Old May 13, 2012, 01:09 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
DJI F450 combo kit ( Quadrino-Zoom) (7 min 7 sec)
DoctorAudio is offline Find More Posts by DoctorAudio
Old May 13, 2012, 04:55 PM
bobandris is offline
Find More Posts by bobandris
LSF 004 - AMA 5055
bobandris's Avatar
United States, CA, Saratoga
Joined Dec 2000
micro Quad
Sorry to bother you all with such a newbie request. I'm now on my 2nd quad; the 1st was a DJI F450 ARF, including the Naza (I wanted to start with the one having the highest probability of success; and it was!).
My 2nd quad consists of a Quadrino Zoom, rev 1E, installed in a Turnigy micro Quad, with ZTW 12 ESCs, HK 1811-2000 10g motors, Gemfan 5x3 3-blades, and a 3S1P GensAce 1000 mAh/25C. I installed a Spektrum AR6100 and bound it to my DX8.
Next I installed MultiWiiConf 2.0 and the FTDIUSBSerialDriver on my iMac and finally got the software and the Quadrino Zoom talking to each other. Was able to use it to set the throttle to 1000-to-2000; the aileron, elevator, rudder to 1000-to-1500-to-2000; and the gear switch to 1000 and 2000. Wrote it, disconnected and installed the battery, fired it up and was able to get it to lift off! Somewhat twitchy but still it was a success!
Then I got back on activated the ACC, BARO, & MAG but didn't touch the default PIDs as I don't know what in the hell I'm doing yet; soon though! It is now flying pretty good, but I'm experiencing some motions which I would like to calm down (yes, the Naza spoils you with its stability!). I am reading the PID references but I'm hoping you could give me some guidance on two issues. My feeling is that the "default" settings (see screenshot, below) that were already in the Quadrino Zoom were selected for a more typical sized quad, much like the DJI F450 not the 220mm motor-to-motor Turnigy micro.
The micro Quad has rather low amplitude ROLL and PITCH oscillations. They both are about + and - 10 degrees and have about a 1 second period. Maybe "wobbly" would describe it better. Could you advise me as to what a good beginning change to their 3.8, 0.030, 23 PIDs would make sense.
Also it is kinda "springy" in altitude. Its like it is slowly bouncing on a trampoline, i.e., it will go up about 5 ft in about 2 seconds and I try to counter it and it will start back down, but overshoot. If I really concentrate on it I can keep it inside say a 2 foot high box. Similarly, do you have a guesstimate for the changes to the ALT 1.6, 0.015, 7 PID that might help it to become more rock steady in altitude hold.
If I can get these two shut down, I'll be well on my way. Would appreciate any help you can think of. Below is a screenshot of the "default" settings I'm using.
Many Thanks,
Bob
bobandris is offline Find More Posts by bobandris
Old May 13, 2012, 06:41 PM
Milwaukie , Oregon
Joined Feb 2003
I only change the PID's one at a time, plus I only change them at .3 at a time.
So this is the part that takes the most time.
But it should not feel springy.
Old May 15, 2012, 01:24 AM
Milwaukie , Oregon
Joined Feb 2003
Check your Pm's
Many Thanks,
Bob
Old May 15, 2012, 04:12 PM
ROCKY2 is offline
Find More Posts by ROCKY2
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
HEY guys so i go to change it to a tri copter i change it but it wont let me arm it i can move the yaw servo but i cant get the motors to turn on when i plug it into the config it doest show the sensors working any ideas
ROCKY2 is offline Find More Posts by ROCKY2
Old May 15, 2012, 07:51 PM
Milwaukie , Oregon
Joined Feb 2003
Tri-copter arms different from a quad or hex.
Old May 15, 2012, 08:01 PM
Sean1986 is offline
Find More Posts by Sean1986
Sean1986's Avatar
Joined Mar 2012
Hello Guys
So im a total newb and this is my first build and first quad unless u count my MQX which I love by the way. So I bought the Quadrino advance Vr1 with the Easy connects. I went into Adruino 1.0 and I defined the quad took away the "\\"
I calibrated my ESC with my Hover Things programing card. Everthings plugged in and ready to fly. Now I can take off and hover and do some forward flight but the whole time (this is the best way for me to discribe it) its "twitchy" what i mean by that is it it jerks lightly when i fly it from right to left like its shaking i can slightly control it but i get to nervous to fly it. im thinking it could be my pid settings or another one of my settings so I have a pic here of what I have.
Now i know you guys say mess with you pids by very litttle by.o33 But im not sure which to change Any help would be much appreciated thanks for taking the time to read this and for the help
Sean
Sean1986 is offline Find More Posts by Sean1986
Old May 15, 2012, 08:26 PM
Milwaukie , Oregon
Joined Feb 2003
Try changing you roll pitch first (3.4) and if the doesn't stop or slow the twiching down.
Then put the setting back and then change the pitch to (3.4).
If that doesn't help it or stop it.
Then work on your yaw, settings.
Old May 15, 2012, 09:20 PM
larryw461 is offline
Find More Posts by larryw461
Joined May 2006
Unusual? Quadrino behavior
Moved to new Thread
larryw461 is offline Find More Posts by larryw461
Old May 16, 2012, 09:54 PM
ROCKY2 is offline
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
how than?
Old May 16, 2012, 10:13 PM
Milwaukie , Oregon
Joined Feb 2003
http://multiwii.googlecode.com/svn/b...8_v0-57721.pdf
Old May 16, 2012, 11:02 PM
badooger is offline
Find More Posts by badooger
Joined Feb 2012
(((Beware))) No failsafe on upgrading multiwii firmware. if you turn off your transmitter after disarming. the qaud will rearm and take off on it's own. (Hole in pc board)
Purchased the new 1e ez/wire board. I don't know who named this but it's other than ez.
vc 450 ar8000 rx and old 1d wiring. Witespy. It would be helpful to have a diagram to convert boards using the esc connectors. badooger@yahoo.com
badooger is offline Find More Posts by badooger
Old May 16, 2012, 11:14 PM
badooger is offline
Joined Feb 2012
vc 450 with spectrum ar8000 rx. Any step by step pictures would be helpful switching from 1d multiwii board to 1e multiwiiboard. a lot of open grounds extra wires and loose ends.
badooger@yahoo.com
Old May 17, 2012, 12:03 AM
ROCKY2 is offline
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
have done that but still nothing what version of the GUI are you running ? i cant get one to work right
Old May 17, 2012, 05:17 PM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
My quadcopter is shaking just a little bit, how do I make less sensitive and softer? I don't want to screw up my PIDs because the 2.0 setup has been treating me well.
Airplanekid333 is offline Find More Posts by Airplanekid333
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
