Old Oct 09, 2012, 07:41 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
I am going to open WebEx at 7:00 pm tonight West Coast time.
DoctorAudio is offline Find More Posts by DoctorAudio
Old Oct 09, 2012, 08:41 PM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
DJI Spyderquad Test Flight (1 min 2 sec)
no post stabization or slowing down footage. all raw! here are some highlights from my last flight. Starting to fall in love with this spyderquad and quadrino.
still trying to get baro defined and tuning ACC
Airplanekid333 is offline Find More Posts by Airplanekid333
Old Oct 09, 2012, 09:10 PM
Milwaukie , Oregon
Joined Feb 2003
WEBex is open.
Password is always "quad"
Go to flyingeinstein.webex.com
Old Oct 10, 2012, 03:08 AM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
From where can I buy more EZ cables?
flyandi is offline Find More Posts by flyandi
Old Oct 10, 2012, 12:30 PM
cquian is offline
Find More Posts by cquian
USA, TX, The Colony
Joined Dec 2005
http://witespyquad.gostorego.com/acc...ct-cables.html
cquian is offline Find More Posts by cquian
Old Oct 10, 2012, 12:50 PM
flyandi is offline
Joined Aug 2009
Finally Done
Well here is my QuadRino F450 in the final configuration except LEDs (still in transit) and Video Transmitter/OSD ..
The QuadRino is tucked-away in the first level of the F450 and the Battery sits now on top. All custom cabling and the EZ-Cables are cut-off to the minium required length. Keeps it clean.
Using the Frankenstein Case for it - had to do some modifications to it, but it's still a good base .. quiet expensive for $25 but I guess it's worth the protection.
GPS is now mounted, too - using a LocoSys 20Hz GPS and the $6 RCTimer Nav-I2C board. Going to test GPS-hold today :-)
Old Oct 10, 2012, 01:16 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Very clean install. Good job. Now got get that thing dirty.
Killab is offline Find More Posts by Killab
Old Oct 10, 2012, 03:25 PM
Atown93 is offline
Find More Posts by Atown93
Joined Jul 2012
Good clean build. I'll be doing the same with my wiring. Really make the thing look even better put together.
I have a question for the group.
What, if any, are the reason some have put their batteries on the top deck and their fc board on the middle?
Atown93 is offline Find More Posts by Atown93
Old Oct 10, 2012, 04:27 PM
Milwaukie , Oregon
Joined Feb 2003
I put the FC in the middle because it is the most expensive piece of the kit.
So really need to protect it
The battery if the worst happens, I would rather have the battery on top becuase it is easier to get away from the rest of the unit.
Old Oct 10, 2012, 04:37 PM
flyandi is offline
Joined Aug 2009
Thanks Guys, Yeah that was my thought - keep all the goodies within the only protected area ... especially away from the props. Probably don't need a dome now since the board is well protected by the top plate from the prop-wash. Baro still should work well since it measures atmospheric pressure and that's the same within the top and the lower level :-) even within the case.
Old Oct 10, 2012, 06:34 PM
Atown93 is offline
Joined Jul 2012
Understood, I like having mine on top. It's under the dome but I do see some benefit. To internal mounting....until you need to change something.
Doc, Do my spider senses tell me something..???
I can't stop thinking about that quad...... how is it coming?
Old Oct 10, 2012, 06:55 PM
Milwaukie , Oregon
Joined Feb 2003
I am waiting on a few Quadrino boards, main batteries and the real FPV cameras!
Mounted the esc's, PDB, BEC's and motors.
flyandi is offline
Joined Aug 2009
Yeah I had the same thought but I still have access to the USB for emergency and a BT Module for config via phone .. I also can easily access the i2c bus since I made some connectors that I can pull out and connect.. so should be good :-)
Just tested GPS-Hold - although I could see that it was trying to move .. it didn't do it right :-) hehe ...
My understanding is that once activated, it saves the current position and try's to stay in that place ... is that correct?
Old Oct 10, 2012, 07:01 PM
Milwaukie , Oregon
Joined Feb 2003
Yes , but I think ACC should be on.
Maybe one of the others guys have a better answer.
Just give them a little time to chime in!
Old Oct 10, 2012, 07:07 PM
flyandi is offline
Joined Aug 2009
ACC = Level, right?
LEVEL and MAG are both always on and perfect calibrated ...
GPS-HOLD is activated via switch.
So to the GPS' defense .. it was a bit windy .. probably like 2-3mph.
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
