This thread is privately moderated by wamsy55, who may elect to delete unwanted replies.
Old May 12, 2011, 09:53 PM
wamsy55 is offline
Find More Posts by wamsy55
Fly Low
wamsy55's Avatar
Nashville , Tennessee
Joined Jan 2009
Mini Stormbach 20" V2
Here is the Mini Stormbach my friend Stormdriverone made ...
As you can see if flies very well and it very fun !
He added some right thrust and moved the battery and it flies even better than the original.
Mini S-bach ... Otherwise known As A Stormbach ... (4 min 5 sec)
wamsy55 is offline Find More Posts by wamsy55
Old May 13, 2011, 12:02 PM
dleep is offline
Find More Posts by dleep
Dleep
dleep's Avatar
Ft. Wayne, Indiana
Joined Oct 2006
nice
That fly's very well for such a small plane. Great job!
dleep
dleep is offline Find More Posts by dleep
Old May 13, 2011, 07:06 PM
SD One. is offline
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
Thanks! I almost gave up on it.
The initial build was too heavy but I managed to get the weight down to 3.4 oz fully loaded using small but standard parts from the LHS. No ultra micro gear needed! Then the 10g Hobbypartz motor I ordered for it sucked horribly and started to fry on the first run. Replaced that with the Rimfire 200. Experimented with various props to find a balance of thrust, speed and torque that worked well with it. Finally, the re-balancing of electronics and battery against the torque + thrust angle adjustment were the final steps to get it to fly like that.
There is a video, shot right before that one, of it doing rollers right into the weeds because Wamsy couldn't keep up with the insane roll rate. I dropped the throws to around 80% and then we shot the video above.
SD One. is offline Find More Posts by SD One.
Old May 13, 2011, 11:08 PM
wamsy55 is offline
Fly Low
wamsy55's Avatar
Joined Jan 2009
It would probably be better next time to lower the aileron rate even lower ...
Old May 14, 2011, 02:30 AM
SD One. is offline
USA, TN, Gallatin
Joined Aug 2009
I need triple rates!
But I bought a plane instead.
Discussion TeamRC's Hawk Talon Mini V2 Impressions impostor Coaxial Helicopters 36 Apr 28, 2011 12:34 PM
Sold TP 5S 20/40c 5000mah Pro Lite V2 65.00 Shipped boatdoc Aircraft - Electric - Batteries & Chargers (FS/W) 2 Apr 10, 2011 11:13 AM
Sold Lot of mini and micro servos. $20 shipped! flyinjrc74 Aircraft - General - Radio Equipment (FS/W) 1 Mar 12, 2011 08:24 AM
