Old May 01, 2012, 02:28 PM
Barn-E-Stormer is online now
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
Ken, you say this only happens after at lest 3 minutes of flight? I think you just have one ESC with the cutoff voltage a little higher than the others.
Test it on the ground with props off and a battery discharged half way.
Barn-E-Stormer is online now Find More Posts by Barn-E-Stormer
Old May 01, 2012, 02:51 PM
DoctorAudio is online now
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Originally Posted by Kenpilot View Post
Here we go. I'll try to fire up Arduino and get my minthrottle settings
By the way, thanks DoctorAudio for your troubleshooting help. Keep in mind that video was edited from two days of flying. Both times the quad flew for 3 minutes or so before crashing. If it were minthrottle or other settings, would it fly well at all?
Would have posted the entire second day flying video, but thought it was too long and boring...but if you watch it you can see its flying fine.
Ken:
Thank you for not letting me watch 10 mins of you flying.
FPV can get very boring.
Check those setting for sure.
Any one using a Multiwii, having issues please check all you settings.
I have said this before that on the [Alt], less is more and it being to high will cause your multirotor to fall from the sky.
If your PIDS are to high, death wobble will come into play almost every time.
Ken I noticed in your video when you would push nose down and go into forward flight you tail kicks to one side.
That has much to do with the PID's you have on your YAW!
DoctorAudio is online now Find More Posts by DoctorAudio
Old May 01, 2012, 02:57 PM
Milwaukie , Oregon
Joined Feb 2003
Oh yeah, you need to update your firmware to 2.0 if your using all those things at once you will see a big difference how she flys.
Old May 01, 2012, 04:31 PM
Kenpilot is offline
Find More Posts by Kenpilot
Kenpilot's Avatar
Joined May 2006
When updating from 1.9 to 2.0 using Arduino 1.0, I got these three messages.
"MultiWii_2_0.cpp: In function 'void loop()':
MultiWii_2_0:614: error: 'getEstimatedAltitude' was not declared in this scope
MultiWii_2_0:629: error: 'computeIM
Kenpilot is offline Find More Posts by Kenpilot
Old May 01, 2012, 04:46 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Use Arduino 1.0 for multiwii 2.0
Dialfonzo is offline Find More Posts by Dialfonzo
Old May 01, 2012, 04:52 PM
Milwaukie , Oregon
Joined Feb 2003
Do you have the right board selected?
May be the problem.
Old May 01, 2012, 04:53 PM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
Ive got good news and a video coming!!! hehehehehehehahahahah I love my quadrino board now.
Airplanekid333 is offline Find More Posts by Airplanekid333
Old May 01, 2012, 05:10 PM
Kenpilot is offline
Kenpilot's Avatar
Joined May 2006
I did that. Here is a screenshot...
Yes, screen shot attached...
Old May 01, 2012, 05:49 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Board sellected in the Arduino DropDown menu.
Not in the sketch
Old May 01, 2012, 06:00 PM
Kenpilot is offline
Kenpilot's Avatar
Joined May 2006
Not in the sketch
Thank you for that info. I had selected this one as directed from the Flyingeinstein.com tutorial. Are you certain that the one you have selected Dialfonzo is the correct board for Quadrino Zoom from FlyingEinstein?
Old May 01, 2012, 06:03 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Multiwii controller based on the Pro Mini (Like the Quadrino) are normaly flashed with the one i pointed. Sometime they are flashed with "Uno" bootloader also.
You can't break anything by trying that.
My Quadrino is flashed with ProMini and all the Quadrino i see are.
Old May 01, 2012, 06:07 PM
Kenpilot is offline
Kenpilot's Avatar
Joined May 2006
Ok will try that. Where do you download your code from? I got another orange error message saying something about INO not defined...
Old May 01, 2012, 06:09 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
This is a MultiWii controller.. so .. try www.multiwii.com
Direct link to download
Old May 01, 2012, 06:48 PM
Milwaukie , Oregon
Joined Feb 2003
I have used both.
Old May 01, 2012, 07:10 PM
Kenpilot is offline
Kenpilot's Avatar
Joined May 2006
Thanks. Once again, the code I downloaded to flash was from the Flyingeinstein site. However, when trying to compile the einstein code, I got the above messages per the screenshots.
However, when using the link from Dialfonzo, the code compiled and uploaded without any errors. Miracle!
Thanks for all your help. Now that I've done this, maybe I'll use the ninth life of this Quadrino board and put it on my old Quad #1. Has been a good flier with FY90Q, lets see what happens when I replace it with the quadrino.
Thanks for all the help Doc and Dialfonzo.
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
