Old May 23, 2011, 08:02 PM
Dolby is offline
Find More Posts by Dolby
Needs more bacon!
Dolby's Avatar
United States, WI, Milwaukee
Joined Jan 2011
Originally Posted by tc3wins View Post
Nice setup. So Were you using the stock level setup to. where it is set to 14.
Yes, all PID settings are stock. I built my own Multiwii and I had to lower the numbers big time and its using a blue vc20-450 frame. So unless the color has an effect this controller is working better.
Dolby is offline Find More Posts by Dolby
Old May 23, 2011, 08:05 PM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
what type of standoffs are you using for the board?
tc3wins is offline Find More Posts by tc3wins
Old May 23, 2011, 08:09 PM
cactus is offline
Find More Posts by cactus
United States, CO, Durango
Joined Sep 2001
I had a better flight this evening with the following settings. There is no longer a pronounced wobble or bounce on inputs and it's stable in a hover. I still get a very light bounce on hard moves, but its controllable. I tried LEVEL mode again too and it was not wobbling but was also not fighting my inputs very much and has some drift. I need to work on that now, then try mag and baro last.
cactus is offline Find More Posts by cactus
Old May 23, 2011, 08:17 PM
seadog1967 is offline
Find More Posts by seadog1967
Waiting for my Medication
seadog1967's Avatar
USA, MA, West Springfield
Joined Nov 2010
Quad Hover 1 (3 min 17 sec)
seadog1967 is offline Find More Posts by seadog1967
Old May 23, 2011, 09:40 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Funny thing you should mention standoffs. Quick story here:
I received my QuaRino board a couple of weeks ago and it went out on me withing the first few minutes of use. I worked with Colin on the issue and ended up sending the board back to him. He found a blown diode, replaced it, tested it, and sent it back to me. I just got the board today, mounted it, connected only the Signal line from the ESCs to the motor pins, and powered the board via a BEC connection to the Rx. When I attached my flight battery...nothing. The board didn't lite up, neither did my Rx. I removed the power lead from the Rx to the board, connected the flight battery again and the Rx lite up. Reattached everything, powered up, nothing again. I pulled the board off the standoffs, attached the battery, viola, the board lite up. I did a little more investigation and found a test point very close to the rearmost mount hole. The standoffs I'm using...ALUMINUM! Apparently the standoff was shorting the ground plane of the board and whatever the test point connects to.
To fix, I grabbed some old servo vibration isolators, cut off part of the end piece, installed the rubber isolator between the board and the aluminum standoff. When I attached the flight battery...everything lite up fine and I was able to get some trim and control adjustments in with no problems. Well...almost. I think the same diode blew again as the board won't power up with a Rx battery attached to the motor pins. Colin had sent me some spares, just in case, and it looks like I'll need to use one. That's not a biggy unless you power the board from the motor pins...which I'm not.
So...moral of the story, use either plastic or rubber standoffs OR install some sort of insulator between the board and the standoffs if using metal standoffs.
FWIW (everyone)...have you read how the board reacts to Rx failures? If the board is powered via the motor pins OR the Vin pin and you lose the Rx the board will continue to fly the quad...uncommanded. That could be a safety issue...a flyaway quad. If you power the board via the Rx pins and lose the Rx the quad will quit and drop like a rock. I'd hate see see a crash, but that's a lot safer than a flyaway quad IMHO.
Vantasstic is offline Find More Posts by Vantasstic
Old May 23, 2011, 10:48 PM
zyp is offline
zyp
Find More Posts by zyp
zyp
Joined Apr 2011
That doesn't make sense, unless the receiver somehow stopped providing power to the board when connection is lost. None of the receivers I've seen does that, and there is no reason to do it either.
Unless the circuit is designed specifically for it, the microcontroller has no way of knowing how it is powered. It's either powered or not.
