Old Mar 06, 2013, 08:36 AM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
Yeah I sanded a small area for the test patch, then removed it later.
vanderbrander is offline Find More Posts by vanderbrander
Old Mar 07, 2013, 06:55 PM
Doug Bateman is offline
Find More Posts by Doug Bateman
Doug Bateman's Avatar
Swarthmore, PA 19081
Joined Dec 2004
The trailing edges on the wing are .25" thick , the stab/elev. is .1875" = drag. Add that to whats going on in the intake ducting and you can see some steps could be taken to clean up the airframe aerodynamically. I most likely will do some glasswork on the bottom. As far as dings and seams on the upper surface i think i will fill and paint. Are model master paints ok on this foam?
Doug Bateman is offline Find More Posts by Doug Bateman
Old Mar 07, 2013, 08:39 PM
Joined Nov 2010
Yep shes a big draggy airframe all right but flies really nice. i think mine tops out around 110-115mph but I didn't buy it as a speed demon and to be honest it looks better flying scale speeds rather than flat out.
I agree the ducting could do with some significant improvements and would probably make a noticable difference to the fan efficiency.
Any acrylic based paint that works on EPS will work on this.
Post some pics of your build when you get a chance.
Old Mar 08, 2013, 07:53 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
i thinned out the trailing edges on mine, mostly for looks lol. mine does 115-120 or so, on about 2700W
corsair nut is offline Find More Posts by corsair nut
Old Mar 08, 2013, 08:33 AM
Joined Dec 2004
I'm just trying to extend flying time more so than increasing the top end. If i can cruise at lower power settings it will pay dividends. I think i'm going to order some hysol today for assembly. If i tape pieces together will the paint pull free from the foam?
Acylic paint. So i'll be brushing and wet sanding to remove brush marks. I don't have a spray gun. All my work has been spray can.
CN, so you just sanded the trailing edges? I expect a filler of some kind is needed after sanding. I was considering balsa strips glued on and sanded to shape.
Old Mar 08, 2013, 06:14 PM
tehachapi, CA
Joined Jan 2006
i just sanded them down, though balsa would be desired. ive got 4-5 coats of wbpu to smooth it out.
Old Mar 15, 2013, 08:39 AM
Joined Dec 2004
I have decided that foam just isn't for me. Bungee ops would be out of the question on this model. I have a local buyer picking it up tonight. I will find a home for my Stumax 100 somewhere...
Thanks for the help guys...
Old Mar 15, 2013, 11:26 AM
Joined Dec 2004
If and when they skin this bird or do a full composite i am there...
Old Mar 16, 2013, 11:18 AM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Dude your missing out. Mine is a stock foam airframe on 2400 watts and I fly for 5 minuets and was radared at 118 on a flat pass. It's a great speed for this type of plane. I have been flying mine for two years now and have over 125 flights on it and it's a blast!!!
1.) The plane is barrel of fun to fly bone stock.
2.) Your not putting it on a judges table, don't get anal over it. If you get caught up in all the insignificant trivial trailing edges are too thick stuff or if I can gain an extra 30 seconds of flight time you will drive yourself crazy.
3.) Build it, fly it, and have a blast.!!!!
Here is a short video of mine to show how nice this plane can fly.
T-33 (1 min 41 sec)
falcon5 is offline Find More Posts by falcon5
Old Mar 16, 2013, 03:53 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Hi Doug,
I took the T-33 out for a couple flights this morning just for YOU
At 1:17 I do a half throttle pass for ya so you can see what the speed of this T-33 is at about half throttle.
Andy
T-33 flight 31613 (2 min 11 sec)
Old Mar 16, 2013, 04:42 PM
Joined Dec 2004
Andy, thanks man... i did sell the jet, but with the idea i might order the plain white version and glass it. But right now i seem to be having a problem motivating myself to do any finishing work. Been this way for a while. Maybe when the weather breaks for good... The vids are sweet!
Old Mar 16, 2013, 08:29 PM
Joined Nov 2010
Wow Andy's really a great guy!! Who else would go to all the trouble of getting out their favourite plane and go fly it "just for you" Doug.
Now that's a true friend
Old Mar 16, 2013, 10:45 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
The sacrifices I make
Old Mar 16, 2013, 10:55 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
looking forward to the Falcon and Nut show at Vegas this year
AIR SALLY is offline Find More Posts by AIR SALLY
Old Mar 17, 2013, 12:04 PM
Joined Nov 2010
Might try that one on my wife...."Honey a guy REALLY needs me to go fly my T-33 for him...."
Discussion RC Lander F 16 build thread VA174 Foamy EDFs 2916 Jul 20, 2016 03:29 PM
Discussion Radical RC Stick 400 Build Thread~~~Now with Video Carnifax Electric Plane Talk 186 Aug 20, 2014 08:55 PM
New Product "afterburner" upgrade set for rc lander f16 cmulder Foamy EDFs 0 Mar 05, 2011 05:22 PM
Wanted RC Lander Retracts 4 T45 CMP josephcharles Aircraft - General - Miscellaneous (FS/W) 0 Mar 03, 2011 11:35 AM
Build Log The Zip 33 Build thread is linked here KJMDES Slope 0 Jan 26, 2010 04:03 PM
