Old May 17, 2012, 05:59 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by badooger View Post
(((Beware))) No failsafe on upgrading multiwii firmware. if you turn off your transmitter after disarming. the qaud will rearm and take off on it's own. (Hole in pc board)
Purchased the new 1e ez/wire board. I don't know who named this but it's other than ez.
vc 450 ar8000 rx and old 1d wiring. Witespy. It would be helpful to have a diagram to convert boards using the esc connectors. badooger@yahoo.com
That behavior is from your ESC failsafe.
Dialfonzo is offline Find More Posts by Dialfonzo
Old May 17, 2012, 09:47 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Originally Posted by ROCKY2 View Post
have done that but still nothing what version of the GUI are you running ? i cant get one to work right
Is your trim all the way down?
What radio you got, sir?
DoctorAudio is offline Find More Posts by DoctorAudio
Old May 17, 2012, 10:05 PM
ROCKY2 is offline
Find More Posts by ROCKY2
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
yes it is all the way down...
so i program it in arduino 0023 or 22 or 1.0 and than i go to the config 1.9 and check it and it says i have shanged it but non of the sensors are responding so it is a problem in the flashing?
ROCKY2 is offline Find More Posts by ROCKY2
Old May 17, 2012, 10:07 PM
ROCKY2 is offline
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
i have a futaba 9cap
Old May 18, 2012, 01:40 PM
chuckswig is offline
Find More Posts by chuckswig
Joined Jun 2007
FIrst (short) flight
Just got the VC450 yesterday evening, got it connected to the software and everything looked good, charged batteries. Today at lunch I got the props put on, did the gyro calibration and at first take off it started to flip, but just adjusted trim and was up and flying around (short hops) in no time - that's the most exciting flight! I've flown fixed wing r/c a lot and some time with a quad on a simulator so this was a real plug-and-play (after reading a lot experience, thanks!!
Chuck in Charleston WV
chuckswig is offline Find More Posts by chuckswig
Old May 18, 2012, 03:50 PM
Nethole is offline
Find More Posts by Nethole
Registered Lurker
Nethole's Avatar
Joined Aug 2004
wiiconfig won't show any 'lines' of data when I click start. I've tried both 1.7, and version 1.9, and selected both com ports that show up. If I pick the 1.7 version, I'll see the RX light flash on the quadrino board. if I pick the 1.9 version, I'll see both the RX and TX light flash. [usb drivers are installed, run on xp, admin user]
I picked up this quad from a user on the forum here, thinking I'd get a nice easy ready to flight unit. However, I misread the sales description, (no receiver). I've connected the leads from the quadrino board in the same fashion, but I haven't been able to get any kind of throttle response. I thought I'd back up a step, and hook up the usb connector to see what information comes through there.
[and I can't seem to get any visible data from the wiiconfig program]
Yes, (first quad)
Nethole is offline Find More Posts by Nethole
Old May 18, 2012, 03:53 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Yes, (first quad)
The Multiwiiconfig version need to match the one that is uploaded in the Multiwii controller.
If you don't know which one the previous owner put inside i suggest to reflash it.
But you need to know some things before.
Look in the few last page of that thread, there is a wiki listed.
Old May 18, 2012, 04:18 PM
FullmoonCat is offline
Find More Posts by FullmoonCat
Rank Amatuer
FullmoonCat's Avatar
United States, ID, Boise
Joined Dec 2011
I'm having a very strange issue with my Quadrino board. I've had it since about January, and it's been performing with no issues in my micro-quad since then, couldn't be happier. Recently, I switched the controller back into my "Witespy" 450 quad, and it also worked perfectly there for two flights.
After those two flights, it stopped working correctly. Now, the quad behaves as if the pitch is fully backward at all times, even if I put the pitch full forward. It does this in any mode. The rear two motors are running slower than the front two. I have narrowed the problem down to the flight control board through the following steps:
  • Re-calibrate all ESCs: No impact
  • Re-upload and re-calibrate firmware/sensors: No impact
  • Switch ESC connections to board so front motors are hooked to back motor connects and visa-versa: Front motors run slower now, verifying that the problem is the signal being sent to the ESCs.
  • Switch roll and pitch channels in the Tx: No impact, verifying that the Tx is not in error.
  • Verify in MultiWii config that the pitch centers at 1500, ruling out the Tx or Rx as the source of the problem
So, it's got to be the flight control board, I believe. Since I already re-uploaded the firmware, is there anything else I can do to try to get it behaving regularly again?
FullmoonCat is offline Find More Posts by FullmoonCat
Old May 18, 2012, 04:19 PM
ROCKY2 is offline
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
Yes, (first quad)
im having this same problem
Old May 18, 2012, 04:22 PM
Milwaukie , Oregon
Joined Feb 2003
What rev boards do you both have?
Also can you post a screen shot?
thanks will try to help if I can!
Old May 18, 2012, 04:33 PM
Rank Amatuer
Joined Dec 2011
I have Rev 1D "Quadrino Zoom" with the BMP085 barometric sensor. Not sure what you'd want with a screenshot in my case. I suppose I could get a capture of the MultiWii config, though it all looks normal, if you think that might help.
Old May 18, 2012, 04:37 PM
Milwaukie , Oregon
Joined Feb 2003
it could help
Old May 18, 2012, 04:44 PM
ROCKY2 is offline
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
screen cap
same thing happenes with 1.9
Old May 18, 2012, 04:45 PM
Milwaukie , Oregon
Joined Feb 2003
Can either of you update to firmware 2.0?
Old May 18, 2012, 04:46 PM
ROCKY2 is offline
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
i did but it wont even connect to the board
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