The only difference when the connection is lost is that the receiver stops giving updates to the microcontroller. It's up to the software in the microcontroller to either carry on with the last command, crap out or revert to failsafe values. I have no experience with MWC so I don't know what it does, but whatever it is, it's unrelated to how the board is powered.
I might of course be wrong, but not until I see a schematic telling me I am.
zyp is offline Find More Posts by zyp
Old May 23, 2011, 11:54 PM
Dolby is offline
Needs more bacon!
Dolby's Avatar
Joined Jan 2011
Just using nylon standoffs with no anti-vibration. http://www.multiwiicopter.com/collec...off-15mm-nylon
Old May 24, 2011, 04:17 AM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
witespy,
will you please clean some of your pms, your inbox is full
thanks in advance,
bob
bob4432 is offline Find More Posts by bob4432
Old May 24, 2011, 04:39 AM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
Originally Posted by bob4432 View Post
witespy,
thanks in advance,
bob
Yep
And when are the next basic boards going out and When are the advanced boards going out
NaterPin is offline Find More Posts by NaterPin
Old May 24, 2011, 08:25 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
From the manual...that's the way the failsafe is setup. As long as the board is powered it will try to fly itself if it looses Rx. Powering by the Vin or ESCs could leave power on the board even if the Rx dies. If the power is coming from the Rx to the board and the Rx dies then power to the QuadRino board also dies, so it stops and drops. A total Rx loss is a pretty rare event so not a huge player...and no, I'm not willing to test it to see what it really does...just repeating what the manual says.
Old May 24, 2011, 08:32 AM
IWCoburg is offline
Find More Posts by IWCoburg
Member FPV UK
IWCoburg's Avatar
Isle of Wight, UK
Joined Apr 2010
SNIP
There is some stuff in the 1.7 code to deal with the loss of reciever input and deal with it accoring to some presets defined. Without specifically checking after a defined time period of a loss of reciever input, then the controller should then set what ever throttle has other conditions that have bee preset.
Mike.
IWCoburg is offline Find More Posts by IWCoburg
Old May 24, 2011, 10:04 AM
zyp is offline
zyp
zyp
Joined Apr 2011
… If the power is coming from the Rx to the board and the Rx dies then power to the QuadRino board also dies, so it stops and drops. A total Rx loss is a pretty rare event so not a huge player...
On every receiver I've seen, all vcc and gnd pins are just directly connected together, meaning that the input power pin is directly connected to the output power pins, meaning that as long as the receiver have power in, it will provide power out.
Old May 24, 2011, 12:20 PM
Ernes is offline
Find More Posts by Ernes
Spain
Joined Dec 2010
Hi
My advanced board is coming!!! I want to put the board in a flat hexa. Can someone show me how I can connect the signal wires of the escīs to the board pins?
Ernes is offline Find More Posts by Ernes
Old May 24, 2011, 02:32 PM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
Originally Posted by NaterPin View Post
Yep
Nater,,, I have a AVD board here for you if you wanted to upgrade..
I sent you a message did you get it ??
witespy is offline Find More Posts by witespy
Old May 24, 2011, 04:30 PM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
<logs into PayPal>
Okay folks, where do I order?
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Article Hangar 9's Piper J-3 Cub 40 Plug-N-Play PNP Plug N Play Evo 46NT Powered ARF Review tailskid2 Scale Fuel Planes 8 Dec 24, 2013 04:08 PM
Help! need new flight controller recommendations n3m1s1s Multirotor Talk 115 Jan 09, 2012 09:38 AM
Article Subsonic's Motrolfly Plug and Play Power System: Motor, Controller & Battery Review Michael Heer Power Systems 27 Dec 16, 2010 12:36 PM
Data Plug 'n Play separates: An Esky CP2 with an E-flight 2 in 1... elan Micro Helis 3 Mar 19, 2010 08:51 AM
Discussion Air Hogs Plug n'Play Flight Deck Simulator trust416 Micro Ready-to-Fly 14 Aug 05, 2007 10:44 AM
