Old Jan 09, 2013, 10:26 PM
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Originally Posted by mark_q View Post
Entropy?
Dollars per hour into China through the RC channel?
Just a guess...
The program that will coralate all the data has not been released!
DoctorAudio is offline Find More Posts by DoctorAudio
Latest blog entry: Composite 200 mm micro quad!
Old Jan 10, 2013, 04:32 AM
Australia, VIC, Melbourne
Joined Nov 2012
Originally Posted by TennesseePilot View Post
Has anyone tried the SD card to record gps data yet. I installed a card today and gave it a flight. The sequence lights stutter about every 4 seconds and I guess thats when it writes out to the file. Each line is formatted like this:
$32098823,Sats,Latitude,-Longitude,Altitude
I don't know what the first piece of data represents. It increases with each card write. Anyone know?
Jerry....
Timestamp or cycle count?
Vertikar is online now Find More Posts by Vertikar
Old Jan 10, 2013, 01:08 PM
Joined Apr 2011
Yes, first field is milliseconds since the unit powered on. If you are getting stuttering on the lights then your sd card is probably not fast enough. Stick with the good brands like Lexar and SanDisk. They implement the sd card specs properly. There may be other good brands too. Surf the net for the best sd cards for write speed, that's what matters. The SanDisk I have writes the data to disk in 12milliseconds worst case - and the write occurs every 5 secs like you say. 12ms is way to small to notice.
Jerry....
guru_florida is offline Find More Posts by guru_florida
Old Jan 10, 2013, 02:02 PM
Milwaukie , Oregon
Joined Feb 2003
look at this!
this a a U-blox,I think!
Quadrino GPS Position Hold (5 min 53 sec)
Old Jan 10, 2013, 04:23 PM
Joined Nov 2010
Need help with PID and snsors
I'm new to quads, I just finished my 650 next level quad with quadrino zoom v2 with 2.1 firmware. I had a successful hover but I need help setting the PID rates and I need help with the sensors. First, How do you change the PID rates, do you change them in the config. program or somewhere else, also can you have different rates for different switch positions. Finally what sensor should I have on in any given switch position. I do have the sensors on a three position switch.
mfoster12 is offline Find More Posts by mfoster12
Old Jan 10, 2013, 04:45 PM
Milwaukie , Oregon
Joined Feb 2003
Anyone needing help!
Webex is open now and will be open for about a hour starting now!
Password is always "quad"
Go to flyingeinstein.webex.com
Old Jan 10, 2013, 05:53 PM
Joined Jun 2010
The SD card I got is a 4g SanDisk. I remembered that this was discussed on the webex last sunday and SanDisk and Lexar were mentioned as fast units. I'll make a small video tomorrow showing the light sequence when it's writing...
Jerry B
TennesseePilot is offline Find More Posts by TennesseePilot
Old Jan 10, 2013, 05:55 PM
Youtube Johnbrum26
Mckinney,TX
Joined Oct 2010
Originally Posted by DoctorAudio View Post
look at this!
http://youtu.be/YxQHqkKVpZ4
nice work as alway doc.
Killab is offline Find More Posts by Killab
Old Jan 10, 2013, 05:56 PM
Milwaukie , Oregon
Joined Feb 2003
Not mine Killab!
I am trying to chat with this guy, on Youtube!
Old Jan 10, 2013, 05:57 PM
Youtube Johnbrum26
Mckinney,TX
Joined Oct 2010
Oh well his is holding awesome, Yours in not far behind from what i saw on your video
Old Jan 10, 2013, 07:08 PM
Joined Jun 2010
Hey Doc. Not a U-Blox. Its my quadrino zoom with the quadrino gps running multiwii dev version r1240...
Jerry
look at this!
Old Jan 10, 2013, 08:07 PM
"you'll play to live "
Alwayscrash's Avatar
Canada, QC, Montreal
Joined Sep 2009
MultiWii dev version r1311 has lot of feature updated.:
- baro Alt from mahowik (new functions to come, noted)
- baro calibration and some baro mods from Sebbi
- new task scheduler for a better computation time repartition
- better Ublox code detection
- HORIZON mode (mix between ACRO & ANGLE)
- ANGLE mode is the old LEVEL mode
- every UART for everything on MEGA
- cool GUI enhancement from magnetron
- spektrum bind button for spektrum receiver (Danal)
- telemetry cosmetic
- bug correction for servos on MEGA
- failsafe is more robust
- variometer
- mag gain calibration improvement for HMC5883L
- GPS MKT binary parser
- GPS forward predictive filter
//#define QUADRINO // full FC board 9DOF+baro board from witespy with BMP085 baro <- confirmed by Alex
//#define QUADRINO_ZOOM // full FC board 9DOF+baro board from witespy second edition
//#define QUADRINO_ZOOM_MS// full FC board 9DOF+baro board from witespy second edition <- confirmed by Alex
Board orientation shift ************************/
/* If you have frame designed only for + mode and you cannot rotate FC phisycally for flying in X mode (or vice versa)
you can use one of of this options for virtual sensors rotation by 45 deegres, then set type of multicopter according to flight mode.
Check motors order and directions of motors rotation for matching with new front point! Uncomment only one option! */
//#define SENSORS_TILT_45DEG_RIGHT // rotate the FRONT 45 degres clockwise
//#define SENSORS_TILT_45DEG_LEFT // rotate the FRONT 45 degres counterclockwise
//#define NMEA
//#define UBLOX
//#define MTK_BINARY16
//#define MTK_BINARY19
//#define INIT_MTK_GPS // initialize MTK GPS for using selected speed, 5Hz update rate and GGA & RMC sentence or binary settings
//#define GPS_PROMINI_SERIAL 57600 // Will Autosense if GPS is connected when ardu boots
anyone had tried yet?
AC
Alwayscrash is offline Find More Posts by Alwayscrash
Old Jan 10, 2013, 08:45 PM
Milwaukie , Oregon
Joined Feb 2003
What no
//#define Quadrino 20hz Super fast GPS?
Old Jan 10, 2013, 08:49 PM
Milwaukie , Oregon
Joined Feb 2003
blue light still doesn't work?
Old Jan 10, 2013, 09:06 PM
Joined Sep 2009
haha, me too! This one i like most:
Assisted AcroTrainer **********
/* Train Acro with auto recovery. Value set the point where ANGLE_MODE takes over.
Remember to activate ANGLE_MODE first!...
A Value on 200 will give a very distinct transfer */
#define ACROTRAINER_MODE 200 //
"Amazing to watch a quad come tumbling down with minimum throttle, and then level itself automatically, just before hitting the ground"
Bledi has a video on Acrotrainer:
Maiden Multwii Acrro Trainer Mode (0 min 45 sec)
Use this and feel lilke Warthox for a while.
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro RTF 14 Aug 05, 2007 10:44 AM
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 6 Dec 02, 2006 12:34 AM
