Old May 25, 2012, 06:27 PM
jpsabo is offline
Find More Posts by jpsabo
jpsabo's Avatar
Joined Feb 2011
No, it doesn't. In fact it's easier to not have the board mounted or connected so the magnetometer can be calibrated.
Regards,
John
jpsabo is offline Find More Posts by jpsabo
Old May 25, 2012, 06:36 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Regards,
John
You want to calibrate the mag outside if possible and with it mounted on the quad so that it adjusts for any magnetic variances from its location in the overall setup.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old May 25, 2012, 06:44 PM
viper522 is offline
Find More Posts by viper522
United States, FL, Palm Beach
Joined Jan 2011
Regards,
John
Thanks John. I figured it out just before I refreshed this page - I was trying to run the 64 bit version - didn't work. But the 32 bit did (on Win7-64 Ultimate). I think it has to match the Javaw.exe (which is 32 bit).
viper522 is offline Find More Posts by viper522
Old May 25, 2012, 06:53 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Same here I have to run the 32 bit version on Win 7 64.
Site Sponsor
Old May 25, 2012, 09:39 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Man, I am hoping that the GPS will be out in a couple of days.
I have the perfect ship to test it in!
DoctorAudio is offline Find More Posts by DoctorAudio
Old May 25, 2012, 10:44 PM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
If you find info on gps let me know, that's the next thing I want for my Quadrino
Killab is offline Find More Posts by Killab
Old May 26, 2012, 03:58 AM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
The gps won't be out right away yet, still in testing from what I understand.
Site Sponsor
Old May 27, 2012, 01:44 AM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
Ya think I've seen a couple of videos on YouTube with people doing it, but I want it to be a simple as buying a gps and plugging it in and go. Minor setting is expected. I just want rth.
Old May 27, 2012, 11:09 AM
viper522 is offline
Joined Jan 2011
Now that I have it wired up, I'm having trouble with the ESCs fast beeping. I did the max throttle calibration using a 4x1 cable and also individually. I tried setting the config file at 1500, 1250 and 1000. MWConfig shows my min throttle # as 975 and max as 1981 (Turnigy 9X w/ ER9X). I have an ESC programming card but I didn't change any settings on the ESCs (TowerPro H40A) so they are at defaults. As I understand it, they have the same defaults as the Turnigy ESCs, if that means anything to anyone without me typing it all out. Ideas?
Old May 27, 2012, 11:11 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Go to config.h and lower that:
Code:
/* this is the value for the ESCs when they are not armed
   in some cases, this value must be lowered down to 900 for some specific ESCs */
#define MINCOMMAND 1000
Dialfonzo is offline Find More Posts by Dialfonzo
Old May 27, 2012, 11:33 AM
bobandris is offline
Find More Posts by bobandris
LSF 004 - AMA 5055
bobandris's Avatar
United States, CA, Saratoga
Joined Dec 2000
1.9 -> 2.0?
Hey Guys,
Just a quickie. Can you point me to a procedure for 'upping' a 1.9 MultiWii board to 2.0, if that is possible.
Many Thanks,
Bob
bobandris is offline Find More Posts by bobandris
Old May 27, 2012, 11:41 AM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
bob, this is a great tutorial right here.
http://www.flyingeinstein.com/index....ating-firmware
It shows you how to upgrade to 1.9 but the 2.0 just came out so just make sure you download the 2.0 first off the multiwii site and use that 2.0 file when uploading to audrino
Airplanekid333 is offline Find More Posts by Airplanekid333
Old May 27, 2012, 11:54 AM
Glenstr is offline
Find More Posts by Glenstr
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
Originally Posted by bobandris View Post
Hey Guys,
Many Thanks,
Bob
Are you on a rev D or E board Bob?
I'm on a revD and heard that the new features in the 2.0 don't work that well on these boards. Haven't tried it yet though, holding off for now.
Glenstr is offline Find More Posts by Glenstr
Old May 27, 2012, 06:44 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
A
That's not true.
Sensors on all Quadrino version are real standard and are supported.
Old May 28, 2012, 08:40 AM
viper522 is offline
Joined Jan 2011
Code:
**UPDATE: Ahh I figured it out, if I turn the Tx off and on a couple times and arm the Quadrino, it works fine. I'll have to figure out the proper procedure.
I did what you said and tried 900, no dice. I also loaded 1.9 stable and it does the same thing (at 900). Orange light on one side and green on the other, both solid. If I shut off the transmitter, I get solid green and solid blue and no beeping.
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
