Old Dec 10, 2011, 12:36 PM
TimBle is offline
Find More Posts by TimBle
South Africa, WC, Cape Town
Joined Dec 2009
as I have said many times. The FrSKY FASSt clone is a very good product but in my experience under range test and in flight, I find the Genuine FASST to be more sensitive, and have greater range.
I still consider the FrSKY to be a viable option though and use about 6 of them currently in smaller planes that don't get too far away. My bigger gassers get genuine FASST.
TimBle is offline Find More Posts by TimBle
Old Jan 08, 2012, 05:34 PM
Scott C is online now
Find More Posts by Scott C
2D Pilot
Scott C's Avatar
United States, GA, Peachtree City
Joined Aug 2000
Radio Shack size H DC power plug seems to be a good fit. I solder up a charge chord using the Radio Shack plug. Works great so far; however these little plugs did not offer much strain relief for the wires.
http://www.radioshack.com/product/in...LAID=107593990
Next step down the road is to bypass the charge diode.
Scott C is online now Find More Posts by Scott C
Old Jan 11, 2012, 08:21 PM
burlyo is offline
Find More Posts by burlyo
Joined Jul 2008
**** There is an optional NiMh battery which can be used,
FUTM1473. To use this, you will need to purchase a new
battery door and charge lead from Futaba Services, see comments
HiTec Optic 6 will at least furnish you with the battery and charge jack
Futaba and Jr have had their day. Good Bye
burlyo is offline Find More Posts by burlyo
Old Jan 11, 2012, 09:32 PM
burlyo is offline
Joined Jul 2008
Originally Posted by DougV View Post
And if you use code # 014F3, you'll get an extra $25.00 off.
That's a $134.96.
Doug.
Add on the cost of the battery and charge jack from Futaba $76.00
Old Jan 12, 2012, 01:32 AM
TimBle is offline
Joined Dec 2009
Only if you require the battery and charger.
as has been said before, the market the radio is aimed at may not necessarily want a rechargable set up initially.
Considering the capability of the radio its a steal at the selling price and competitive once the rechargable battery and charger are added
Old Jan 12, 2012, 04:05 AM
numnutchris is offline
Find More Posts by numnutchris
numnutchris
Joined Sep 2009
The Tx is also available as set (Ive seen it in some European stores) with rechargeable pack and charger, priced almost as the old 6EX 2.4 was.
And as I probably will use mine during the indoor season, I removed the battery springs and a 5xAA high capacity NiMh pack fit (but had to solder it myself, 2x2 side by side plus the extra at the middle of one side). 2S LiPo was no problem as mentioned a few posts earlier, but I dont feel comfortable with that as the Tx probably will be left on the shelf during the outdoor season.
This is a good adequate entry level Tx, and a bit further, but remember its not FASST.
numnutchris is offline Find More Posts by numnutchris
Old Mar 01, 2013, 12:55 PM
2D Pilot
Scott C's Avatar
Joined Aug 2000
Has anybody had any frame rate issues while using analog servos with this radio? My Hitec HS-81 chatter/buzz around a bit on startup trying to find the center point. Also the HS-81 seem not to like this radio when the servos are assigned on an on/off switch like channel 5.
Thanks.
Old Mar 01, 2013, 01:43 PM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
Thanks.
Which receiver?
Is it just one HS-81, or do all your HS-81's do it?
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Mar 02, 2013, 05:27 PM
2D Pilot
Scott C's Avatar
Joined Aug 2000
Unfortunately, all my HS-81s exhibit this behavior. However, I am at peace with the solution. By increasing the volume of travel on the servo controlled by the transmitter’s channel 5 switch, the servos seem to be operating ok. It is just that a short travel hard throw by the channel 5 switch can “lose” the servo’s centering.
Old Mar 02, 2013, 05:54 PM
danny.act is offline
Find More Posts by danny.act
Electrif(r)ied nitroman
danny.act's Avatar
BelgiŽ, Vlaams Gewest, Putte
Joined Jun 2004
Unfortunately, all my HS-81s exhibit this behavior. However, I am at peace with the solution. By increasing the volume of travel on the servo controlled by the transmitterís channel 5 switch, the servos seem to be operating ok. It is just that a short travel hard throw by the channel 5 switch can ďloseĒ the servoís centering.
Wich receiver are You using (model type please) ?
danny.act is offline Find More Posts by danny.act
Old Mar 02, 2013, 07:54 PM
2D Pilot
Scott C's Avatar
Joined Aug 2000
R2006GS Receiver
Old Mar 03, 2013, 03:18 AM
danny.act's Avatar
Joined Jun 2004
R2006GS Receiver
On the R2006GS You've got settings for "high speed" and "normal" mode for servo's.
Are You shure it's in "normal" mode for the HS-81 servo's when binding the receiver?
Normal and High-Speed Modes:
Normal mode frame rate is (FHSS/S-FHSS) 13.63ms and accepts any
type of servos or peripherals.
High-Speed mode (in 4PL tx only), with an output of 6.8ms accepts
digital servos including the BLS series and most peripheral
equipment such as brushless ESCs
Old Mar 03, 2013, 05:12 AM
numnutchris
Joined Sep 2009
Is there any reference on rx to servo PWM output frame rate? Ive found no way to swap the 2006GS output between digital (HS) or normal modes?
See eg. the 6J manual p13; theres no led status on HS mode either (as with fasst RXes) (If linked to a 4PL it wouldnt work with the 6J, right?)
Old Mar 03, 2013, 05:30 AM
danny.act's Avatar
Joined Jun 2004
You should find it in the "para" (parameter) menu of Your transmitter.
The receiver auto adapts the selected mode from Your transmitter when "binding" the receiver to transmitter.
The R2006GS auto-adapts to the transmission mode selected, whether it’s FHSS or high-speed S-FHSS mode.
Take a look under the Helicopter set up part:
http://www.rcgroups.com/forums/showthread.php?t=1438836
Old Mar 03, 2013, 06:26 AM
numnutchris
Joined Sep 2009
The R2006GS auto-adapts to the transmission mode selected, whether itís FHSS or high-speed S-FHSS mode.
Transmission mode doesnt change the Rx PWM output frame rate. Measured eg. CH1 in both SHFSS and FHSS modes (and yes, remembered to reboot in between). Left/first: FHSS, Right/last: S-FHSS
For Sale 2.4GHz 6 channel skyttech radio TS6i sonicboom24 Aircraft - General - Radio Equipment (FS/W) 8 Apr 28, 2011 10:29 AM
Sold Tacticô TTX404 4-Channel 2.4GHz Spread Spectrum Radio System MERLIN V16 Aircraft - General - Radio Equipment (FS/W) 3 Apr 17, 2011 07:26 PM
Sold Futaba 2.4GHz FASST 3-Channel 3PMX Computer Radio System. crashdumby Cars - Motorcycles (FS/W) 4 Mar 15, 2011 08:31 PM
Sold Futaba 3PM-X 3-Channel 2.4GHz FASST Radio crashdumby Boats (FS/W) 0 Mar 13, 2011 09:13 AM
Sold Futaba 2.4GHz FASST 3-Channel 3PMX Computer Radio System.CHEAP!!!!! crashdumby Cars - Trucks and Parts (FS/W) 0 Mar 11, 2011 07:16 PM
