Old May 18, 2011, 07:35 PM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
paypal waiting to sent for this board!
daign is offline Find More Posts by daign
Old May 19, 2011, 02:42 AM
Av8Chuck is offline
Find More Posts by Av8Chuck
Av8Chuck's Avatar
USA, CA, Thousand Oaks
Joined Feb 2010
I wouldn't call the Quadrino board 'plug-n-play' but it CAN be... since we are all flying the same frame, it could be sent to you pre-programmed and you'd just plug it in and fly. This was from Tom.
I'd like to purchase the Advanced version of this card, can you pre-program the controller for me so I could replace my GU344?
Av8Chuck is offline Find More Posts by Av8Chuck
Old May 19, 2011, 02:49 AM
chevota is offline
Find More Posts by chevota
United States, CA, Rancho Cucamonga
Joined Feb 2011
Mine arrived "pre-programmed" with multiwii1.7. It flew but all values had to be reduced via the GUI for my taste. I think you're local to me if you need any help with settings.
chevota is offline Find More Posts by chevota
Old May 19, 2011, 06:04 AM
Flying-Monkey is offline
Find More Posts by Flying-Monkey
Did you get it on video?
Flying-Monkey's Avatar
United States, FL, Ponce De Leon
Joined Nov 2005
Where is the gui download?
Flying-Monkey is offline Find More Posts by Flying-Monkey
Old May 19, 2011, 07:12 AM
techspy is online now
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
PM'ed for Paypal request, Ready to buy! (I know you are busy so whenever you can get to it)
techspy is online now Find More Posts by techspy
Old May 19, 2011, 07:30 AM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
Here is the link for the GUI download. http://code.google.com/p/multiwii/so...se/#svn%2Ftags
tc3wins is offline Find More Posts by tc3wins
Old May 19, 2011, 08:00 AM
Joined Nov 2005
thank you!
Old May 19, 2011, 08:02 AM
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Can someone point to the "install instructions" for the software? I unzipped it and tried to run the exe but I get an error from Java Virtual Machine Launcher "could not find the main class. program will exit".
I made sure I have the latest Java updates.
Old May 19, 2011, 01:58 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Question for those of you who have tested the Baro functionality on the Adv board. Did you have the board covered with a dome or container?
Indoors, Outdoors?
cactus is offline Find More Posts by cactus
Old May 19, 2011, 07:40 PM
daign is offline
daign's Avatar
Joined Feb 2011
Indoors, Outdoors?
I'll let you know when I get mine
Old May 19, 2011, 08:12 PM
seadog1967 is offline
Find More Posts by seadog1967
Waiting for my Medication
seadog1967's Avatar
USA, MA, West Springfield
Joined Nov 2010
Indoors, Outdoors?
Ok I have a dome/ tupperware cover over mine. The baro does not hold it's height good at all. Fluctuates 5-6 ft. very erratic. So I drilled eight holds in the top to vent it more. Same thing did not make a difference and my cover has some space on the bottom so the board is not sealed really. I took the cover off once and made no difference.
seadog1967 is offline Find More Posts by seadog1967
Old May 19, 2011, 08:20 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Actually that sounds about standard for the altitude holds on different controllers....1-2meters/3-6feet of variance. I saw some videos of the MK controller with altitude hold and it varied too...but not all that much. Of course those also will set you back thousand(s) of dollars.
I bought a 'basic' board and might add a BM085 baro later on, but for now I'm after more 'sports' type learning to fly. I've got a different $$$ controller for the 'fancier' stuff...which also varies with altitude hold.
Vantasstic is offline Find More Posts by Vantasstic
Old May 19, 2011, 08:22 PM
Joined Nov 2005
I wonder just how sensitive the barometers are. It seems to be asking a lot of a device like that to be accurate to such a small degree, when what it is doing is measuring air pressure. How much more does air weigh within a 6 foot span?
Old May 19, 2011, 08:29 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Good point...not much difference to be sure. GPS altitude is notorious for being even worse. Down low the normal altitude drift is probably more of a concern/annoyance. Up higher and you probably wouldn't even notice that amount of drift.
Old May 19, 2011, 08:35 PM
seadog1967's Avatar
Joined Nov 2010
I'm looking at it more for photography. The baro would be nice to have working better but I like the mag a lot for yaw hold. so combo of the auto level and the mag is good enough for me to have spent the extra on the full board. When they work out the software stuff then I'll just enable again.
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
