Old Oct 13, 2013, 06:17 AM
darynxbcoupe is offline
Find More Posts by darynxbcoupe
Joined Sep 2010
Originally Posted by Scott C View Post
Delta 8 or factory Futaba receiver?
Hi Scott,
Factory receiver, I have tried a few times but cant work it out
darynxbcoupe is offline Find More Posts by darynxbcoupe
Old Oct 14, 2013, 06:36 AM
Scott C is offline
Find More Posts by Scott C
3D only by accident
Scott C's Avatar
United States, GA, Peachtree City
Joined Aug 2000
The reason I ask, I tried to bind my new Delta 8 to my 6J using the same procedure as the factory receiver, which by the way did not work. It might be worth trying to bind the factory receiver using the method of the Delta 8 receiver. Turn on transmitter, press and hold binding button on receiver, THEN turn on or add power to receiver.
Also, there is some chatter on RCGroups that people are having a hard time binding 2.4 near WiFi routers.
Scott C is offline Find More Posts by Scott C
Old Oct 15, 2013, 08:35 AM
numnutchris is offline
Find More Posts by numnutchris
numnutchris
Joined Sep 2009
Yes, in an RF smog environment it might bind faster when relocating the transmitter; mine does the same at home and sometimes has taken say 30sec to bind and establish the link. And the FrSky receivers have the "opposite" bind procedure than original stuff, with frsky you have to power on the Tx, press the RX button and then power on the Rx itself.
numnutchris is offline Find More Posts by numnutchris
Old Nov 09, 2013, 06:52 AM
Su-33 is offline
Find More Posts by Su-33
Su-27's Rule!
Su-33's Avatar
Philippines, NCR, Pasig City
Joined Nov 2012
anybody with a 6j, do you have problems with elevator to flaperon mixing?
Su-33 is offline Find More Posts by Su-33
Old Jan 21, 2014, 07:47 AM
spykez is online now
Find More Posts by spykez
Cá bhfuil an linn snámha?
spykez's Avatar
Joined Jul 2011
Originally Posted by SimonChambers View Post
Yes, protocol wise, fhss is similar to sfhss. Fhss sends one packet every 9ms (ch1-4), sfhsss sends two packets together (first packet ch1-4, second packet ch5-8) every 9ms. Also sfhss has failsafe and brownout failsafe - where as fhss doesn't.
If your transmitter and receiver both support it, I see no reason why you would use fhss over sfhss. Latency is the same between them.
Si.
Sorry to dig up this post but I got one of these with my trex btf, and found it incredibly nice.
My question is regarding the spec'ced frame rate of 6.8 ms. From your post, to my uneducated eye it seems like your saying the frame rate is 9 and 2 packets are sent with the full 8 channels in total divided up amongst them.
Could I ask how you got these numbers?
I don't fully understand the implications, does this mean the latency is always 9ms assuming no packet loss?
Isn't that better than FASST or possibly FASSTEST?
I'm a simple heli guy, if this radio is that fast, I'll convert my flybar helis to this, from a dsmx setup, possibly even my FBL's via s-bus. Don't need nothing fancy. I only need 6 channels v bar and 3g mrs. Maybe 7 with a brain, but I can still find an 8j.
Or am I misguided somehow? Trying to understand why I should pay more for an 8fg or 14sg.
spykez is online now Find More Posts by spykez
Last edited by spykez; Jan 21, 2014 at 08:05 AM. Reason: I'm a heli guy, for context.
Old Apr 15, 2014, 04:25 PM
realdyl75 is offline
Find More Posts by realdyl75
Joined Apr 2014
Anybody know how to program GPS mode and Attitude mode for the 2pos channel 5 switch on the top left shoulder?
realdyl75 is offline Find More Posts by realdyl75
Old Jul 10, 2014, 12:05 PM
zubayer_khan is offline
Find More Posts by zubayer_khan
Bangladesh, Dhaka Division, Dhaka
Joined Jun 2014
anybody can give me low price solution for rec. of futaba T6J?
zubayer_khan is offline Find More Posts by zubayer_khan
Old Jul 11, 2014, 05:58 PM
vicrider is offline
Find More Posts by vicrider
vicrider's Avatar
United States, OK, Claremore
Joined Jun 2012
http://www.valuehobby.com/radio-syst...y-delta-8.html
But futaba recievers for this radio are not expensive.
