Old May 07, 2012, 11:36 AM
DoctorAudio is online now
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
If you ESC's don't see a low enough signal number they won't arm.
But if you are turly having and issue, with the board.
If you can't get it to talk to the programs the, something is loose or more like a C.S.J. (cold solder joint) which would cause the intermittent issue.
Try using a had dryer when it doesn't arm.
With the chips that are on the board either they work or they don't.
So I would bet there is a c.s.j somwhere on that board.
Checking your BEC should give you no more than 5.5 volts DC!
Originally Posted by egaus View Post
Dialfonzo,
My issue is not that I can't 'arm' the board, it's that the board does not arm the ESCs like it normally does immediately after plugging in battery. The ESCs just beep every few seconds and twitch the props.
Of course, I can't arm the board either, because it never gets to the point of being able to be armed. When it is in this state, it is as if it never 'booted' correctly.
In the off chance that the board arms the ESCs, I can arm the board and fly the quad. The prob is that everytime I get it (by repeatedly trying to plug it in) to work, it only works for maybe one flight, then does the same thing again. MW Config and Arduino cannot see the board in this condition.
If I check the BEC voltage, what am I looking for?
e
DoctorAudio is online now Find More Posts by DoctorAudio
Old May 07, 2012, 11:55 AM
egaus is offline
Find More Posts by egaus
Quadrophenia
egaus's Avatar
Seattle
Joined Mar 2009
Got it. Exactly what I was thinking DA, because it works in my house sometimes, then I take it to the field in my car and it doesn't work. Only difference is temperature. I bring it back to the house, let it sit and it works. I'd rather fly it at the field than in my living room personally.
e
egaus is offline Find More Posts by egaus
Old May 07, 2012, 11:58 AM
Milwaukie , Oregon
Joined Feb 2003
Well then if you can get the hair dyrer to make a difference then that is it.
It could be easy for you to fix yourself.
But if you havent done it before you should just send it in to witespy.
Old May 07, 2012, 08:55 PM
jonquinn is offline
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
Originally Posted by jonquinn View Post
Need some help -
I got my quad to run with Quadrino advanced, finally, last weekend. But the settings, or maybe something else isn't right yet.
When I run up the throttle it just want to tip over to its left (my right as I face the top end of the quad and the top two rotors). I' be got the blade orientation and rotation correct for a quad x. I can't tell for sure but it looks like the motors on that side it wants to tip to aren't turning as fast as the other side.
I'm using RC timer 20A escs on all four motors, and the motors are all heads up RC 2215 970kv. Props are all the same Dia and pitch too (yes two are reversed). So to this point I cannot yet do a basic hover.
Can I test for rpms on individual motors on the GUI screen? And if that's the problem can they be adjusted on the GUI screen? Or does that involve programming the esc?
here is a print screen I got today when I hooked up the quadrino to my PC with the USB cable. I did not arm the motors, but you can see with full throttle, one side is up near 1900, while the other is well below that. How do I calibrate the ESCs? is that done in the GUI? I was able to slide top top ESC number up or down. When I tried that on lower ESC, the aux 3 and 4 kept opening up. Anyways, even if I could slide the front right ESC up with my mouse, it wouldn't stay put.
I think this follows my quad's tendancy to tip over as I increase throttle, instead of going into nice hover.
jonquinn is offline Find More Posts by jonquinn
Old May 07, 2012, 09:33 PM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
Originally Posted by Barn-E-Stormer View Post
How to calibrate speed controllers.
http://www.youtube.com/watch?v=Xpru6XoLg1Q
right here Jon, this is a great video on how to calibrate your ESC's
Airplanekid333 is offline Find More Posts by Airplanekid333
Old May 07, 2012, 10:04 PM
jonquinn is offline
Joined Aug 2008
Thanks. Will have to try that tomorrow evening
Old May 07, 2012, 11:38 PM
egaus is offline
Quadrophenia
egaus's Avatar
Seattle
Joined Mar 2009
Where's the official support for Quadrino?
Witespy store home page looks awful, no contact, no reply to emails. What up?
This is a great product, support is currently user forum only apparently.
e
Old May 08, 2012, 12:22 AM
AdaptedEye is offline
Find More Posts by AdaptedEye
Joined Mar 2012
His phone number is on the FAQ page
AdaptedEye is offline Find More Posts by AdaptedEye
Old May 08, 2012, 12:23 PM
Milwaukie , Oregon
Joined Feb 2003
e
So what did you find?
DA!
Old May 08, 2012, 03:59 PM
egaus is offline
Quadrophenia
egaus's Avatar
Seattle
Joined Mar 2009
Just talked to him on the phone. He returned my call quickly and made me a happy customer!
He said the crystal(?) may have gone bad and he would fix it.
e
Old May 08, 2012, 04:01 PM
Milwaukie , Oregon
Joined Feb 2003
Roger brother.
I knew you would get somewhere.
Old May 08, 2012, 04:05 PM
Milwaukie , Oregon
Joined Feb 2003
Are you coming down here on the 19th, for the multi-Rotor fun-fly?
Old May 08, 2012, 04:13 PM
ro.bi. is offline
Find More Posts by ro.bi.
... where is it ?!
ro.bi.'s Avatar
United States, CA, SF
Joined Jul 2011
Finally, I can tell my wife something she can relate to: the crystal needs replacement =)
e
ro.bi. is offline Find More Posts by ro.bi.
Old May 08, 2012, 05:26 PM
egaus is offline
Quadrophenia
egaus's Avatar
Seattle
Joined Mar 2009
Link?
e
Old May 09, 2012, 01:32 AM
Milwaukie , Oregon
Joined Feb 2003
Contact Dana it is his club.
http://www.rcgroups.com/forums/showp...postcount=1723
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
