Old Aug 08, 2012, 05:35 PM
Atown93 is offline
Find More Posts by Atown93
Joined Jul 2012
That answers that question then. So the bt unit and the GPS can be piggybacked together with no issues.
Do you know if anyone out there is making a second deck type platform that mounts over the FC for these add-ons that will still fit under the plastic dome?
Atown93 is offline Find More Posts by Atown93
Old Aug 08, 2012, 05:43 PM
Atown93 is offline
Joined Jul 2012
Now that I read that again.... Does the radio turn off once the board is armed or is that the board will no longer receive configuration input once armed?
Old Aug 08, 2012, 06:11 PM
DoctorAudio is online now
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Because you have a V1E board your profile is very low compared to my V1C and V1D boards.So it is possible to use it and any other top plate with the same mount spacing that the quadrino uses.
The atmega can't save to the eprom unless it is unarmed.
DoctorAudio is online now Find More Posts by DoctorAudio
Old Aug 08, 2012, 06:25 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
Ok, checking back here since my independent study was approved-
I can't imagine trying to sift through 300 pages of info here, and the RCG search function isn't great, so I've got a few questions-
Does the quadrino controller have GPS support yet? Last time I asked I was told it was coming soon-ish.
And how programmable is it- ie...can you program it for autonomous flight and stuff? Just thinking of capabilities I might need for my project.
Thanks!
Endlesslag is offline Find More Posts by Endlesslag
Old Aug 08, 2012, 06:34 PM
Milwaukie , Oregon
Joined Feb 2003
The GPS module that colin is working on, will be out soon. He is starting to see the light at the the end of the tunnel, with the recall.
He has lost days in repairing them all.
Sunday he thought it was Friday! Hahahaha!
I am even waiting on a box to show up with my new boards.
Looking forward to get my big quad in the air. We are still testing out motors.
This will be a fast moving FPV and drop ship.
Some of those name brand ones suck bad air. Damm bearings.
As for the Autonomous flight: I have no clue.
I live to close to an airport! Lots of air traffice around me about 200 feet.
Old Aug 08, 2012, 11:02 PM
Milwaukie , Oregon
Joined Feb 2003
Atown: did you get two of these?
http://witespyquad.gostorego.com/acc...splay-i2c.html
Old Aug 09, 2012, 12:10 AM
Atown93 is offline
Joined Jul 2012
Originally Posted by DoctorAudio View Post
Yup they arrived to my currier yesterday and were put on the plane coming here today. I'll have them in my hands probably Monday.
Old Aug 09, 2012, 12:41 AM
Milwaukie , Oregon
Joined Feb 2003
That is what I would use instead of the bluetooth. You should be able to use both without an issue. I will double check my info tomorrow.
Old Aug 09, 2012, 03:04 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Hey doc, whats the advantage of that screen over BT? I love my BT module. Saves so much time.
Cervanchez is offline Find More Posts by Cervanchez
Old Aug 09, 2012, 03:16 PM
Milwaukie , Oregon
Joined Feb 2003
The advantage of the screen is you don't need your phone at the field.
You still need your computer to set it up first time. You have to setup the sketch, for it to work. but once it does you can you it to make adjustment without any other device.
The bluetooth does not need you to do anything in arduino.
Just plug it in to the right pins and pair it. After that you can use it anytime.
From what I am told, only because mine has not gotten here yet.
Once it is paired you need an app on your phone to use it.
Old Aug 09, 2012, 03:18 PM
Milwaukie , Oregon
Joined Feb 2003
Guys and ladies.
Colin has been burnning the midnight candle to much.
He is sick with what it seems to be the flu.
So let's give him a day or two. Hopefully we see him in WEBEX this Sunday!
Old Aug 09, 2012, 03:23 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Guys and ladies.
Thanks for the heads up... He is done great work getting these boards repaired and back out.. Great support. I cant believe he is doing this alone.
Killab is offline Find More Posts by Killab
Old Aug 09, 2012, 03:25 PM
Milwaukie , Oregon
Joined Feb 2003
I know. I was like WTH!
But he is the boss and I just help when I can!
Old Aug 09, 2012, 06:11 PM
Edkirk is offline
Find More Posts by Edkirk
United States, CA, Vista
Joined Dec 2010
I have been using the OLED, I had to get a copy of the config.h file to set it up properly. It works as advertised, the print is small and the tx stick banging takes some getting used to.
I got this board http://www.hobbyking.com/hobbyking/s...rol_Board.html really made me mad, it flyes just great, easy to setup and just too much fun. Anyway the 4 buttons are really handy for programming, the OLED would be more usefull if it had the 4 buttons.
We have been using this long range radio, we can monitor and make setting in flight. There is a slight glitch when settings are written, we don't make changes to the throttle in flight for obvious reasons https://store.diydrones.com/3DR_Radi...try-3dr915.htm
Edkirk is offline Find More Posts by Edkirk
Old Aug 10, 2012, 03:05 AM
Milwaukie , Oregon
Joined Feb 2003
Wow, look at the Paris.
I thought people were only using them for gimbals.
Hahahaha, just joking.
Where is the BadAZZ Tri-copter you got there?
Can we see it?
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
