Old Apr 29, 2012, 12:28 PM
jonquinn is offline
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
I'm still stuck/lost trying to get my quad with a quadrino advanced to do anything.
I was able to flash and update the board, and have version 1.9 on it. When I run the MultiWii Config program for 1.9, I can get the board to show how its moving about its axis (if I turn it about), and relationship to magnetic north. There is nothing from the barometer though, and I did pay for a advanced board when I bought this from whitespy last fall. I did remove the little piece of tape.
The big problem so far is that this board doesn't seem to be doing anything with the transmitter input. I've tried a couple different spektrum DSM2 receivers, a couple of turnigy orange ones, with my DX6i and a JR 9503 with DSM2 module. The bind light on the rx goes from flashing, then off quickly to steady on - so it would appear to be binding.
I get no indication on the config screen, or the quad itself that anything is happening with control inputs. The ESCs keep beeping, and the motors make little turns back and forth.
I get nothing on the screen or board than does anything when I move the TX gimbals.
When its wired directly from the laptop to the board with th USB cable, the small tx and rx LEDs on the board light up (when i hit start and read). The blue power LED comes on, and if it moves the status LED lights up.
I'm using a DIYDrones power distibution board, the quadrino advanced, a wiring harness set from Innov8tive RC frm the RX to the board.
What am I doing wrong, or what else am I supposed to have done?
Could I have missed commenting something out when I flashed the board using the arduino program/editor?
jonquinn is offline Find More Posts by jonquinn
Old Apr 29, 2012, 12:49 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
www.multiwii.com
Dialfonzo is offline Find More Posts by Dialfonzo
Old Apr 29, 2012, 01:53 PM
jonquinn is offline
Joined Aug 2008
I'm not seeing anything helpful there.
I did the min throttle when I flashed the board.
I guess I'll have to go through the arduino code again.
Old Apr 29, 2012, 02:02 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Which sensors did you define in the sketch config.h ?
Old Apr 29, 2012, 03:09 PM
jonquinn is offline
Joined Aug 2008
I reflashed the board again with 1.9.
I went through the sketch and defined
#define QUADRINO full FC board 9DOF+baro board from witespy with BMP085 baro <- confirmed by Alex
I took out the // in front of the full FC board above too.
since I don't have a independent baro I didn't do anything with those lines
also defined/uncommented quad x and set minthrottle 1150 (I have rc timer 20A escs).
still nothing happen when I try to bind the rx. It looks like it should be bound, but again nothing happens on the GUI screen when I moved the TX sticks. also, the GUI still shows the baro as OFF.
I can't imagine this should be this difficult.
Old Apr 29, 2012, 03:38 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Check your PM"s
DoctorAudio is offline Find More Posts by DoctorAudio
Old Apr 29, 2012, 07:27 PM
bobandris is offline
Find More Posts by bobandris
LSF 004 - AMA 5055
bobandris's Avatar
United States, CA, Saratoga
Joined Dec 2000
Must You Also Supply VIN
To put my question in perspective, "I am a complete newbie to MultiWii boards". I'm finishing up installation of a Quadrino Zoom (Rev 1E) on the Turnigy mico Quad frame. The "A" motor connector coming off the board has the full three pins, so it will supply the necessary 5v VCC to the board (from the "A" motor ESC) and therefore to the RX through it's own VCC and ground pins. My question is, do I also have to supply the full battery voltage (VIN) to the board. I don't think so, but I can't find any "FlyingEinstein" documentation that says you MUST supply it in addition to the 5v VCC.
Thanks to all,
Bob
bobandris is offline Find More Posts by bobandris
Old Apr 29, 2012, 07:35 PM
cquian is offline
Find More Posts by cquian
USA, TX, The Colony
Joined Dec 2005
Thanks to all,
Bob
No you do not, full voltage goes to motors only through the ESC's, 1 ESC only supplies 5v to the Quadrino, board supplies 5v to your receiver.
Also, never plug in the battery when you are also connected to computer via usb. Usb connection only will provide power to the board and receiver.
cquian is offline Find More Posts by cquian
Old Apr 29, 2012, 08:33 PM
LSF 004 - AMA 5055
bobandris's Avatar
Joined Dec 2000
Thanks, cquian,
And thanks for that USB caveat, I probably would have . . . smoke!
Bob
Old Apr 29, 2012, 08:40 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
One thing i want to say.
I plug my Quadrino to the PC and the Battery all the time since day one.
Old Apr 29, 2012, 09:12 PM
jonquinn is offline
Joined Aug 2008
finally some success, thanks to help from DoctorAudio/Al! Rotors are turning, and it did lift. Unfortunately by the time I got the props on tonight, it was dark outside. I did run it up briefly under the porch light. I think I've gt all the props on in the right rotation/reverse rotation, and they're all spinning the right direction. I didn't try to lift it too much, but it did seem to have a tendancy to want to tip to its left (my right, looking at the front rotors).
Hopefully I'll get a chance to work on it tomorrow after work and spin it up, if not then probably Tuesday.
At least I'm finally on the right track!
Old Apr 29, 2012, 09:45 PM
Milwaukie , Oregon
Joined Feb 2003
JonQuinn:
I am just happy that we got you to the point that you are at!
Jon, You have my number now. If you have an issue, don't think twice just call me.
I will do my best to get you back up and running.
I have many years of time invested in RC.
I don't feel like I should do any less than help those out that need it.
I am a HeliDirect field rep.
Hopefully, I can continue to help out those that need it.
DoctorAudio!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!
P.S. It was a pleasure to help out!
Old Apr 29, 2012, 10:20 PM
cquian is offline
USA, TX, The Colony
Joined Dec 2005
I remember people stating that they blew the diode when they did that.
Old Apr 29, 2012, 10:24 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Maybe
But in theory the diode is there to avoid and correct that.
Maybe reverse diode?
And also there is many ways to power it. I power mine from one esc pin
Old Apr 30, 2012, 01:06 PM
JediKnight2 is offline
Find More Posts by JediKnight2
I'm Bonafide!
JediKnight2's Avatar
Wilmington, NC
Joined Aug 2005
Trying to read thru this megathread..but I am having a slight issue with my new quad. First quad BTW...I have the 1e board on the vic550 frame using 4 Hoverthings motors and Turnigy Plush 18 ESC's. I have connected all the ESC's separately...started my Tx, Throttle all the way up, then connected power, beep beep, throttle all the way down. When I arm the board and start to give throttle one motor hesitates to spin and doesn't seem to be starting or running right. If I hold the quad in my hand and throttle up to where the motor will spin it wants to tilt on me. I sat it down on the floor and it will pull forward, reverse, left and right...but won't even begin to hover as that one motor seems to be slow to start...suggestions.....when I get home I will try to get some video and upload it...just trying to get a jump on it before I get home.
JediKnight2 is offline Find More Posts by JediKnight2
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
