Old Feb 27, 2012, 01:05 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by MOTOSTEIN View Post
sorry im blind as a bat and need it to see on laptop
CTRL & +Key
You will see bigger.
Dialfonzo is offline Find More Posts by Dialfonzo
MOTOSTEIN is offline
Find More Posts by MOTOSTEIN
Joined Sep 2011
wont happen again...so how can i power whatever the usb cable is powering that makes the board work? anyone?
MOTOSTEIN is offline Find More Posts by MOTOSTEIN
Old Feb 27, 2012, 01:06 PM
Joined Sep 2011
again apologies on the caps
Old Feb 27, 2012, 01:16 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
i answer
http://www.rcgroups.com/forums/showp...postcount=2892
Old Feb 27, 2012, 01:52 PM
cquian is offline
Find More Posts by cquian
USA, TX, The Colony
Joined Dec 2005
Originally Posted by Helistupid View Post
I've have altso the same question.
Got the Quadrino Zoom FC (the latest edition I believe) a copple of months ago,
and it controlls my quad big time.
I've used the 1.9 to adjust my quad and it works very ok.
I have put together two tricopters now whitch I would like to try the same FC on
Have read a lots of threads but still not found anything.
My brain must have missed somthing essential
Would be most greatful for some help in this issue.
Best regards
Just go to the config.h tab in the arduino editor. Look for the define statements that say quadx vs. quad+ vs. a tricopter and comment out the quad defines and uncomment the one for tri.
Then upload to FC board.
cquian is offline Find More Posts by cquian
Old Feb 27, 2012, 02:12 PM
Helistupid is offline
Find More Posts by Helistupid
Norway, Akershus, LillestrÝm
Joined Jan 2007
Thanks a lot. I'll try that
Helistupid is offline Find More Posts by Helistupid
Old Feb 27, 2012, 02:54 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Have you tried powering through the VIN pins?
Cervanchez is offline Find More Posts by Cervanchez
Old Feb 27, 2012, 03:25 PM
ROCKY2 is offline
Find More Posts by ROCKY2
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
can anyone tell me how to change the firmware to a tri?
ROCKY2 is offline Find More Posts by ROCKY2
Old Feb 27, 2012, 03:31 PM
Joined Jan 2007
See post #2900/2901 and try that solution
Old Feb 27, 2012, 03:47 PM
ROCKY2 is offline
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
i cant see it ill keep looking have you found it?
Old Feb 27, 2012, 04:15 PM
Joined Sep 2011
Originally Posted by Dialfonzo View Post
Your on board 5v regulator look to be blown.
When powering from ESC wire it should send voltage to the board.
it only powers when usb plugged in alsol! so no that doesnt help
Old Feb 27, 2012, 04:17 PM
Joined Sep 2011
not yet are the vin pins power out or power in?and if power in can i bring power from the battery or different source,like an ESC red wire?
Old Feb 27, 2012, 04:19 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
It will probably not work.
As i said 5v regulator look blown
Old Feb 27, 2012, 05:05 PM
Cervanchez's Avatar
Joined Dec 2011
VIN is power in. I was told by the Quadrino designer that you can power right from the batt as long as its not bigger than 3 cell. I use a dedicated BEC, just because I have blown the diode and reg and am gun shy. If your diode only is bad, then VIN will still work, but if your reg is blown then it will not.
Old Feb 27, 2012, 05:42 PM
cquian is offline
USA, TX, The Colony
Joined Dec 2005
Just open the Config.h file in the MultiWii_1_9 folder
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
