Latest blog entry: Composite 200 mm micro quad!
Sorry, guys it must have been the dirt. They were really dirty from the last two days of flying.
Last flight went smoothly. |
Yo, Shawn.
I talked to the Guru about changing the N to the word FRONT! You guys next week we will start discussing the real Quadrino 2.0 Everything is opened, for discussion! If your not going to be around. Post you idea and we can pass it along! |
Question. I've been using my original QuadRino Basic board...back from before they were mass produced. It's been working fine on my quads. Now I'm planning on putting it on a hex...then it hit me...some of the inputs become motor outputs for a hex setup...thus I can't use a normal Rx. I could do the PPM input without to much problem, but my question is...can the QuadRino accept a Spektrum Satellite for the control input? If so, where would I connect it? Thanks in advance.
Latest blog entry: Transplanting a Spektrum Dx4E Rf Deck...
Let me do some research.
But really if you converting to hexa, you gimbal out puts become the other two motors. |
I may do a Y6 before the end of the week!
Mckinney,TX
Joined Oct 2010
Nice fleet doc, couldn't agree more. I was just debating with a buddy that runs apm.
But anyway look at the new toy I just bought, should be some cool bling. http://www.robotshop.com/dfrobot-rainbow-led-ring.html |
That is cooler then the other one I saw! Real nice! I am sitting where i have to resist the urge to take off the goggles!
At 2:13 seconds you have to look real good to see. It freaked me out. Almost crashed. |
Mckinney,TX
Joined Oct 2010
Lol awesome.
Here's a video of the ring. http://touch.dailymotion.com/video/x...gmultiwii_tech Since I bought the I2c expansion board, I needed something else to plug in. Lol |
There is the code and it tells you how to do it.!
Yeah, I enable that for my Nanowii to use the Spektrum Satellite. The Nanowii manual tells where to hook up the satellite, I couldn't find similar info on connecting to the QuadRino. I also didn't find documentation to verify where to hook up the extra motor outputs for a flat hex setup. From early on in this thread it was mentioned you had to have a PPM input and then two of the normal inputs became the outputs for the extra motors. I was hoping things were different with the newer firmware(s).
For my Hex-X I ended up installing a Nanowii board. It had all the outputs needed for a Hex and was able to connect up a normal Rx. I just did a test over flight in the back yard with the frame and it was...well...uneventful. Multiwii is becoming my preferred controller now. |
| Thread Tools | |
| Help! need new flight controller recommendations | n3m1s1s | Multirotor Talk | 115 | Jan 09, 2012 09:38 AM |
| Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review | Michael Heer | Power Systems | 27 | Dec 16, 2010 12:36 PM |
| Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... | elan | Micro Helis | 3 | Mar 19, 2010 08:51 AM |
| Discussion Air Hogs Plug n'Play Flight Deck Simulator | trust416 | Micro RTF | 14 | Aug 05, 2007 10:44 AM |
| Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review | tailskid2 | Scale Fuel Planes | 6 | Dec 02, 2006 12:34 AM |
