Old Jul 18, 2012, 05:36 AM
p25o1 is offline
Find More Posts by p25o1
Joined Aug 2011
thx Doctor,,,
time for a small confession,,,
i used PatrikE MultiWii AcroTrainer mode!!!
"If combined Roll and Pitch command Exceeds Ex.200 acroTainerMode is activated.
When sticks are centered it will return to Level mode."
read about it on
http://www.multiwii.com/forum/viewto...57a6ff9e2260fd
its a good way to start , and then switch to the real deal.
p25o1 is offline Find More Posts by p25o1
Old Jul 18, 2012, 07:22 AM
Flyitall. is offline
Find More Posts by Flyitall.
Joined Jul 2012
I had questioned earlier about dual rates. I guess being a long time heli flyer Im trying to set the quad up in a similar fashion. Intentions are to use it as a stable aerial platform for an FPV trainer. Will fly my helis for acro. If I say put Yaw/roll/pitch on 70% D/Rs all I have done is clip the outer limits of the values, center point remains the same. I would assume the amount of differentiation among the motors is lessened just as would be servo travel. If this is the case it will allow on the spot changes to the quad with out using the GUI. Am going to begin to "build" a heli program in the tx and bind it to it when it flys to suit my purpose
Thoughts on the D/R?
Flyitall. is offline Find More Posts by Flyitall.
Old Jul 18, 2012, 10:50 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Oh if you didn't know guys and girls.
The guru was to have the GPS module out last Friday.
Some of us have been waiting, longer than that.
I am hoping we will see it for sale soon.
I woul love to display it on the 29th at the Snohomish FunFly.
So if you have a big a little issue everyone, lets get them taking care of.
So they can finish it..
The doctor is IN!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Jul 18, 2012, 11:36 AM
Milwaukie , Oregon
Joined Feb 2003
DR is great option, just make sure you either leave that mode so you can unarm it.
arm won't work with the yam below 80% on mine.
Old Jul 18, 2012, 01:52 PM
Joined Jul 2012
ThanksDrA! This just gets better. Got my FPV system in this AM. Its pretty cool just playing around with the components. Started a heli program in the tx, as soon as I get the quad 100% tweeked will move it there. I will tie the D/Rs to the second flight mode and the flattened throttle curve.
Old Jul 18, 2012, 02:14 PM
Milwaukie , Oregon
Joined Feb 2003
The only thing I am questionable, is the flattened throttle curve.
Old Jul 18, 2012, 02:39 PM
p25o1 is offline
Joined Aug 2011
The doctor is IN!
which site should we camp in front, for the gps module ??
Old Jul 18, 2012, 02:45 PM
p25o1 is offline
Joined Aug 2011
btw DoctorAudio,
the price of having so much fun = re-kit
i just destroyed my frame after getting too confident with my flip skills.
luckily the quadrino was protected with a cover.
any advice on a Protective Case , like the one on hauntnet.com but for the rev1e??
Old Jul 18, 2012, 03:09 PM
Joined Jul 2012
Its not flattened it becomes non-linear(sloped) between points 2-3-4 on a 5 point curve. Since this is a fixed pitch heli this will help soften the curve a bit when flying slow or hovering.The complete curve is still available, you will just have to move the stick more in this range to get it(similar to expo). Will take the jumpiness out.
Old Jul 18, 2012, 05:16 PM
Milwaukie , Oregon
Joined Feb 2003
I think if you can chat with him he could modify it.
I don't think he has a couple hondred made.
http://www.hauntnet.com/frankenquad/...2fd543ebc2f15a
Other wise the price would be lower.
As for the site that it is coming out on,
Old Jul 18, 2012, 10:10 PM
Milwaukie , Oregon
Joined Feb 2003
Look what showed up in the mail.
Old Jul 18, 2012, 11:09 PM
ScoRpiUs2009 is offline
Find More Posts by ScoRpiUs2009
ScoRpiUs2009's Avatar
Australia, VIC, Mordialloc
Joined Aug 2009
so i got my quad flying well, only LOS so far, only just installed my FPV stuff onto the quad and havent had a chance yet to fly cause its been pretty windy.
Flying with the Quadrino Board mainly in Acro mode
https://vimeo.com/45809579
ScoRpiUs2009 is offline Find More Posts by ScoRpiUs2009
Old Jul 19, 2012, 12:07 AM
Milwaukie , Oregon
Joined Feb 2003
Nice there.
I saw whe you was flying straight it kind of pitched up a little.
Could you may need to bring Your I higher to stop that.
See if that work, unless you had a couple gust of wind.!
Nice job on the flips.
Old Jul 19, 2012, 01:54 AM
Joined Aug 2009
Nice there.
It was dead calm, bit hard to see it when it's up high and not knowing the angle it would level out at
Old Jul 19, 2012, 02:54 AM
p25o1 is offline
Joined Aug 2011
regarding the gps,
i'm waiting for this one
http://www.flytron.com/sensors/180-i...nd-others.html
its an i2c module ,, should work nicely with the quadrino
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
