Old Feb 23, 2012, 11:19 AM
Killab is offline
Find More Posts by Killab
Youtube Johnbrum26
United States, TX, Celina
Joined Oct 2010
Oh so i have a question. I have the board all setup in the gui, one thing i notice though is that the motors in the diagram are not all equal at say half throttle. (not real sure if that is a problem or not), but i tried my first flight today. as soon as i give the quad stick imput it flips over super fast, not even enough time to cut the throttle. Not too sure what would cause this. If i remember right on the kk board i had it was a gyro i need to reverse.
Killab is offline Find More Posts by Killab
Old Feb 23, 2012, 12:19 PM
CrazyLittle is offline
Find More Posts by CrazyLittle
CrazyLittle's Avatar
United States, OH, Brilliant
Joined Sep 2011
If you flashed your quadrino with the #define quadrino then you don't need to reverse any gyros.
HOWEVER, you do need to pay special attention to the motor order because they don't plug in 1234 clockwise like a KK board. Also the Rx plugs don't plug in using the normal Aileron/Elevator/Throttle/Rudder order. It's Yaw/Pitch/throttle/Roll (or Rudder/Elevator/Throttle/Aileron). Mixing either of those things could cause your quad to flip unexpectedly like that.
From left to right the plugs on the board are DCBA (4321) and the motor order is:
Code:
A C
D B
-or-
1 3
4 2
CrazyLittle is offline Find More Posts by CrazyLittle
Old Feb 23, 2012, 12:37 PM
Cervanchez is offline
Find More Posts by Cervanchez
Habitual Line Stepper
Cervanchez's Avatar
United States, WA, Redmond
Joined Dec 2011
Originally Posted by Dialfonzo View Post
You can power the board 2 way.
1 - From the BEC
2 - From one of your ESC wire
If you power from the BEC line and add 2 servo to the board. Those 2 servo are driven by the internal voltage regulator of Quadrino and i don't know the spec of that chip but if you put big servo on that.. maybe it's too much
If you power from the ESC wire then all + pin are powered direcly from the ESC BEC without going by the internal voltage regulator.
Actualy my problems started when Iadded the bluetooth module. I think that is defective and is drawing to much current. Regardless, colin did replace my board free of charge so I can't complain there. So then I stopped uusing the bt and now, when I connect servos when powered by usb, it works as it should. When I power up with the flight pack I get a blinking status led.
Cervanchez is offline Find More Posts by Cervanchez
Old Feb 23, 2012, 12:43 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Blinking status LED normaly if you have Multiwii uploaded in the board mean that the board is not level. Or if it's leve you didn't calibrate the ACC in GUI.
Didn't try to plug my bluetooth module on that particular board (Quadrino)
But did you try to connec the + wire of the bluetooth to your BEC direcly.
That way it's not powered by the onboard regulator. You understand what i mean ?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Feb 23, 2012, 01:06 PM
Cervanchez's Avatar
Joined Dec 2011
I do understand what you're saying. That's a good idea. I haven't had much time to do follow up testing. I've been hesitant to hook it up for fear of it doing damage. But, I will also try powering my board (and therefore servos) through the esc wires. I had originally thought that was the source of my problem so I added the dedicated BEC and am powering through VIN. Thanks
Old Feb 23, 2012, 01:17 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Ok
I have never use the BEC input on the Quadrino but just tested with a "Fluke" voltmeter and there is no link between the + input of BEC and the + of all the servo or esc wire.
Like in the attached picture.
Hope it help..
Old Feb 23, 2012, 01:24 PM
Killab is offline
Youtube Johnbrum26
Joined Oct 2010
Code:
A C
D B
-or-
1 3
4 2
thanks i'll check that when i get home tonight, but im pretty sure that i have that right. Ill also check the sketch when i get home. I just downloaded the gui from the multiwii site so maybe it's not defined correctly. Also is the front of the board the N arrow or should it aligned just like the diagram.
Old Feb 23, 2012, 04:28 PM
Joined Sep 2011
The front of the board is "North"
The mounting hole between "Quadrino" and the USB plug is "north"
Old Feb 23, 2012, 04:31 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
[]http://crymore.com/img/quarino%20north.jpg[/IMG]
There is no relation to north.
North is north.. if you turn the board then the north move..
Old Feb 23, 2012, 04:49 PM
Joined Sep 2011
No, I'm not referring to magnetic north of the earth's magnetic field, nor am I referring to north as oriented on a geographical map. HOWEVER, if you simply say "up" or "front" instead of north you could be referring to the Z-axis instead of which part of the board should be facing the front of the aircraft. So relative to the board itself, North is forward, East is right, South is backwards, West is left, "up" is above the board, and "down" is below it. This is a much clearer definition for the orientation of the board than saying "up" or "front". If you only say "front" then you could also be referring to the top face of the board, compared to "back" which would be the reverse face.
Silkscreened onto the quadrino board is a diagram that's shows a quad-X where the "forward" direction arrow is facing the wrong way.
See how that can get confusing?
Old Feb 23, 2012, 04:51 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I see your point but don't agree.
Front is always the front..
The easiest is the X-Y-Z on the board that show the right direction.
Y arrow facing forward.
Old Feb 23, 2012, 09:30 PM
jonquinn is online now
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
well maybe I'm getting a little further. I found out how to find and look at the Arduino sketch, and I think change to the quadrino (not the quadrino zoom since mine was the edition before the zoom).
but when I try to do the upload, I get an error message
core.a(HardwareSerial.cpp.o): in function'_vector19':
then gives folder address and
hardwar\arduino\cores\arduino/HardwareSerial.cpp:192: multiple definition of '_vector_19'
MultiWii_1_9.cpp.o: folder namebuild75940137260636179.tmp/MultiWii_1_9.cpp:3325: first defined here
so, not sure what to do next? I've tried the two different serial ports I had listed (COM1 COM3) - no difference. I selected board "Arduino Pro or Pro Mino (5V, 16 MHz) w/ ATmega328 - I have a Quadrino Advanced that I bought last summer before the Zoom came out later
but at least I feel like I'm unlocking some of the secrets, of a supposedly "ready to fly" board
- or maybe I'm just fooling myself into not believing that I didn't pay $145 for a board that wouldn't pass any sort of QC muster.
jonquinn is online now Find More Posts by jonquinn
Old Feb 24, 2012, 05:30 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Which version of Arduino software are you using?
Can you post a printscreen of it?
Old Feb 24, 2012, 06:11 AM
Psionic001 is offline
Find More Posts by Psionic001
Psionic001's Avatar
Australia, NSW, Sydney
Joined Apr 2006
The latest version of arduino fails with multiwii software.
Use version 22 or 23 and you'll be fine. Arduino V1.0 is not compatible.
Psionic001 is offline Find More Posts by Psionic001
Old Feb 24, 2012, 06:18 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Exactly where i was going
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
