Old Jan 04, 2013, 08:43 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
I just want to say, nice work there!
Pull up at his house and then he say check this out.
DoctorAudio is offline Find More Posts by DoctorAudio
Old Jan 04, 2013, 09:49 PM
Sniperp is offline
Find More Posts by Sniperp
FPV addict
Joined Mar 2011
After putting the gimbal mode on my quadrino in getting a steady, and rapid, up count of I2C errors as well. I never noticed this when I used the board to fly my quad but now it sticks out.
Sniperp is offline Find More Posts by Sniperp
Old Jan 04, 2013, 09:56 PM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Ok fellow Quadrinoites, here is the 10" prop info you have been waiting for! The picture below is the charted results.of todays bench testing.
Couple explanations here:
  • I didn't include all significant digits for readability
  • The weight includes a bushing to 5mm
  • The column "T/100W" is a measure of thrust per 100 watts and represents an efficiency measure.
  • The column "Runtime" is a theoretical time a 3000mah pack would last at the listed steady state. (another efficiency measure)
  • The top chart is normalized on voltage at 11.7 volts
  • The bottom cart is normalized on a thrust of 16oz
Enjoy!
Pic of the players:
mark_q is online now Find More Posts by mark_q
Latest blog entry: FX-61 Phantom #2 Build Pages
Old Jan 05, 2013, 10:39 PM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Question!
Recently I re-flashed with the 2.1 firmware. I selected quadrino Zoom in the sketch and the Nano ATmega 328 in Arduino. It flys fine although I'm still trying to get the GPS-HLD to settle down but since the re-flash the Yellow Led for arming blinks when not armed and is solid when armed. Is this correct? I don't remember this LED ever blinking before.
Thanks for any help
Old Jan 05, 2013, 11:02 PM
RC911 is offline
Find More Posts by RC911
8 bit is more fun
RC911's Avatar
Norway, Troms, Tromsų
Joined Aug 2012
Originally Posted by mark_q View Post
Question!
Thanks for any help
As far as I know, the yellow LED should only flash when the board is unleveled.
If you get a lot of I2C errors in the GUI program you may have to select the correct sensors and possibly change some I2C addresses in the sketch. If you use the new firmware configuration program and enter the serial number you should get the correct settings.
RC911 is offline Find More Posts by RC911
Old Jan 05, 2013, 11:52 PM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
That's what I thought as well and I'm not getting any I2C errors.
I think I will try re-flashing again, the blinky thing spooks me...
Old Jan 06, 2013, 01:09 AM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
those graupner 10x5 eprops look amazing...
Airplanekid333 is offline Find More Posts by Airplanekid333
Old Jan 06, 2013, 05:00 AM
jsflyrv is offline
Find More Posts by jsflyrv
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
Did you change this this in the Arduino sketch?
it should look like this if you are using the quadrino sat.
/* indicate a valid GPS fix with at least 5 satellites by flashing the LED? */
//#define GPS_LED_INDICATOR
It blinks the led to show that 5 or more sats are locked on, this is not needed with the quadrino sat as it has its own led and blinking led to show lock.
jsflyrv is offline Find More Posts by jsflyrv
Old Jan 06, 2013, 09:15 AM
Flyboy II is offline
Find More Posts by Flyboy II
Gales Ferry, CT
Joined Oct 2003
Rev 1C buzzer pin
I've been playing with my new I2C Flytron GPS on a Rev 1d zoom using the aux2 channel to select modes, but when I put one on the older multi with a rev 1c board, I have a different bank of aux pins. I know I should use D8 (buzzer pin) and it's already activated in the sketch, but I can't find any mention of which pin it is on the physical board. Maybe it's time for new spectacles?
Scott
wait, now I see D8 on the exp row. Is this and '#define RCAUXPIN8' all I need?
Flyboy II is offline Find More Posts by Flyboy II
Old Jan 06, 2013, 10:42 AM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Thanks jsflyrv!!!!!
That was it. I re-loaded several times last night and saw that comment but it never "clicked"
It's a beautiful thing
Old Jan 06, 2013, 10:43 AM
Milwaukie , Oregon
Joined Feb 2003
Quadrino & MultiWii 101
FlyingEinstein will be hosting a webex class each Sunday @ 3PM EST for an introduction to wiring the Quadrino and initial installation and configuration of the MultiWii Configuration software. This is a group discussion and a Question and Answer period will follow and asking questions during the webex is also encouraged. If you are having difficulties with setting up the Quadrino this is your chance to get your questions answered and your quad flying.
This class is offered through Cisco WebEx and supports up to 25 attendees at a time. To join the meeting goto flyingeinstein.webex.com between 2:45 PM and 3:00PM EST. The meeting will open at 2:45PM but will not begin until 3PM.
Password is always "quad"
Go to flyingeinstein.webex.com
Webex is a Cisco product for online group meetings and presentations. If you haven't already done so, your browser will prompt you to install the webex browser plugin. There is no spam, spyware or adware in the Cisco webex product. Cisco is the leading supplier of computer network related products.
Old Jan 06, 2013, 12:53 PM
jsflyrv is offline
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
Thanks jsflyrv!!!!!
Glad it worked
Old Jan 06, 2013, 04:20 PM
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
Wish I could have stayed in the webex today, it was getting interesting!
Doc, here are my settings with changes since I added GPS. It's pretty smooth, I just need a little more tunning for POS-HLD.
Old Jan 08, 2013, 02:48 PM
RC911 is offline
8 bit is more fun
RC911's Avatar
Joined Aug 2012
I have my Quadrino GPS mounted, configured and ready to go, but I will probably have to wait until May (spring) before testing is possible so I have a few questions for you (just so that I know what to expect):
1. Will there be any conflicts between the GPS unit and my 1.3GHz, 300mW VTx?
2. Will the GPS use GPS height data or the barometer for RTH and position hold?
3. Will RTH take the direct route home or will it increase the height first?
4. Will RTH land the quad automatically or will it just stop and hover?
Thanks in advance.
Old Jan 08, 2013, 03:00 PM
Milwaukie , Oregon
Joined Feb 2003
1.3 GHZ needs a lowpass filter for sure, or a notch filter would be much better than a lowpass filter. GPS operates at 1.5GHZ so it can interfer.
YES!
YES!
4. Will RTH land the quad automatically or just stop and hover?
Just hover over the Home position
Thanks in advance.
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
