Old Jul 04, 2011, 10:58 PM View Post
hatsglasses
A moderator felt this post violated the following rule: Excessive Advertising (Spam). Show it to me anyway.
Old Jul 05, 2011, 03:46 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Reported
AndyOne is offline Find More Posts by AndyOne
Old Jul 12, 2011, 08:01 PM
CSpaced is offline
Find More Posts by CSpaced
Team Futaba
CSpaced's Avatar
Oak Ridge, NC
Joined Jun 2006
A new 6 channel micro receiver has been announced that is S-FHSS compatible.
The super small and lightweight R21065GF 2.4GHz 6-Channel Micro Receiver from Futaba gives the option of High Speed mode with digital servos and fail safe on all channels. It can handle high voltage ranges (4.8-7.4V) and is compatible with all Futaba FHSS/S-FHSS transmitters.*
FHSS/S-FHSS is not compatible with FASST systems.
Specifications:
Size: 1.5 x .85 x .40 inches
Weight: 4g with case
FUTL7605 R2106GF 2.4GHz 6 Ch. Micro Receiver Retail:$39.99 Street:$34.99
The Futaba R2106GF Micro Receiver will be available late July.
CSpaced is offline Find More Posts by CSpaced
Old Jul 12, 2011, 08:27 PM
vienquach is offline
Find More Posts by vienquach
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Cool !!
Vien
vienquach is offline Find More Posts by vienquach
Old Jul 12, 2011, 09:56 PM View Post
jack lj
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Old Jul 13, 2011, 02:27 PM
Axefly is online now
Find More Posts by Axefly
South Africa
Joined Feb 2010
no sbus features specifically for their gcy750? i get it they want you to shelve out more dollar for the 7fg right ? .... Riiiiight.....
Axefly is online now Find More Posts by Axefly
Old Oct 12, 2011, 12:39 PM
Scott C is offline
Find More Posts by Scott C
3D only by accident
Scott C's Avatar
United States, GA, Peachtree City
Joined Aug 2000
I am considering this radio as a replacement for my 72 Mhz. 6EX. I was wondering about the battery requirement of the 6J transmitter as well and found this interesting article.
http://www.eznec.com/Amateur/1.5_vs_..._Batteries.pdf
Scott C is offline Find More Posts by Scott C
Old Oct 29, 2011, 01:02 PM
jpurcha is offline
Find More Posts by jpurcha
jpurcha's Avatar
Canada, MB, La Salle
Joined Sep 2004
I'm going to wait and see what the new 8J has to offer before I upgrade my 6EAX (72MHZ) to 2.4 GHZ.
Jim
jpurcha is offline Find More Posts by jpurcha
Old Oct 29, 2011, 07:17 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Interesting data. It is a good guess that the Tx operates at 3.3V. If it uses the cheapest possible regulator it will need at least 5.3V input or with an LDO regulator, 4.3V. With only four cells that corresponds to 1.33V per cell or 1.08V per cell.
Now consider that 500mA is a high drain for an AA cell and that modern 2.4GHz Tx typically draw less than 150mA and many less than 100mA. So it is worth taking a look at some data that compares performance at something like 100mA. Note that "DC" is Duracell Copper-top. The other curves are other brands and the "ET" is an exotic Energizer Titanium.
Those curves make it seem likely they are using an LDO regulator or else a 4S alkaline pack would not give adequate run time. So if that is the case then they only need 4.3V input and it does seem likely that a good quality 4S NiMH pack would perform as well or better than a 4S alkaline pack.
I guess we won't know for sure until someone does some testing for us to determine the current draw and dropout voltage of this particular Tx.
kgfly is offline Find More Posts by kgfly
Old Nov 03, 2011, 09:34 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
The manual for the T6J states that the low voltage warning is to be set at 4.2V when using AA Alkalines. If the low voltage warning goes off at 4.2V, then the transmitter should work even lower.
What is not answered in the manual, is whether there is any other setting than the 4.2V for Alkaline, or 5V for 5 cell Nimh. The 4.2V setting would be a bit low for 4 cell Nimh, and the 5V setting would drive you nutz with only 4 Nimh cells installed
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Nov 03, 2011, 09:40 AM
Scott C is offline
3D only by accident
Scott C's Avatar
Joined Aug 2000
Ok, I am in. Tower Hobbies has a two day sale that started yesterday on the 6J with four servos 159.96!
http://www3.towerhobbies.com/cgi-bin...&I=LXAVSW&P=ML
Old Nov 03, 2011, 09:52 AM
pilotpete2's Avatar
Joined Jun 2004
Such a deal
Very good price!
Pete
Old Nov 03, 2011, 10:19 AM
kgfly is offline
Joined May 2006
That is useful info, thanks.
Perhaps, but there is no way to know how much lower. Also, 4.2V implies 1.05V per cell, which is extremely close to absolutely dead flat for alkaline cells so if the warning goes off, I wouldn't be doing anything but landing real soon.
If you look at the discharge curves I posted above, 1.05V/cell is just as useful for good quality 2000mAh NiMH as it is for good quality alkaline cells. In both cases the cell is over 90% discharged and close to the point where the voltage goes over the knee.
Based on the figures, you could safely use four Eneloop AA cells instead of Duracell alkaline ones and have almost identical run time.
Old Nov 03, 2011, 11:20 AM
DougV is offline
Find More Posts by DougV
DougV's Avatar
United States, FL, Miramar
Joined Dec 2007
And if you use code # 014F3, you'll get an extra $25.00 off.
That's a $134.96.
Doug.
DougV is offline Find More Posts by DougV
Old Nov 11, 2011, 08:41 AM
Scott C is offline
3D only by accident
Scott C's Avatar
Joined Aug 2000
Honey I shrunk the charging port.
The charging port on this transmitter is micro. I am sure Futaba changed this to keep folks from using a wall-wart eight cell charger on just four cells. I will probably try to match the port to a coaxial plug at the local computer repair shop. Coaxial plugs from Radio Shack have such horrible reviews, I am afraid to chance it with my equipment.
For Sale 2.4GHz 6 channel skyttech radio TS6i sonicboom24 Aircraft - General - Radio Equipment (FS/W) 8 Apr 28, 2011 09:29 AM
Sold Tactic™ TTX404 4-Channel 2.4GHz Spread Spectrum Radio System MERLIN V16 Aircraft - General - Radio Equipment (FS/W) 3 Apr 17, 2011 06:26 PM
Sold Futaba 2.4GHz FASST 3-Channel 3PMX Computer Radio System. crashdumby Cars - Motorcycles (FS/W) 4 Mar 15, 2011 07:31 PM
Sold Futaba 3PM-X 3-Channel 2.4GHz FASST Radio crashdumby Boats (FS/W) 0 Mar 13, 2011 08:13 AM
Sold Futaba 2.4GHz FASST 3-Channel 3PMX Computer Radio System.CHEAP!!!!! crashdumby Cars - Trucks and Parts (FS/W) 0 Mar 11, 2011 06:16 PM