http://www3.towerhobbies.com/cgi-bin...?&I=LXARNZ&P=0
vicrider is offline Find More Posts by vicrider
Old Oct 28, 2014, 03:02 PM
Farwell is offline
Find More Posts by Farwell
United States, MI, Royal Oak
Joined Sep 2012
Futaba 6J Battery Charge Jack Problem
Just got a Futaba 6J four days ago from Tower Hobby. The charge jack doesn't work though the battery pack powers the Tx using either NiMH or AA alakaline batteries. Checked it with a battery charger and a volt meter with the switch off. Had the wire polarity right. Talked several times with Tech Service to no avail.
The response I got from several conversations with Tower and Futaba was to send it in under warranty (my expense $15) and they would look at it.
Had to order a charge jack ($9) and a new battery door ($4.90) from Futaba and they forgot to mention in the manual that you have to use only a Futaba NiMH battery pack at $48 a shot. So my $179 Tx actually cost $240.90 with $15 for return it will cost me $255.90!!!
Never, ever buy from Tower you can't return the merchandise like you can at a local hobby shop. I should know better so I think I deserve what I got.
Farwell is offline Find More Posts by Farwell
Old Mar 06, 2015, 09:41 PM
betterrcbuilder is offline
Find More Posts by betterrcbuilder
MorE t0Yz iz m0Re gO0dER
betterrcbuilder's Avatar
United States, CT, Hamden
Joined Aug 2013
I use BRAND name rechargeable. Double A's , charge them the night before I go to the field and easy and dependable. My 6J has been rock solid with zero issues. 48inch extreme flight
EXP's , 60" edge 540t, 50cc yak, what ever. ..this is a great radio. There are better looking
Transmitters...do you have to be handsome to be a good pilot? NO .
THE 6J IS AS GOOD AS MY 8J AND DX8 for almost all flying.
betterrcbuilder is offline Find More Posts by betterrcbuilder
Old Apr 23, 2015, 07:42 AM
John Hendry is online now
Find More Posts by John Hendry
John Hendry
Joined Oct 2013
Originally Posted by renatoa View Post
No need for jet or scale.
Try to fly a full scale glider with flaps or an acrobat with splitter elevator with T6.
They both need 6 channel only, but real channels, not crippled to not affect sales of big brothers.
Too bad that's true.... I need to spend big bucks to get my next Futaba radio but something has to pay for R&D and a night out on the town I guess but wonder how Futaba's quality will survive. They should focus on larger sales number with less profit in the entry level without removing what costs nothing to not put in... but rather keep in that people expect now. Happy with my old 72mhz gear and DX9 that's been dependable and looked this up because a new company in China is making their inexpensive quads that are very nice on paper FUTABA S-FHSS compatible which might be the best thing that's happened to Futaba in some time.
If I were a kid just starting out with less than 60 bucks in my pocket I know exactly without any hesitation what I'd buy and surprise it's not Spektrum compatible with 11ms timing... but rather Futaba S-FHSS with 6.6ms. I'm sure this has caught Futaba's interest in more ways than one.
John Hendry is online now Find More Posts by John Hendry
For Sale 2.4GHz 6 channel skyttech radio TS6i sonicboom24 Aircraft - General - Radio Equipment (FS/W) 8 Apr 28, 2011 09:29 AM
Sold Tactic™ TTX404 4-Channel 2.4GHz Spread Spectrum Radio System MERLIN V16 Aircraft - General - Radio Equipment (FS/W) 3 Apr 17, 2011 06:26 PM
Sold Futaba 2.4GHz FASST 3-Channel 3PMX Computer Radio System. crashdumby Cars - Motorcycles (FS/W) 4 Mar 15, 2011 07:31 PM
Sold Futaba 3PM-X 3-Channel 2.4GHz FASST Radio crashdumby Boats (FS/W) 0 Mar 13, 2011 08:13 AM
Sold Futaba 2.4GHz FASST 3-Channel 3PMX Computer Radio System.CHEAP!!!!! crashdumby Cars - Trucks and Parts (FS/W) 0 Mar 11, 2011 06:16 PM
