Old Nov 11, 2011, 08:59 AM
Crackroll.com Editor
CSpaced's Avatar
Oak Ridge, NC
Joined Jun 2006
It might be simpler to just charge the battery out of the transmitter, I do it with my lipo battery on another transmitter all the time.
CSpaced is offline Find More Posts by CSpaced
Old Nov 11, 2011, 09:21 AM
2.0
Scott C's Avatar
United States, GA, Peachtree City
Joined Aug 2000
I am a little leery of placing cycles of plugging and unplugging the connection between the battery and the TX. The wires and connectors are just too small the handle this treatment in my opinion.
Scott C is offline Find More Posts by Scott C
Old Nov 13, 2011, 01:43 AM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Or you could add an adaptor / connector in between (such as 2mm bullets), so that we wont put too many cycles of plugging and unplugging on the stock connector and wire.
Vien
vienquach is offline Find More Posts by vienquach
Old Nov 15, 2011, 07:53 AM
numnutchris
Joined Sep 2009
Whats the difference between S-FHSS and FHSS? Only things Ive found are the Rx incuded (at least the one I got) only operates 4 channels in FHSS and takes a little longer to bind. Are there eg. range issues or supposed to be some lightweight 4CH indoor Rx:es?
numnutchris is offline Find More Posts by numnutchris
Old Nov 15, 2011, 08:40 AM
DougV's Avatar
United States, FL, Miramar
Joined Dec 2007
The only difference is low latency with the S-FHSS receivers.
http://futabarc.com/technology/fhss.html
Doug.
DougV is offline Find More Posts by DougV
Old Nov 15, 2011, 03:20 PM
numnutchris
Joined Sep 2009
Doug.
The linked page says nothing about differences between FHSS/S-FHSS; both "include extremely low latency, exceptionally fast frame rates, transmitters with no external antennas and low-cost receivers with Easy Link convenience."
Old Nov 15, 2011, 03:59 PM
DougV's Avatar
Joined Dec 2007
lets try again: http://www.futaba-rc.com/systems/futk6000.html
"The R2006GS auto-adapts to the transmission mode selected, whether it’s FHSS or high-speed S-FHSS mode"
Doug.
Old Nov 27, 2011, 07:42 AM
Pro Bro # 2398
GassPasser's Avatar
BoonVegas, Indiana
Joined Dec 2005
139 bucks cyber monday....WOW ! at Tower.
GassPasser is offline Find More Posts by GassPasser
Old Nov 28, 2011, 04:24 PM
Joined Oct 2010
hello.. can i use lipo 2s in this transmitter?
lambrisl is offline Find More Posts by lambrisl
Old Nov 28, 2011, 05:57 PM
numnutchris
Joined Sep 2009
I put a 2S1600, but added three 1N5404 diodes in series with the pack to comply with the battery warning (set to 5V).
Old Nov 29, 2011, 10:05 AM
Joined Oct 2010
if i don't used the diode will have problem?
Old Nov 29, 2011, 12:07 PM
2.0
Scott C's Avatar
Joined Aug 2000
I am hoping that Frsky will offer a S-FHSS receiver soon.
Old Nov 30, 2011, 07:48 PM
numnutchris
Joined Sep 2009
Im not sure as I did not check the PCB/power supply on mine but you might get problems as the addendum at
http://manuals.hobbico.com/fut/6j-tech.pdf
states you need a special cable even with eg. 8FG that runs on 2S.
Mee too - meanwhile I hooked up a V8HT DIY to be able to use the small V8R4 (FrSky ACCST 4ch Rx:es) for small indoor foamies. But I had to cut the schottky diode as the PPM level otherwise would be too low for the module to work. The con was (is) my 6J now has an external antenna too...
Old Dec 08, 2011, 10:07 AM
Romania, Dolj, Craiova
Joined Sep 2007
Why, aren't S-FHSS receivers cheap enough ?
renatoa is online now Find More Posts by renatoa
Latest blog entry: JRSky - birth of a dream radio
Old Dec 09, 2011, 09:22 AM
2.0
Scott C's Avatar
Joined Aug 2000
Not really when a Frsky TFR6 FASST 7ch can be had for only $23.40.
For Sale 2.4GHz 6 channel skyttech radio TS6i sonicboom24 Aircraft - General - Radio Equipment (FS/W) 8 Apr 28, 2011 09:29 AM
Sold Tactic™ TTX404 4-Channel 2.4GHz Spread Spectrum Radio System MERLIN V16 Aircraft - General - Radio Equipment (FS/W) 3 Apr 17, 2011 06:26 PM
Sold Futaba 2.4GHz FASST 3-Channel 3PMX Computer Radio System. crashdumby Cars - Motorcycles (FS/W) 4 Mar 15, 2011 07:31 PM
Sold Futaba 3PM-X 3-Channel 2.4GHz FASST Radio crashdumby Boats (FS/W) 0 Mar 13, 2011 08:13 AM
Sold Futaba 2.4GHz FASST 3-Channel 3PMX Computer Radio System.CHEAP!!!!! crashdumby Cars - Trucks and Parts (FS/W) 0 Mar 11, 2011 06:16 PM
