Old Aug 18, 2012, 03:22 PM
shawn1979 is offline
Find More Posts by shawn1979
United States, NE, Lincoln
Joined Jul 2012
Will try thanks Doc.
Here is a couple of pics from my build.
Name: 525 x 001.jpg
Description: Name: 525 x 002.jpg
Description: Name: 525 x 003.jpg
Description:
shawn1979 is offline Find More Posts by shawn1979
Old Aug 18, 2012, 03:28 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Attachment 5091754Attachment 5091755Attachment 5091756
Good ole x525 where it all started.
Killab is offline Find More Posts by Killab
Old Aug 18, 2012, 04:33 PM
Joined Jul 2012
OK Doc,
I turned down the P on the Roll and Pitch to 3.4 and turned the I on both to .45. There was no noticeable effect. I actually turned the P down on Roll and Pitch all the way to 1.5.
Now instead of a tight circular oscillation after lift off, I get a veering effect on lift off and when I try to compensate to flatten the bird out I get a very wide or loose circular oscillation that is uncontrollable.
The tight circular oscillation is pretty uncontrollable also but i can hover 6 inches off the ground for only seconds and then it wobbles completly out of control.
I calibrated the gyro right before take off every time I adjusted the PID setting. I calibrated the gyro by throttle down yaw left and elevator back and the orange light on the board flashed.
I have expo set on my tx to 40% on my aileron and elevator.
I have my travels set to about 2000 and 1000 ms although when I was running the kk board I had my travels cut back to about 60% on my aileron and elevator.
I'm not sure what to try next.
Name: oscillation still.jpg
Description:
Shawn
Old Aug 19, 2012, 11:41 AM
guru_florida is offline
Find More Posts by guru_florida
Joined Apr 2011
Webex at 3PM!!! What are we going to discuss today, any suggestions?
guru_florida is offline Find More Posts by guru_florida
Old Aug 19, 2012, 11:54 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Originally Posted by guru_florida View Post
webex at 3pm!!! What are we going to discuss today, any suggestions?
1.
Originally Posted by killab View Post
hey doc, couldn't make the web ex last week. Does he record them? Really interested in the gps integration. Would like to see any tips he had.
2.
ok doc,
i turned down the p on the roll and pitch to 3.4 and turned the i on both to .45. There was no noticeable effect. I actually turned the p down on roll and pitch all the way to 1.5.
Now instead of a tight circular oscillation after lift off, i get a veering effect on lift off and when i try to compensate to flatten the bird out i get a very wide or loose circular oscillation that is uncontrollable.
I calibrated the gyro right before take off every time i adjusted the pid setting. I calibrated the gyro by throttle down yaw left and elevator back and the orange light on the board flashed.
I have my travels set to about 2000 and 1000 ms although when i was running the kk board i had my travels cut back to about 60% on my aileron and elevator.
Attachment 5091865
thanks
shawn
DoctorAudio is offline Find More Posts by DoctorAudio
Old Aug 19, 2012, 11:57 AM
Milwaukie , Oregon
Joined Feb 2003
Something just doesn't look right with Shawn's PIDs!
I sense a disruption in the force!
hahaha!
Old Aug 19, 2012, 12:49 PM
3D52 is offline
Find More Posts by 3D52
Steve
Denton, Tx
Joined Feb 2004
Originally Posted by Killab View Post
Hey doc, couldn't make the web ex last week. Does he record them? Really interested in the GPS integration. Would like to see any tips he had.
I would be interested also.
Steve
3D52 is offline Find More Posts by 3D52
Old Aug 19, 2012, 12:52 PM
Joined Apr 2011
P is *way* too low for any quad. Even my Gaui330 has then set to 2.3. I is way to high. It should be 0.025 or less. The I term can cause oscillations, reduce I to reduce the oscillation. I am not suprised you dampened response and a lot of oscillating with those values.
Shawn, hop on the webex in an hour. We can talk about your quad and what would be suitable PID values. We may also need to enable the gyro filter. It may simply be vibrations causing the problem.
Colin
OK Doc,
Attachment 5091865
Shawn
Old Aug 19, 2012, 01:05 PM
Milwaukie , Oregon
Joined Feb 2003
I just was just talking about that with him.
I think need to also look into his Config.H file.
Old Aug 19, 2012, 05:35 PM
Joined Jul 2012
Webex was very helpful again.
After Webex I played with the PIDs and had my first successful flight. It was a little wobbly but I managed to get it off the ground and drain my small battery without landing or crashing.
Name: First hover PID Settings.jpg
Description:
Old Aug 19, 2012, 06:10 PM
Milwaukie , Oregon
Joined Feb 2003
nice
Old Aug 19, 2012, 06:11 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
looking for webex replay
jy0933 is offline Find More Posts by jy0933
Old Aug 19, 2012, 06:14 PM
Milwaukie , Oregon
Joined Feb 2003
We got a sneak view of the venus GPS in action. Had 9-12 sats llinked inside the house.
It is about a month out but hell for that I will wait!
Old Aug 19, 2012, 06:27 PM
Joined Jul 2012
Adjusted PID's again almost wobble free. I decided to be brave and threw the acc switch needs some adjusting but seems to work. Its kind of weird, no wobble to a little wobble in acro mode but when I threw the acc switch, it held attitude pretty well considering there was a breeze but instantly wobbled. I adjusted the level PID which I assume is for the acc mode and wobble is almost gone in acc. This is allot of fun when you can get the copter off the ground and tweak settings to make it fly better. Just waiting for another charge.
I'm sure I will have more tuning questions.
Thanks to Colin,DoctorAudio, and everyone else.
Old Aug 19, 2012, 06:57 PM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
Hi, I am switching to 2.1
I went into sketch and defined everything I need and verified everything then uploaded it. So i go into config and clicked read and my graph is flat, my values are zero, and there is a flashing red light on my board. Obviously i did something wrong.
Any help would be appreciated!
Shelby
Airplanekid333 is offline Find More Posts by Airplanekid333
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
