Old May 29, 2011, 10:38 PM
Flying-Monkey is offline
Find More Posts by Flying-Monkey
Did you get it on video?
Flying-Monkey's Avatar
United States, FL, Ponce De Leon
Joined Nov 2005
Originally Posted by aerorotor View Post
Witespy these are not defined in my warthox 2.0 board I bought from you. I've been asking you which of these I should define. I do not know if my board is using the official wii boards or the clones. I sent you a detailed email regarding this. You said everything looked good, but it seems some of the sensors are not enabled. My I2C_speed is set to 100000L.
For the warthox board, you might want to check here...
http://www.multiwiicopter.com/pages/multiwiicopter-wiki
about 3/4 of the way down the page looks like what you're asking about.
Flying-Monkey is offline Find More Posts by Flying-Monkey
Old May 29, 2011, 11:30 PM
aerorotor is offline
Find More Posts by aerorotor
Joined Oct 2009
I have seen this page but the components are not the same as what is on my board. My board was assembled by witespy and by the looks of things he used different components than what is on that page. My board looks like it has another nunchuck on the bottom. I bought a board with self leveling.
aerorotor is offline Find More Posts by aerorotor
Old May 30, 2011, 12:07 AM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
none of these apply to a warthox 2.0 board. THese are for Quadrino Muiltwii Flight controller
warthox 2.0 board should be set to 100000L with a normal MP
FLYING_ MONKEY is correct.
see section
Classic Nintendo Wii Motion Plus MP+ and Nintendo Wii Nunchuk NK combo
on this page for all the information http://www.multiwiicopter.com/pages/multiwiicopter-wiki
witespy is offline Find More Posts by witespy
Old May 30, 2011, 02:44 AM
Joined Oct 2009
Ok thanks was not sure if everything was correct since the sketch was not loaded when I got it.
Old May 30, 2011, 10:46 AM
BrokenRotor is offline
Find More Posts by BrokenRotor
BrokenRotor's Avatar
Nashville TN
Joined Jan 2011
Originally Posted by witespy View Post
did you do these changes to the stock code?
The following steps were made to prepare the stock MultiWii code for the Quadrino ADV board:
1. Define your appropriate MINTHROTTLE depending on your ESCs
2. Choose multicopter mode: TRI, QUADP, QUADX, Y4, Y6, HEX6, HEX6X
3. Enable 400kHz i2c mode (I2C_SPEED = 4000000L)
4. Enable the following config defines:
ITG3200
BMA180
BMP085
HMC5883
5. Uncomment MOTOR_STOP. (This is our recommended setting.)
What about the I2C internal pull-ups?
Without a onboard LLC with a 5V mpu, they should be disabled with 3.3V sensors.
Update> Duh, Just reread the manual, it has LLC built-in. So internal pullups should be enabled.
BrokenRotor is offline Find More Posts by BrokenRotor
Old May 30, 2011, 12:59 PM
witespy is offline
Joined Sep 2009
IT does NOT matter. Build in fail safe.... you can just keep them on if you wanted
Old May 30, 2011, 02:45 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Woo-Hoo...light winds today so I got to take my Vic20 450 frame and QuadRino board out today. Daddy likes. I think I've got a little PID adjustments to do, but it flew very comfortably and very well.
On another controller thread there was talk about having the motors spin when armed. All my previous controllers wouldn't spin the motors until throttle was applied. I asked the benefit/why spinning vs non-spinning motors. One reply back was 'I take it up high, chop the throttles, and the quad descends, but since the motors are spinning, the gyros/accels are still acting on the 'drop' and help hold things stable. When close to the ground I hit the throttle and, (since the quad is already stabilized), it shots straight back up...no worry of some weird direction change'.
After my first flight with the quad in normal setup, I decided to try the spinning motor thingy. I cheated though vs changing something in the coding (which I don't know how to do anyway). I just increased my throttle trim until the motors spun up. One click of down trim and they stop. I also have and use a throttle kill switch. When the kill switch is active the motors do not spin...no matter what. I tried the 'trick', climbing high and chopping the throttle. I thought it would drop like a rock. Nope, instead it came down at not-to-fast a rate and stayed pretty much level. When I hit the throttle it just shot back up. Okay, I can live with that. If needed I can just hit the kill swith or hit down trim to fully stop the motors.
Once almost finished with the third battery through the quad I wanted to see how the QuadRino behaved when arming/disarming with some throttle trim engaged. Good news...it won't arm at all UNLESS I have the kill switch on or drop the throttle trim all the way down. I figure I'll normally 'kill' the motors by the one-click of down trim when I'm not flying as well as using the kill switch. After arming the board and then turning off the kill switch the motors still won't spin until I give it that one click of up trim. I might go back and set my other boards similar to this so they all behave the same.
Oh yeah...and I really liked how the QuadRino board performed. After some tweaking it should be really fun!!!!
Vantasstic is offline Find More Posts by Vantasstic
Old May 30, 2011, 02:54 PM
Joined Nov 2005
Van, I'd like to see your config screen when you get things worked out.
Old May 30, 2011, 02:55 PM
cactus is offline
Find More Posts by cactus
cactus's Avatar
United States, CO, Durango
Joined Sep 2001
Vantasstic,
How is auto level and heading hold working so far?
cactus is offline Find More Posts by cactus
Old May 30, 2011, 03:34 PM
llbr22 is offline
Find More Posts by llbr22
llbr22's Avatar
USA, CA, Oakland
Joined Nov 2009
+1
llbr22 is offline Find More Posts by llbr22
Old May 30, 2011, 03:35 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by cactus View Post
Vantasstic,
I have the basic board, so heading hold is not a possibility for me, nor is altitude hold. I may add the sensors later though.
A for the leveling, mine does pretty well out of the box with my Vic20 450 frame. I think it still needs some tweaking with the PIDs. My XAircraft controller auto-level feature response much faster and with less drift than the QuadRino board did on my first 'real' flights. I did try turning auto-level off and you can certainly tell the difference, but I just left it on for the flying I was doing.
I think I need to invest in a little netbook or similar so I can take it to the field, fly, adjust PID, fly, readjust PID, etc. I could do it with my laptop, but a smaller netbook would be much easier to haul around and ought to fit in my flight box pretty easy.
Old May 30, 2011, 03:58 PM
Joined Nov 2005
I have dedicated my netbook to that purpose. For both my quad, and my stabilized helicopter.
Old May 30, 2011, 10:05 PM
seadog1967 is offline
Find More Posts by seadog1967
Waiting for my Medication
seadog1967's Avatar
USA, MA, West Springfield
Joined Nov 2010
latest flight testing with the quadrino board.
Memorial Day Quad Flight (6 min 39 sec)
seadog1967 is offline Find More Posts by seadog1967
Old May 30, 2011, 10:22 PM
djdavid60 is offline
Find More Posts by djdavid60
If it flies, I can crash it!
djdavid60's Avatar
Naperville, IL
Joined Aug 2010
Looking good seadog!
djdavid60 is offline Find More Posts by djdavid60
Old May 30, 2011, 10:27 PM
seadog1967's Avatar
Joined Nov 2010
Thanks. Trying to overcome my panic moves. LOL Didn't use auto level or mag this time. Got daring to see what I could do on my own LOL. Thanks again.
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
