Mar 09, 2011 08:06 AM
Discussion Hitec 2.4GHz pushed back to Mid Sept./Late Oct. What's up Mike? Gyroguru Radios 0 Aug 25, 2009 02:17 PM
